03-27-2016, 06:21 PM | #1 |
Melbourne Red | Carbon
31
Rep 106
30/265/19 R 30/295/19 will they fit?
Looking at HRE F101 19 x 9 front and 19 x10.5 stock suspension. Will this setup rub or effect handling dynamic in a negative way over the oem stock 19 in wheel and tire setup?
Also considering 255 in the front v. 265 Thanks in advance |
04-06-2016, 04:06 PM | #3 |
Rep 348
General rule for handling: The wider the tire in the rear vs the front causes understeer. If front is 255 and rear is 275 from the factory then increasing the rear size will cause more understeer and decreasing the front size will do the same. If you start running tires that don't fit your wheels (stretched tires or tires that are too fat) you'll start to change the performance of the tire and it gets complicated from there but you shouldn't have to worry about that. on the set up you listed i would recommend a 255 for the front and a 285/295 rear. You may see a bit more understeer than stock with this set up. As far as rubbing goes we need your offsets to tell.
