09-13-2016, 02:19 PM | #1 |
BimmerPost Supporting Vendor
975
Rep 13,781
ACM | Active Auto Test Pipes
We are proud to announce we are currently stocking the Active Auto Test Pipes!
-LOOKING TO CREATE SOME BOLT-ON HORSEPOWER AT AN AFFORDABLE PRICE. THE ACTIVE AUTOWERKE TEST PIPE WILL DO THIS AND A LOT MORE. RELATIVELY EASY TO INSTALL IF YOU KNOW HOW TO USE A TAPE MEASURE AND A AXE-SAW MAKES INSTALLING THE TEST PIPE A COOL WEEK-END PROJECT. Made of 100% Brushed stainless steel it bolts right up to the factory exhaust headers and provides a tight seal with the new set of TORCA clamps that are also included with the Test Pipe kit. The Test Pipes features a ** Z STYLE ** expansion slot at the rear of the Test Pipe to provide that tight exhaust gas seal with the help of the European designed TORCA style clamps. These clamps are strong and robust with the beefiest in band width, a 14 mm shank bolt to provide the highest degree of load when tightened. An additional support brace is also provided (just like the factory) to relieve the load and stress if installed. The gains in horsepower is achieved through the free flowing design of the Test Pipes and the replacing of the factory primary catalytic converters by removing the restrictions of the OEM cats. With guaranteed HP gains this application is a must for the track user . NOTE: THIS IS FOR OFF ROAD USE ONLY AND IS DESIGNATED FOR RACING PURPOSES ONLY AND NOT INTENDED TO BE INSTALLED OR USED ON PUBLIC HIGHWAYS. Like every Active Autowerke product you can expect only the best in fit, finish and performance. FEATURES: Easy BMW horsepower gains All stainless steel construction with a brushed finish Precise and tight seal to factory headers Beefy, support brace integrated Z STYLE expansion slot for a tight seal Industry standard TORCA Clamps included Complete instructions included Limited 2 Year Warranty included Alex Contact through PM or give a call (201)-666-3500 Alex@Autocouturemotoring.com Come see us at- 15-01 Pollitt Dr Unit 8A Fair Lawn, NJ 07410 |
