11-03-2016, 10:52 PM | #1 |
Rep 1,239
Square setups
Is there any particular reason why people run square setup vs. Staggered? I've been waiting for a staggered setup but only squares come up.
A job is nothing but work.
11-04-2016, 11:00 AM | #2 |
Rep 328
You can rotate tires front to back is the primary reason on street car. Also, from a style perspective running a wider wheel up front with a deeper dish looks better.
I'll let others explain why they do it for the track. |
11-04-2016, 11:06 AM | #3 |
Rep 1,049
Mostly to allow for tire rotation.
It also counteracts understeer giving you a more neutral to oversteering balance. Not sure if that really works though unless you turn traction control all the way off. |
11-04-2016, 12:02 PM | #5 |
Rep 131
11-04-2016, 12:22 PM | #6 | |
Rep 1,256
Drives: '08 M3, '09 328xi Sport Wagon
A square setup would probably feel decent on a tighter slower speed track, but at a track like Mosport with average corner speeds being around 100mph, the car is not stable.
11-04-2016, 01:01 PM | #7 | |
Rep 131
You would certainly set up your car differently for a higher speed track. |
11-04-2016, 06:30 PM | #8 | |
Rep 818
You could also run slightly lower pressures in the rear to add a little more grip in the rear as well, right? |
11-04-2016, 06:34 PM | #9 | |
Rep 1,256
Would it help a little bit? Yeah sure at quite high speeds. |
11-04-2016, 08:50 PM | #10 |
Rep 875
