05-11-2016, 12:54 PM | #1 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Anyone ever try the GodSpeed MonoMax?
I'm probably going H&R, but was curious if anyone ever tried the GodSpeed MonoMax coilovers? They look pretty nice for the $, but reviews are scarce even for other cars, and I can't find anything on the Z4M.
One of you guys needs to try it, so you can tell me if it is any good. Salty
2006 BMW Z4M Interlagos Blue/Black
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete |
05-11-2016, 03:30 PM | #4 |
Rep 1,692
Salty, you are correct that there is not a lot of information on applications and BMW specific are non-existent.
They are $800 which is really cheap for a coilover. If you don't find a review for your application (E85 M Roadster) you should go with a brand that is well known, you have heard of them, positive product feedback exists and know where it was built. Don't ever skimp or cut corners on tires, brakes or suspension. |
05-11-2016, 05:18 PM | #5 | |
Rep 870
I'm still on the path toward the H&R coilovers. They will be only for street use. Thanks! Salty
05-11-2016, 07:11 PM | #7 |
Rep 1,692
They could be decent, nice or amazing for the price ($800).
Haven't decided what I am going to put on my car yet. Sounds like you are leaning towards H&R which is what I would do. Doesn't Ohlins have a setup? And if so it would be heavy $. |
05-11-2016, 07:29 PM | #8 |
Get off my lawn
938
Rep 1,162
Do your homework and pick a solution befitting of your needs. An $800 coilover setup on a ~$30K (50K MSRP) is a cheap and ugly solution likely to leave you with unforgiving/harsh ride quality and possibly other issues. In the event you upgrade down the line you'll still be out $800 + installation and have a set of no-name coilovers to give away.
Plenty of options out there besides the track junkie Ground Control/JRZ/KW - check out Status Gruppe SRS, H&R (as you mentioned), Fortune Auto, etc. A used higher end setup might stave off some of the sticker shock as well! |
05-12-2016, 07:48 AM | #9 | |
Rep 870
Salty
05-12-2016, 01:11 PM | #10 |
Get off my lawn
938
Rep 1,162
http://forum.e46fanatics.com/showthread.php?t=967719
http://www.m3forum.net/m3forum/showthread.php?t=487770 Seems promising, an upgrade to swift springs is a no brainer (great company!) and camber plates as an option. |
05-12-2016, 01:17 PM | #11 | |
Rep 870
For strictly street use, I wouldn't really need camber plates, would I? I don't plan on slamming the car or anything like that. My plan is simply to put on 19" wheels with PSS tires and drop the car an inch or so. I had also planned to purchase the rear shock mounts made by Rogue Engineering. It looks like these come with RSMs, but would there still be an advantage to going with the Rogue set? Salty
05-12-2016, 01:47 PM | #12 |
Get off my lawn
938
Rep 1,162
Your plan of action is best, it's likely Mike (the owner) has some experience with Z4M customers and can recommend a good setup. You should be fine without camber plates unless you are running overly aggressive width/offsets.
I am not as familiar with the rogue product, but my assessment is that it provides an extra level of reinforcement not present in most OEM or coiver E85/E86 setups. |
05-14-2016, 07:15 AM | #13 |
Rep 870
I am still debating the coilovers, but have it narrowed down to either the Status Gruppe or my original choice of the H&R. Since the H&R use a progressive spring and the SGT use a linear spring, the H&R may really be the better choice for my street-only use, even though the SGT seem to be as good or better quality coilovers and have more adjustability.
There is one final factor and that is cost. The Status Gruppe are currently on sale for $1150 and I have a discount code that takes it to under $1000. They even come with adjustable end links and have a lifetime warranty. * Machined aluminum RSMs (would replace with Rogue RSM) * 18 way adjustable dampening (combination of rebound and compression) * Monotube gas charge dampers * High strength anodized aluminum alloy and powder coated steel components * Full length height adjustment with separate settings for damper force and spring pre-tension * Linear race springs front / rear (B&G or upgrade to Swift - Cold wound from high tensile chromium silicone wire) * SGT Adjustable Sway bar endlinks included Decisions, decisions! Salty
