M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      06-21-2017, 04:35 PM   #1
Jhenka
Jhenka's Avatar
Drives: 2015 M5
2015 BMW M5  [0.00]
Advice for the drag strip
Hey so I'm hitting the drag strip for the first time in my M5 tonight.
Mods: Jb4 Bcm, Dp's
Tires: 295 cup2's
Fuel: Had about 3 gallons of 93 and going to add 5 gallons of VP Ms100
Here's the thing I'm not sure what map to run, i usually run map 2 but with the race gas not sure if its ideal or if theres a different map i should be in.
Any advice would be greatly appreciated!!
      06-21-2017, 05:50 PM   #2
somer
Drives: F10 M5 CP
Either way post up your results!
      06-21-2017, 07:22 PM   #3
Northern X5M
Northern X5M's Avatar
Drives: 2014 Tanzanite Blue M5
I'm interested to see how your SC2's 60 foot.
You might want to consider airing them down to 20-25 psi if you find you are not hooking.
2014 ///M5 CP Tanzanite Blue/Cohiba - 11.15 @ 128.8 & 1.84 60' (2150' DA) - BPM Tune - MSR Intake - SSP DCT - SS DPs & HFC Mid Pipes/X-Over - E Race Muffs - 19" MT DRs... On to a new home.
      06-22-2017, 06:07 AM   #4
evilb
evilb's Avatar
Drives: McLaren MSO 570S, 18 Raptor
I've heard from some of the fastest that you'll probably want to run a tank or two of gas with the higher octane mix to let the car adapt first.
2016 McLaren MSO 570S | 2018 Ford Raptor | @alpha7even
      06-22-2017, 12:37 PM   #5
srtoad4
Drives: 2014 CP M5 / 2016 SRT Jeep
So...how'd you do OP?
14 Space Grey CP M5 / CCB / Exec / etc
BMS Stage 1 / Charcoal Delete / K&Ns / Catless OEM DP & Borla S-Type Catback
      06-22-2017, 01:12 PM   #6
ARC550
Drives: M3, X5, 720s, X5, 750xi
Mods: Jb4 Bcm, Dp's
Tires: 305 cup2's
Check my thread.
Also, map 2
If you don't have backend map 7/6 will not work
      06-22-2017, 01:59 PM   #7
f10eugene
Drives: 2013 BMW m5
Need DR's if you want to hook off the line. Those tires will def still spin. So I would go 50% throttle off the line then stomp it. LC is useless. Suspension should be comfort or sport. Everything else sport plus. Good luck!
      07-30-2017, 02:54 PM   #8
Jhenka
Jhenka's Avatar
Drives: 2015 M5
2015 BMW M5  [0.00]
Mods: Jb4 Bcm, Dp's
Tires: 305 cup2's
Check my thread.
Also, map 2
Thank Arc! I actually read through your review, good stuff helped a lot. I did a bunch of runs today at Bimmerfest East (Englishtown). Track prep was alright, they wouldn't let me go around the water gap so I had to attempt a solid burnout every run. It was around 87 today so a bit hot but overall it was a good day.
Tires: SC2's 27psi
Mods: DP, JB4 (Map2)
      07-30-2017, 05:10 PM   #9
ARC550
Mods: Jb4 Bcm, Dp's
Tires: 305 cup2's
Check my thread.
Also, map 2
Tires: SC2's 27psi
Yea your map 2 is not runing right lol... put map 1 it will Be faster lol
Your 1/8th Mph is slow for map 2 and trap also.
Try map 1 your clutch will be thankful and your times and car will be faster and more consistent.
      07-30-2017, 06:44 PM   #10
Jhenka
Jhenka's Avatar
Drives: 2015 M5
2015 BMW M5  [0.00]
Mods: Jb4 Bcm, Dp's
Tires: 305 cup2's
Check my thread.
Also, map 2
Tires: SC2's 27psi
As I said I couldn't get the moisture off the tires I spun a bit. How can you tell map 2 was off aside from that?
      07-30-2017, 09:36 PM   #11
TrevorM3
Drives: 6.3 AMG
are some tracks like that? won't let you go around water box? thats gay
      07-30-2017, 11:55 PM   #12
ARC550
Mods: Jb4 Bcm, Dp's
Tires: 305 cup2's
Check my thread.
Also, map 2
Tires: SC2's 27psi
You don't have combo package and map2 without Backend will wear your clutch hard and could increase clutch slip.
I ran trap times of 127-129 on Map 1 and when I did map 2 I did 124-126(just like you)
Map2 is 22-23psi
Map 1 is 21 psi and study as hell! Trust me.
Go back to track and you will see or if you have Vbox log it
      07-31-2017, 12:08 AM   #13
Jhenka
Jhenka's Avatar
Drives: 2015 M5
2015 BMW M5  [0.00]
Mods: Jb4 Bcm, Dp's
Tires: 305 cup2's
Check my thread.
Also, map 2
Tires: SC2's 27psi
Map2 is 22-23psi
Thanks for the heads up, I'll try it out on Wednesday and post logs here.
m5post
