07-15-2016, 01:03 PM | #1 |
BimmerPost Supporting Vendor
9601
Rep 10,891
IND | Project Kics Iconix Racing Lug Nut Set
IND is proud to introduce the Project Kics Iconix Racing Lug Nut Set! Made out of chromoly steel 435, the set comes in a pack of 16 with 4 wheel locks. The R40 unique feature (patent pending) of this six-sided, hexagonal lug nut is that each lug consist of 2 pieces, where the top of the lugs spin freely from the tapered centering ring. This ensures a much tighter and precise hold than traditional lug nuts. It also minimizes the chances of scratching your wheels. Made of lightweight composite materials, these open ended lugs fit on both standard studs as well as extended studs. The entire set weighs just under 2 lbs! Highly recommended for both street and track enthusiasts. Note: Compatible with extended studs when cap is removed. In order to run the colored end caps, 54 mm studs are required. This thread will be updated next week with the necessary 54 mm Stud. The kits we offer are compatible with M14x1.25 pattern only. Project Kics Iconix Racing Lug Nut Set: $330.00 The Project Kics Iconix Racing Lug Nut Set may be viewed at the following link to our online store: https://ind-distribution.com/product?sku=R40ICONIX14MM Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com Read more about IND and our family of brands here!
07-22-2016, 03:19 PM | #2 |
9601
Rep 10,891
The 54mm studs for the kit are now in stock! Product link has been updated to reflect the availability of the studs.
11-15-2016, 09:40 AM | #3 |
9601
Rep 10,891
02-14-2018, 05:11 PM | #5 |
9601
Rep 10,891
04-02-2018, 07:24 AM | #6 |
Rep 231
Thinking of getting these soooo much for my incoming M3 (along with a stud conversion kit and some spacers). However I'd love to see some installed pics before I spend hard earned money on essentially 20 bolts.
Just can't decide between colors and what they'll look like on the black 666M ZCP wheels. Does anyone here have any pics of the capless R40s in Black or Neo-Chrome on the black ZCP wheels? |
11-21-2018, 12:55 PM | #7 |
driver
820
Rep 781
Thx IND
IND-Distribution9600.50 |
11-30-2018, 05:11 PM | #8 |
9601
Rep 10,891
coldsteelrain820.00 |
12-18-2018, 08:47 AM | #10 |
9601
Rep 10,891
10-28-2019, 02:46 PM | #11 |
Proud Father of a Univ. of Mich. Chemical Engineer
193
Rep 643
Hi there, I purchased these Project Kics Iconix Racing Lugs in Blue. They are great, I love them on my 19" FI-Rs. My question is... do you carry Center Caps for the BBS FI-Rs in Blue? It looks like the ones pictured in your catalog are a different part Number than the black ones I currrently own which are 09.24.467. Thanks, Jeff
Current: '16 F82 M4, Avus Blue, DCT, BavSound, Winters-19" 437s, Summers-19” BBS FI-Rs Past: '13 E92 M3-Jet Black, '12 E92 335is-Space Gray, '06 E90 330i-Jet Black, '99 E46-328i-Green, '96 E36 328is-Jet Black
11-01-2019, 01:28 PM | #12 | |
1771
Rep 7,653
03-20-2020, 04:24 PM | #13 |
9601
Rep 10,891
