      04-30-2009, 08:11 AM   #1
BForbes
Moderator
BForbes's Avatar
Bahamas
642
Drives: BSM 135i/AW E90 M3
750i horsepower VERY underrated!
http://blogs.edmunds.com/roadtests/2....photopanel..2.*
Yup, that's our long-term 2009 BMW 750i on MD Automotive's Dynojet chassis dyno in Westminster, CA.
And why not? After all, its 4.4-liter V8 is not only twin-turbocharged and equpped with direct injection, it's been turned inside out. That's right--the intake manifolds are located where the exhaust manifolds usually live, and the turbos nestle in the vee formed by the two cylinder banks.
Does this unconventional layout actually work? Is Nutella a delicious spreadable chocolatey substance? When we finally defeated all of the 750i's numerous electronic protections (including one that throws the transmission into Park if the wheels turn while the door is open), we found out just how angry this flagship luxury liner can be.
Hit the jump for the dyno chart.
BMW rates the 750i at 400 horsepower at 5,500 rpm and 450 pound-feet of torque at 1,800 rpm.
We started our run after 2,000 rpm and found that peak torque arrived a bit later than BMW's claim. Nevertheless, it's safe to say that the engine is, shall we say, robust. What's more, while on the dyno the BMW breezed right up to the rev limiter with little more than a whoosh, as if it wasn't even working hard.
As you can see, there's a big shelf of torque available all the way through the midrange. Torque rolls off steadily past 4,600 rpm followed by a more precipitous drop at 6,500 rpm. Without running all the numbers, it's likely that the BMW turns in its best acceleration times by shifting well short of its 6,700-rpm rev limit.
It's worth noting that turbocharged cars generally produce "high" chassis dyno results relative to normally aspirated cars rated at similar power. Part of the explanation is due to the turbo car's intercooler--automakers tend to heat soak the intercooler to somewhat higher temperatures during their certification process than what you get on a chassis dyno. The result is that the numbers claimed by the automaker end up appearing a bit conservative. And that goes for pretty much any modern turbocharged gasoline engine.
Conservatively rated or no, this sucker's quick. We clocked the 750i at 5.2 seconds to 60 and 13.5 @ 103.7 through the quarter mile. Not bad for a 4,600-lb sedan.
Jason Kavanagh, Engineering Editor
It looks to be putting out 391whp! In reality, its putting out over 450hp.
- 04 Honda S2000(gone)
      04-30-2009, 12:31 PM   #2
xDrive50i
xDrive50i's Avatar
Drives: '09 750i individual
Interesting and thanks for the post!
      04-30-2009, 02:32 PM   #3
135forthewin
Drives: sideways
I just saw that on edmunds, very impressive.
That car must spin the tires quite a bit, because a 5.2 0-60 seems relatively slow for that car with that power/weight ratio.
Compared to the Mercedes S550 which does a 5.3 0-60 with less hp at the crank than the bimmer has AT THE WHEELS, this seems odd...
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      04-30-2009, 03:14 PM   #4
BimmerGuyFL
Drives: 2013 F10 BMW 535i M-sport
With those numbers the car is making more like 460 hrp and 511 Torque at the engine...........Oh Man that engine is a BEAST!!
2013 F10 BMW 535i Alpine White / Oyster Dakota Leather / Anthracite Wood Trim / Steptronic transmission / M Sport Package / Premium Package / Technology Package / Rear-view camera / Park Distance Control
      05-01-2009, 12:28 AM   #5
samuraisaiyo
samuraisaiyo's Avatar
Thailand
Drives: 318i E36
oh
      05-01-2009, 03:04 AM   #6
ShaneV78
Drives: 440i M-Sport
So if all the BMW turbo motors are this conservatively rated, does it mean the 760i will actually be around 600hp?
      05-01-2009, 05:30 AM   #7
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [9.50]
Beast.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      05-01-2009, 06:54 AM   #8
mtechnik3
mtechnik3's Avatar
Drives: 2020 M2C
ohhh wow....move over AMG's
      05-01-2009, 08:13 AM   #9
GreenPlease
GreenPlease's Avatar
Drives: BMW 335i e92
Wow. Definately a Beast.
4600lbs? Seems like the 750i could use a diet...
      05-01-2009, 11:25 AM   #10
Silvertige
Silvertige's Avatar
Drives: 2011.75 e92 M3
1988 BMW 535i  [10.00]
Crazy...
      05-01-2009, 01:33 PM   #11
BzzzBom
Drives: 05 R53 MINI / 09 335i Coupe
Does anyone know what the 2009 740i dynos at?
      05-01-2009, 02:54 PM   #12
Remonster
Drives: E90 M3
Go test drive it and take it on some twisty roads. I usually like my cars small and light and consider my E90 (non sport, so it has 205 width tires all around) portly and always felt it could lose a couple hundred pounds.
With that said, the F01 blew me away. Completely. I would have no problem justifying spending a hundred grand on one, if I had it.
      05-01-2009, 06:23 PM   #13
M3WC
Drives: BMW
This engine in the next 5-series, is going to be insane. With a simple tune, it will roast everything.
      05-02-2009, 02:35 PM   #14
blue2fire
blue2fire's Avatar
Cayman Islands
284
Drives: BMW 135i
The simplest solution is to conclude that even Merc rates their V8 conservatively.
BMW CCA
Member #420568
Originally Posted by Gordon Murray View Post
Being a fan of Honda engines, I requested that they consider building for the F1 a 4.5 liter V10 or V12. I asked, I tried to persuade them, but in the end could not convince them to do it, and the McLaren F1 ended up with a BMW engine.
      05-02-2009, 03:38 PM   #15
roozie2001
Just some guy
roozie2001's Avatar
Drives: 2008 White 335i sedan
why would u give a 7 series big body german sedan a diet. without the weight u wouldnt have that ride comfort. even if the car was 5000 lbs i'd be all over it.
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
      05-03-2009, 02:21 AM   #16
Master Deep
Drives: 06 325xi
2006 325xi  [0.00]
new jaguar xjr coming out next year is said to be only 3700 lbs. How Jaguar managed to get a flagship 510hp car weighing that much simply blew me away. We shall wait and see how it compares to the 750.
      05-03-2009, 02:27 AM   #17
xDrive50i
xDrive50i's Avatar
They probably use inflatable seats and steering wheel... You need to inflate them yourself before you can drive the car
      05-03-2009, 02:43 AM   #18
Fastbuck
Fastbuck's Avatar
Scotland
Drives: F01 740d M Sport
They've probably added the engine and gearbox to the options list!
Fastbuck
2012 F01 740d M Sport Alpine White Oyster/ Oyster
2013 E84 X1 1.8d M Sport Alpine White Black/ Black
      05-03-2009, 03:39 PM   #19
Master Deep
Drives: 06 325xi
2006 325xi  [0.00]
lol. It's because the car is built entirely out of aluminum. But if you were to get into an accident....it would cost a lot more to fix.
P.S. The current XJ weights 3,770 lbs. So making the next gen weigh less than 3700 isn't a far fetch.
      05-03-2009, 04:41 PM   #20
blue2fire
blue2fire's Avatar
Cayman Islands
284
Drives: BMW 135i
It has an all aluminium body in its present iteration and since the latest one is supposed to be just rebodied to show their current language, i expect more of the same.
It should properly kick the ugly 7's head in the lavatory and goose its mother, i cant wait to see it!
BMW CCA
Member #420568
      05-03-2009, 04:42 PM   #21
blue2fire
blue2fire's Avatar
Cayman Islands
284
Drives: BMW 135i
Oops, just looked to see that you answered it yourself.
BMW CCA
Member #420568
