09-24-2015, 02:13 PM | #1 |
Cruisin'
48
Rep 79
Tire Recommendation for 19x10 (f) 19x11 (r) setup.
Hi All,
I have tried : and could not find much about the info I needed. I hope you guys can chime in/give advice on what tires to use on the following: Wheels - Forgestar CF5V 19x10 +26 (f) 19x11 +29 (r) Scenario 1 - Setup with Swift Springs and the recommended tires are 275/30/19 (f) and 305/30/19 (r) on Hankook V12. Others in the forum have ran this and it had no issues with rubbing, etc. However, I read that V12s are considered Summer Tires? (correct me if I am wrong) and I was thinking of getting all-weather purpose tires instead. What other brand tires can I use which will not have rubbing? (I do not mind changing tire specs if necessary) Scenario 2 - Setup with stock suspension (non ZCP) what tires would be best for performance and making the car look beefier/good stance? I know typically having a beefier setup is easier on 18s squared (again open to changing tire specs and obtaining spacers if necessary). Thanks all in advanced. |
09-25-2015, 06:40 AM | #2 |
Rep 3,359
Before using the V12s, consider the Michelin PSAS3 (Pilot Sport All-Season 3). They will easily outperform the Hankooks in the dry as they have the dry grip that exceeds many other maker's summer performance tires. I'd run 295/30 on the rear if was me simply to keep the tire stagger down to 20mm, but it's probably not a big deal.
As to the other situation, running 10x18 ET25 all around with 275/35-18s is a typical setup; note however that this reduces the rear diameter by about 4%, so the speedo is optimistic by that amount. The other possibility (that takes away the ability to rotate tires of course) is to run 275/40s on the rear.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
09-25-2015, 10:07 AM | #3 |
Cruisin'
48
Rep 79
Thanks a lot for your input. I've read in here multiple times that V12's sidewalls are slimmer than other tires; therefore you can run them relatively wide.
Does anyone happen to know if 285-295/30 on PSS would be about the same (width wise) as running 305/30 on V12s? |
09-25-2015, 10:51 AM | #4 | |
Rep 3,979
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
10-16-2015, 08:35 AM | #5 | |
Rep 1,201
FWIW I ran a 18x11r+34 with Rivals in 315/30 and did not rub once I trimmed the inner wheel well liner back a bit. I could probably add 5mm to make it more flush with the fender, but it would probably rub slightly on bumps.
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
