      04-18-2010, 01:27 PM   #1
BMWMB
BMWMB's Avatar
Belgium
36
Drives: Mercedes C450 AMG Sport
My BMW 740d with AC Schnitzer lowering and 20" wheels styling 238
3 Months ago i picked up my new F01 740d.
Since a few weeks my dealer installed lowering springs of AC Schnitzer (-25mm) and 20" wheels styling 238.
I was thinking about taking 21" wheels styling 312, but i decided not to take them because of too little rubber and to delicate for curb damage.
Here is a pic of my car in wintersetup before lowering:
These is my car in summersetup after lowering:
      04-18-2010, 01:29 PM   #2
BMWMB
BMWMB's Avatar
Belgium
36
And some interiorshots i took in wintertime:
      04-19-2010, 02:57 PM   #3
TheGooch
Drives: 2021 X7 M50i
Lookin Good!
      04-19-2010, 05:01 PM   #4
vladberca
vladberca's Avatar
Romania
763
Drives: '18 octavia 2.0 tdi dsg
Your car looks much better now! Cograts!
      04-19-2010, 05:18 PM   #5
bmr760
bmr760's Avatar
Drives: G80 M3C, F90 M5C, G05 X5 40i
Beautiful car
      04-19-2010, 08:56 PM   #6
schnell325
Bored at work....
schnell325's Avatar
Drives: 2016 F82 M4 GTS//2022 M235iGC
Awesome drop!!
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      04-27-2010, 05:31 PM   #7
BMWMB
BMWMB's Avatar
Belgium
36
Should it be possible to drop the car in front about 10mm more?
      09-26-2010, 06:54 AM   #8
BMW Alpina
BMW Alpina Enthusiast
BMW Alpina's Avatar
Drives: Alpina B7
it is possible to drop the front lower,
but you got to use different Brand of Springs.
H&R sport springs front drop is 1.6inches,
and another more extreme version of H&R
which is super sport springs even drop much more to 2 inches.
G Power springs front drop is 30mm
Hartge Springs front drop is 30mm
Hamman springs front drop is 40mm
only Eibach Pro Kit is the same as ACS at 1 inch/25mm front drop
      09-26-2010, 04:30 PM   #9
BMWMB
BMWMB's Avatar
Belgium
36
Thanks for your reply.
I am now accustomed to the look with this drop and i'm satisfied.
Maybe after wintertime i'm going to change my 20" rims for 21" styling 312, the silver ones.
      09-26-2010, 05:06 PM   #10
wjhughes420384
Drives: 2009 750Li - Space Grau Metal
what tires did you use in winter? were they run flats?
      09-26-2010, 05:15 PM   #11
BMW Alpina
BMW Alpina's Avatar
Drives: Alpina B7
Hi,
How is the Ride comfort compare to standard springs ?
How is the Handling and Balance of the car compare to standard springs ?
Does the lower ride clearance give any problem for you to go on a ramp/speed bump ? (any scrape)
Thanks
      09-26-2010, 05:49 PM   #12
Lastcombo
Lastcombo's Avatar
Netherlands
Drives: BMW 730D
Question
Thanks
Hi,iam also curious about the handling ,comfort and performance of the car,could you please let us know thnx grtz
      09-27-2010, 07:50 AM   #13
SAMLAMBO
Drives: 2010 BMW 730Li
is there any spring out there that wont drop more than 1"? I dont want to sacrifice to much comfort and still want to be able to go through humps, car parks comfortably. Also is all that required springs and just for the fronts or also shocks?
2012 BMW 740i
2011 Mercedes E250
2010 Lamborghini LP670-4SV
      09-27-2010, 09:09 AM   #14
BMW Alpina
BMW Alpina's Avatar
Drives: Alpina B7
Eibach Pro Kit drop is only 1 in front and 0.8in rear.
Alpina B7 drops is only 0.6in front and 0.4in rear, but I don't think Alpina sells their springs for regular BMW owner.
this copy and paste is from Alpina B7 review :
http://www.insideline.com/bmw/alpina...rst-drive.html
The suspension's coil springs have different rates than the stock 7 Series and the ride height is 0.6 inch lower in front and 0.4 inch in the rear.
so far I had NOT find any tuner/suspension company that sells (shocks and springs) kits for the new 7 Series.
so I think there are no shocks available for new 7 series yet...
if anybody have any info regarding aftermarket
performance shocks for the new 7 series please post here.
Oh by the way, the only company that I knew
change the damping value of the shocks is
Alpina for their Alpina B7.
Hamman, Hartge, ACS, RDsport, do not have
any replacement shocks only springs...
Although I am sure if you have no limit with your budget, you can always custom
install Moton or Ohlin (or other exotic racing shocks) and used it for 7 Series...
      09-27-2010, 09:18 AM   #15
SAMLAMBO
Thanks for your detailed reply. I would prefer just to swap the springs as I use the car nearly everyday and it would be more for looks than anything else. I could end up with Hamann since it's just springs thsat they offer and what I prefer, however I dont want it to drop so much. Can I just change the front springs?
2012 BMW 740i
2011 Mercedes E250
      09-27-2010, 09:36 AM   #16
BMW Alpina
BMW Alpina's Avatar
Drives: Alpina B7
Hi Samlambo,
your car is LWB, and usually LWB had rear self leveling suspension,... right ?
http://www.hamann-motorsport.com/en/...02/suspension/
on hamann webpages above,
they do sell the kit for Front Springs only and
some kind of link extension for the Rear Suspension.,
so if you buy the Hamann Kit for Self Leveling Suspension that it should be perfect for you.
but since you also do NOT want the car to be too low,
than maybe this Eibach kit is better for you.
if you go to Eibach.com,
you can try to find the correct part number for the Pro Kit that only have 2 front springs in the kit (not 4 springs).
it lower the front springs 25mm/1in.
Since your car is a 730iL,
I think the kit from 730d will suit you the best.
This is the kit number:
E10-20-018-03-20
again the kit number above is for the front springs kit only.
and when you try to look for F01/F02 spec,
don't forget to put in European and Asian Application on the Product Line menu at
Eibach.com website.
because on the US application menu,
they only have the E65 7 series but no F01/F02 menu...
I guess Eibach is not updating their website completely..
if you have more info from your local Eibach dealer in Singapore,
please let us know.
Thanks
      09-27-2010, 09:42 AM   #17
SAMLAMBO
Hi Samlambo,
E10-20-018-03-20
Eibach.com website.
please let us know.
Thanks
You have been very helpful and informative, really appreciate it. I am more inclined towards the Eibach. I will look into this now and report soon, thank you very much.
2012 BMW 740i
2011 Mercedes E250
      09-27-2010, 01:30 PM   #18
BMWMB
BMWMB's Avatar
Belgium
36
I'm not for sure, but ik think my wintertyres are Continental. And yes, they are RFT's.
      09-27-2010, 01:44 PM   #19
BMWMB
BMWMB's Avatar
Belgium
36
Hi,
Thanks
Honestly, i don't feel much difference...
Most of the time i drive in 'sport'-modus, because in the other settings the springs are a little bit bumpy, especially when you take speed bumps with higher speed. I' am comparing with my earlier E60 530d with sport suspension. Also in sport-modus you have a sporty handling and balance, but i don't think there is much difference with the standard springs, so the ride comfort is also still ok.
Because the lowering is only 25mm, i don't have problems with scraping.
Conclusion: AC Schnitzer lower springs (or Eibach Pro-kit) are perfect.
      09-27-2010, 10:48 PM   #20
SAMLAMBO
Ok thanks, I have emailed Eibach, awaiitng their quote.
2012 BMW 740i
2011 Mercedes E250
      09-28-2010, 01:23 AM   #21
BMW Alpina
BMW Alpina's Avatar
Drives: Alpina B7
Hmmm based on BMWMB description that
he need to put his suspension in Sports Mode to avoid the ride being bumpy show that
AC Schnitzer springs have much higher spring rate than the standard suspension.
So Samlambo,
perhaps it is best if you could e-mail AC Schnitzer and ask their Spring Rate,
then ask Eibach for their Spring Rate and compare them.
If Eibach have lower spring rate than AC Schnitzer then your ride should be not bumpy even if you left your suspension in normal mode.
If you could have their spring rate data,
please kindly post it here.
by the way, I also would recommend you to check with Hartge for their price and spring rate.
because Hartge's spring is 30mm (only a bit more lower than ACS),...
with Hartge, I think you can buy direct from them...
Thanks
      09-28-2010, 05:06 AM   #22
SAMLAMBO
Thanks, i will do a check. i have also emailed Hamann for a quote. Might just end up with Eibach only becuase I dont want it to drop to much.
2012 BMW 740i
2011 Mercedes E250
