08-30-2014, 12:03 PM | #1 |
Rep 41
Would this setup work? Enkei RS05RR
Hi everyone,
I would like to your help and input. Would I be able to make this work? Wheel - Enkei RS05RR Front - 18x10.5 / 5x120 / Offset +23 (Face R) - tire size: 275x35x18 Rear - 18x11 / 5x120 / Offset +30 (Face R) - tire size: 275x35x18 or 295x35x18 I am not sure about the 295x35x18. I could be wrong with the aspect ratio 35 versus 30. My car is a E93 M3 stock suspension with EDC. I also would run my current setup 245x40x18 (front) 265x40x18 on these wheels in the beginning. I know there might be some stretching until I change out the current tires. Please let me know. Best regards, Guenther |
08-30-2014, 02:06 PM | #2 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Your plan on the front is doable but it will be challenging. You may need to add camber plates to make it work. The 9.5" et22 version would be far easier to fit.
I would run 295/35/18 on the 11" et30 rear. That should be a fairly easy fitment but you may need to add a little negative camber. Some people run 295/30/18 but that size is a full inch shorter than OEM and the only reason to go that route IMO is to run certain r-comp tires that are not available in a larger size. 295/30/19 is the right size for a 19" wheel on the M3 (same overall tire diameter as 265/35/19). To run that size on an 18" wheel means you are running an unnecessarily slim sidewall height and the wrong overall diameter. I would definitely not stretch your OEM tires onto those wheels. Sell the tires and get some in proper sizes.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
08-30-2014, 02:24 PM | #3 |
Rep 999
front would be a PITA
rear would fit no problem
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
08-30-2014, 05:01 PM | #4 | |
Rep 3,979
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
08-30-2014, 05:18 PM | #5 |
Rep 6,734
Yes you are correct, 305/30/19 is technically closer to the same overall diameter as 265/35/19.
'23 X7
08-30-2014, 08:30 PM | #6 | |
Rep 3,979
Thanks in advance... Dave
08-30-2014, 08:35 PM | #7 | |
Rep 6,734
The rear will work well but will be somewhat conservative. You could go to et25 with Michelins. Et27 for more flexibility to use more square / wide tires like AD08. Et31 would allow 305/30/19...
'23 X7
08-31-2014, 12:14 PM | #8 | |
Rep 3,979
Dave
