04-06-2017, 04:43 PM | #1 |
Rep 210
Coolant smell on start up
I have a question to determine if it's a problem or not.
I have a 2013 M5 with 30,000 miles with Dinan Stage 1. I get a coolant smell on the first cold start of every day. It's a smell that dissipates after I leave for and doesn't seem to return until the next cold start the next day. Do I have some sort of problem? I have not noticed any leaks on the ground nor in the engine bay. I also have noticed that the coolant levels for the turbos seem to always be low. Any advice you can provide would be helpful. |
04-06-2017, 05:32 PM | #2 |
Rep 97
there was a recall for the coolant lines some time ago. The heat from the engine was expanding the fittings/hoses and causeing coolant to leak. Happened to me, went to BMW and they fixed and covered it under warranty.
04-06-2017, 06:14 PM | #4 |
Rep 1,107
04-06-2017, 07:32 PM | #6 |
Rep 210
Did they wrap the coolant lines for the fix like the others suggested?
04-06-2017, 08:46 PM | #8 |
Rep 210
Okay, is this what is should look like with the coolant lines wrapped? With those that have had this fix, do you get a slight smell of coolant at cold start?
04-07-2017, 01:48 PM | #9 |
Rep 1,107
I posted the thread with pictures of the recall done. Yes, my car has had the recall and that's what it looks like. No, I do not get any coolant smell.
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
04-07-2017, 03:49 PM | #10 |
Rep 210
Okay, thanks for responding. I must have a small leak somewhere and will get it looked at since I am still under warranty.
04-07-2017, 03:52 PM | #11 | |
Rep 1,107
04-07-2017, 04:35 PM | #12 |
Rep 210
Thank you. I will have them look at it on Monday next week. I will let you know what they have to say. Love this beast
04-07-2017, 08:30 PM | #13 |
Rep 97
04-18-2017, 03:50 PM | #14 |
Rep 210
Okay, I am reporting back from my original post. Brought my vehicle in to get the front and rear strut and spring assemblies replaced per SIB 330113.
At the same time I had them investigate why I am smelling coolant at cold starts. They pressure tested the system and found no leaks. The results of the test were 17-00-509(2) 17-11-48-00 PS. I have no idea what that means. They told me I must be smelling something other than coolant at cold start. |
04-18-2017, 04:16 PM | #15 | |
Rep 814
Formally known as BMWM3NYC
04-18-2017, 04:29 PM | #16 | |
Rep 210
I never smelled it in my e60 M5 but crazier things have happened. |
