09-07-2015, 02:00 AM | #1 |
Rep 1,405
Ok so I finally got around and installed the JB4, after 1:30 mins I was able to install the painful and not so easy tune. Now I have a drivetrain malfunction light on... I did not happen when I was driving it happen at cold start this afternoon, now my question is How on earth I reset the check engine light without the stupid USB cable that I just find out that I pretty much need or the dam thing is worth less !!! is there a map that sets the car back to stock and clears the code/s ?
Sorry guys I did lots of research with my phone no desktop here I am not home. I came from the Cobb platform with the hand held device and it was great to load maps and clear/read codes so far I am very disappointed with this JB4 it's NO easy at all to install all I keep thinking is when I have to go back to the dealership and having to do this all over again WHAT a PITA!! So again please help need to reset the drivetrain malfunction and I don't have the USB cable, dam thing is 800 dollars and no usb cable incredible !!! |
09-07-2015, 02:38 AM | #2 |
Rep 534
I miss my cobb tune. Easiest way to load maps. Plug it on the obd2 and done. Wish cobb sold a tune for the f80/82.
2016 m3
2012 yamaha r1 Last edited by V3rbatim; 09-07-2015 at 03:36 PM.. |
09-07-2015, 11:33 AM | #4 | |
Rep 3,249
1. You drive an F8x and cheaped out by not getting the $15 USB cable? Seriously? Come on. 2. Why would you buy the JB4 and expect to run E85 blends without the map switching capability? 3. How much E85 did you put in the car? 4. Map 0 is stock setting.
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold '18 /// M3 - Individual Imola/Black - Sold '15 /// M4 - YMB/SO - Sold '12 E92 ///M3 ZCP - AW/FR - Sold |
09-07-2015, 12:35 PM | #6 | |
Rep 1,405
09-07-2015, 12:40 PM | #7 | ||
Rep 1,405
I did switch to the correct map I put 4 gallons And the stock map is erasing the codes.. |
09-07-2015, 12:54 PM | #8 | |
Joint Chiefs of Staff
4922
Rep 115,999
Did you see the video on how to use the wheel controls? Change menu 4 to 1. Mike |
09-07-2015, 12:55 PM | #9 |
4922
Rep 115,999
09-07-2015, 01:39 PM | #10 |
Rep 1,405
09-07-2015, 03:59 PM | #12 | |
Rep 286
09-07-2015, 04:06 PM | #13 | |
BimmerPost Supporting Vendor
24350
Rep 191,156
Getting that cable will make your life a lot easier, i recommend you get one. Also double check that the Jb4 is installed correctly
09-07-2015, 05:37 PM | #14 |
4922
Rep 115,999
I'd also put the EWG connectors back to stock if installed. Those have been known to cause a startup code on certain JB4 firmware & DME versions. They are not used for any maps other than 6, 7, or 8 anyway. You should be on map 2 with your E85 mix.
Mike |
09-07-2015, 08:08 PM | #15 | |
Rep 1,405
09-08-2015, 10:19 AM | #16 |
4922
Rep 115,999
09-08-2015, 01:12 PM | #17 |
Rep 1,405
Problem solve, the car is running hard !!! We put the EWG connectors back to stock and the whole nightmare stop.
Thank you all for the input and again special thanks to Mike !! |
09-08-2015, 01:29 PM | #18 |
Rep 886
Did you update the JB4 firmware?? I was getting codes like you, then updated my firmware, it all stopped.
Now granted, I still inconsistently get them running map 6/7...
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
09-08-2015, 02:39 PM | #19 | |
4922
Rep 115,999
The EWG connectors should be kept off for most applications. Mike |
01-11-2016, 01:36 PM | #20 |
Rep 218
I have the same problem but I can't connect the jb4 to my PC. I might want to try this step too. But what is EWG connectors? And where it connected to?
01-11-2016, 01:54 PM | #21 |
4922
Rep 115,999
01-11-2016, 01:55 PM | #22 |
Rep 1,405
