08-27-2016, 09:12 PM | #1 |
Daily Dose of Reality
63
Rep 157
255/35/19 RE-11 rubbing bad up front
So I just noticed my 255/35/19 RE11s up front on my SDC F14 Forgestar 9.5 inch wheels are rubbing pretty good.
They rub so bad on one turn that the bumper moves a little bit!! Help me pick out a new tire size and new tire. Don't think I wanna go AD08R, a bit too much for the street. Maybe the Kuhmo PS91 in 275/30/19 square??
2008 E92 M3 - loaded and mint
2007 E60 M5 - black on black and mint 2014 BE GTR - quadruple digits 2003 Quad Cab Silverado 1500 - Beast truck 2013 Audi RS5 - the "shared" DD |
08-27-2016, 09:37 PM | #4 |
F15 daddymobile
2352
Rep 3,516
does it really? 30/35 is the ratio... so with a wider tire a 30 sidewall isn't entirely shorter.
Google tire size calculator. that way you can really see the dimensions/measurements |
08-27-2016, 10:25 PM | #7 | |
Rep 1,174
08-27-2016, 10:42 PM | #8 |
Güdentyte
1165
Rep 1,202
Tire size is fine, pretty standard. It's the offset or raise your ride height
CURRENT - 991 GT3 | Future Classic 1M | Model 3 | T4R TRD Pro Lime Rush
SOLD - MB M2 CS | SMB F80 M3 CS | E90 M3 | E90 335i | E46 M3 Vert | E39 M5 | E34 525i |
08-27-2016, 10:57 PM | #9 |
Stop the hate, get a V8
3853
Rep 8,625
The sidewall is an aspect ratio, meaning it is a relative number, not absolute.
275/30R19 means "the sidewall is 30% of the tire's 275mm width" (82.5mm) 255/35R19 means "the sidewall is 35% of the tire's 255 mm width" (89.25mm) However, you also have more tire sticking into the wheel well now, so if you're rubbing, it might make things even worse. Without posting the wheel offset and suspension setup, everything is going to be a guess. Also, posting this in the wrong forum won't help get you answers quickly. You don't want AD08Rs for the street. Very poor ride quality (I know from experience) and you won't even be able to use 100% of its performance on public roads anyway. Go for something more reasonable like the Pilot Super Sport, Potenza S04, Conti DW, etc.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
08-27-2016, 11:27 PM | #10 |
63
Rep 157
They are Foregatar 19x9.5 in front I believe 17 offset!
Lowered on TCK DA coilovers with a one inch gap up front! I was thinking about the Ecsta PS91 which apparently is an almost exact copy of the PSS with 1/2 the price... Take a read on them! Maybe I'll do 265/30/19 up front and 285/30/19 out back. |
08-28-2016, 08:04 AM | #11 |
Rep 5,396
That's not going to fix anything
That is a very aggressive offset. Stock zcp front offset is 19x9 et 31. You have 19x9.5 et17. This is a 21.5mm difference, equivalent to running a 21.5mm spacer on the oem zcp wheel which will never fit without rubbing Maybe you can run some super stretched tires, but I doubt that will fit. You need to take some actual measurements and not randomly guess. Also, you probably need to raise your car up. |
08-28-2016, 10:54 AM | #13 |
3853
Rep 8,625
Or just sell those wheels + tires and buy a set that fits. That width and offset is not a good fit for the M3.
Rubbing that severely could cause a dangerous blowout. Tires are a safety item.
08-28-2016, 12:15 PM | #14 | |
Rep 5,396
It's more likely how much they stick out. You need to raise the car, run more camber, or get new wheels. Tires won't do much imo. |
08-28-2016, 04:54 PM | #16 |
Rep 556
I ran a RE-11 265/35/19 up front 19x9 with offset of 25 very little rub
I am running 245/35/19 with same rim little rub. Probably going to back to 265 once the 245 wears down. I also have more camber on now then before and it may rub not sure, yet. hope that helps. |
08-28-2016, 05:08 PM | #17 | |
Rep 3,979
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
08-30-2016, 10:57 AM | #19 |
Rep 1,171
I'm running F14 SDCs 9.5" ET18 up front with 265/30/19 PSS and i'm lowered on KW HAS with no rubbing at all. When people say it's too aggressive... Don't listen.
08-30-2016, 12:03 PM | #20 | |
Rep 3,979
Dave
08-30-2016, 12:05 PM | #21 | |
3853
Rep 8,625
It's a very aggressive tire for a street car. Unless you are tracking it often and don't want to swap your wheels out, I think it's overkill. Something milder like the PSS or S04 would be more than adequate.
08-30-2016, 12:19 PM | #22 |
63
Rep 157
Just got a set of 275/30/19 Exsta PS91 for front and 295/30/19 for rear!
Will comment back on how they work
