11-29-2015, 02:38 PM | #1 |
gone baby gone
382
Rep 1,052
At what point do you really need upgraded charge pipes?
As the title says, at what point should one consider upgraded charge pipes?
JB4 Map 1 / 2? JB4 Map 7 / 8 (with meth)? A specific boost target? Any experience or opinions welcome. Personally I'm not looking to upgrade something that doesn't need to be done. |
11-29-2015, 03:21 PM | #2 |
Coder
574
Rep 1,550
You don't have to replace them but I've read that they've blow out even if you aren't running a tune.
I think it's a peace of mind to replace them. I plan to do so as well. |
11-29-2015, 06:17 PM | #3 | |
Joint Chiefs of Staff
4922
Rep 115,999
Mike |
11-29-2015, 06:45 PM | #5 |
Coder
574
Rep 1,550
11-29-2015, 07:56 PM | #6 |
Rep 2,809
The stock charge pipes are hit or miss. Some blow out on stock boost, others hold on for thousands of miles at 25+psi and are still fine. I personally wouldn't change my charge pipes until I blew my stock ones out. Maybe for some under-hood bling factor or meth, but other than that, I would rock the stockers until they go.
2016 BMW ///M4 ZCP - President / Master Calibrator | JordanTuned, LLC (www.jordan-tuned.com)
IG and Twitter: @CaryTheLabelGuy |
///BMW Junkie473.50 |
11-29-2015, 08:06 PM | #7 | |
Gone Fishin’
7318
Rep 12,125
11-29-2015, 08:26 PM | #8 |
Rep 2,809
Blown charge pipes won't necessarily leave you stranded. The engine will typically still run, just won't build any boost.
humbertin089.00 ///BMW Junkie473.50 |
11-29-2015, 08:30 PM | #9 | |
Rep 499
Drives: California Packet
Location: Left edge of browser window beneath 'join date' obvi
edit: of course you'll wanna pop that pipe back on ASAP especially in a dusty environment. Unfiltered air flowing through your IC, into your throttle body, and into the combustion chamber is, well, "less than ideal". |
11-29-2015, 08:35 PM | #10 | |
Gone Fishin’
7318
Rep 12,125
Thisisdave - the failures I have seen on the s55 split the plastic pipe and I think they cost ~$300. |
11-29-2015, 09:07 PM | #11 |
Rep 2,809
Well, the metal charge pipes will heat soak faster than the plastic ones. I really wouldn't worry about IAT too much as the difference will probably be negligible.
11-29-2015, 09:25 PM | #12 | |
gone baby gone
382
Rep 1,052
I plan to run in map 2, and really don't want to get stranded somewhere over a split plastic boost pipe. Any users who actually had this happen to them want to chime in?? |
11-29-2015, 09:47 PM | #13 | |
Rep 2,809
11-29-2015, 11:45 PM | #14 | |
Sameet
740
Rep 2,541
Drives: AY/B M4 '15
There's a local tuning company that have came out with their own set of Chargepipes including the pipe that connects from the intercooler to the throttle body. The meth bung is actually located on that pipe and not the Chargepipes. I may give this a try when it's released in two weeks. |
11-30-2015, 08:59 AM | #15 | |
Rep 2,809
I don't think your heat exchanger was bleed properly, TBH. You shouldn't be having these IATs. I can do pull after pull after pull on the stock heat exchanger and my IATs will barely climb over about 105deg in the Florida heat. During the run, IATs should actually slightly lower, then raise again and top out.
11-30-2015, 03:36 PM | #16 | ||
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
I'm inclined to agree here. I think he needs to bleed the exchanger again. |
11-30-2015, 04:32 PM | #17 |
BimmerPost Supporting Vendor
24332
Rep 191,093
Unfortunately there is not set point where CP will fail. I recommend to get a CP after your tune.
11-30-2015, 05:30 PM | #19 | |
Rep 982
11-30-2015, 05:30 PM | #20 |
Rep 3,051
Yes this is true but not only with ER but with another brand as well. ER is working on a solution for this as we speak.
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
11-30-2015, 05:32 PM | #21 |
Gone Fishin’
7318
Rep 12,125
11-30-2015, 05:51 PM | #22 |
Rep 2,809
I'm not saying it's a good idea to run around with blown charge pipes, the question was whether you'd be "stranded" if one blew out and the answer to that is NO. You won't be stranded. You'll be able to drive the car to a safe place. A few miles of unfiltered air won't hurt anything, trust me. I have tuned several very high powered cars that run ZERO filters and while I don't think it is smart in the log run, they seem to be fine.
