European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      08-08-2015, 12:40 PM   #1
F82Steve
F82Steve's Avatar
Drives: 2015 BMW M4
Check Engine Light at 3000 miles? Common?
I have a 2015 M4 and my check engine light has come on. I was told there was two codes and this is the second time I have had to bring it back to the dealership for repairs.
Code: 12B304 Lambda probe heating after catalyst activation: Line Break
Code: CD0487 Central Gateway: Synchronization failed.
Anyone have a clue what these codes mean?
Car is currently at the dealership (2nd visit).
Thank you!
      08-09-2015, 11:29 AM   #2
F82Steve
F82Steve's Avatar
Drives: 2015 BMW M4
Originally Posted by darge82 View Post
What codes did you have on the first visit? The central gateway fault is an erroneous fault do not worry about that. The other fault is an O2 sensor issue. Either a wire problem from the O2 sensor to the DME or something internal in the sensor failed on the heating circuit.
Is the car modded at all? Do you have downpipes?
Car is completely stock. The first time I brought it, it read the same exact codes. They replaced one O2 sensor, now the other one is bad.
      08-09-2015, 10:30 PM   #3
heckyeahbro69
heckyeahbro69's Avatar
518
Drives: m3
Take it to the dealer. Common problem. There is an sib
      08-10-2015, 01:19 PM   #4
solstice
Drives: 2015 M3 6MT
I had intermittent check engine light that was diagnosed to "lean fuel mixture". The dealer worked with BMW corporate and fixed it with a SW update. No re-occurrence after that.
      08-12-2015, 10:23 AM   #5
heckyeahbro69
518
Drives: m3
12B304 - Oxygen sensor after catalytic convertor, activation: line disconnection
cause
Under certain conditions, moisture can enter the internal insulation layers of the oxygen sensor.
If the sensor’s heating activation occurs too early, the internal pressure can damage the sensor elements, leading to the faults being set.
correction
Replace the damaged oxygen sensor as instructed in ISTA. Program the vehicle using the latest version of ISTA/P.
Target integration (new): F020-14-11-501 or higher
Note that ISTA/P will automatically reprogram and code all programmable control modules that do not have the latest software.
      08-12-2015, 11:49 AM   #6
F82Steve
F82Steve's Avatar
Drives: 2015 BMW M4
cause
correction
Picked up my car yesterday. Two of the four sensors have now been replaced.
f80post
