05-08-2008, 10:10 AM | #1 |
Rep 1,429
Low cost track wheels?
I need track wheels. I was considering buying nice aftermarket wheels and using the OEM 19s as my track wheels, but I think it would be a better idea to buy some 18" track wheels considering 18" rubber is a lot cheaper than 19" and there's more available. So what are some fairly inexpensive 18" wheels? Light weight would be even better, but I'm sure that's going to cost more.
05-08-2008, 10:51 AM | #2 |
Rep 7,887
I went for these wheels.They cost $265 in CDN $'s.I went for 8.5 30p & 9.5's 25p x18
http://www.beyernwheels.com/bmw_whee...n_typemesh.php and these tires http://www.toyor888.net/racing/index.htm 255/35 18 & 265/35 18 The wheels are here,but the tires are on backorder and the 1st trackday is this weekend |
05-08-2008, 11:30 PM | #3 |
Rep 5,448
I would go with 18's - casue of the tires choices. I will likley go with the BFG G-forece R tires/ i am hoping my extra set of e46 M3 wheels with r tires will fit (have som eold SSR's on them) - they are not light but hey were really cheap - plus i kept them when I sold the e46.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
05-09-2008, 02:47 AM | #4 |
Rep 6,926
Track wheels should be no bigger than 18's.
A great wheel used by many E46 M3 owners for tracking, is the TRMortorsport MT1. You can find them on Tirerack.com. 18x8.5 F and 18x9.5 R or 18x10 R Only 18.5 lbs per wheel. ~$300 each |
05-11-2008, 01:53 PM | #5 |
Rep 5,448
the e46 seemed best with a square set up such as 265's at all corners. I wonder if the e92 will be the same.
06-11-2008, 08:36 PM | #6 |
Rep 492
OK, my car's due into PDC in about a month, so it's time to start planning track wheels/tires.
Has anyone tracked their new M3 with any of the wheel/tire combo's listed in the responses above? Any consensus on staggered 245 F /265 R vs. square 265 F /265 R? I'm definitely going with 18's, and have uses Proxes Ra-1 and Nitto NT-01's on my e46 330i, but might try r888s the for the first set on the new M3. Lemme know your thoughts.
E90 M3 Sedan
06-13-2008, 12:00 AM | #7 |
Rep 419
Here are some of those TRM wheels some one else posted... You could always get some BBS CH's but they are not really inexpensive.
06-14-2008, 02:07 PM | #8 | |
Rep 648
06-21-2008, 02:00 AM | #9 | |
Rep 5,448
check out the new BFG R1 tire I think they have a 265.
06-22-2008, 06:34 PM | #10 |
Rep 648
Is anyone going to run the same size wheels/tires at all four corners? 8.5" with 245 40 18 or 9.5" with 265/275 30 18? Or custom make 9.0" with 255/265/275. There will be some clearance issues in the front depending on offset. Non staggered is best bet for longevity at a roadcourse. R compound tires are usually 10-20mm wider than street tires in the same size.
06-22-2008, 07:29 PM | #11 | |
Rep 5,448
I hope to run my four stock rear e46 M3 wheels with 265's all around (currently Dunlop SSR's). since they are left over from my e46 thats about as cheap as you can get. I'll report when I get a chance to see if they fit. plan on trying on the mini spare also.
06-23-2008, 01:59 AM | #12 |
Rep 648
The new Advan wheel in the 9.0" ET22 will work great and should fit without a problem in doing the math. Wonder what the price is? If the stock 9.5" ET 23 is used on the front, the clearance will be 7mm closer to the strut and 19mm closer to the outside fender lip. A 9.0" ET 22 will be 1mm farther away from the strut and 13mm closer to the fender lip. That is roughly 1/2" to the outside which should work. Can't want for one of you to try the stock rear wheel on the front and report back. I may want to run a 255 instead of a 265 at all four corners. The 255 will have less sidewall flex on a 9.0 than the 265 which should negate any advantage over the larger size if you are running a 9.0" rim. Of course if the 9.5" fit, than the 265 is a better choice and maybe due to tire offerings a 275 could be run. Does anyone know what the Dinan wheel offsets are for comparison? They seem to fit a rather large combo on the E9x chassis with success.
06-23-2008, 03:08 AM | #13 |
BimmerPost Supporting Vendor
1767
Rep 7,652
The BBS CH and BBS RXII are great track wheels.
PM me if you need more info... Here is a picture of the RXII wheel Here is one of the RG-R
06-23-2008, 10:56 AM | #15 | |
Rep 1,429
As great as they are, I don't think you caught the *low cost* part...
06-23-2008, 10:57 AM | #16 |
Rep 1,429
I thought about doing the same. I've been looking at E46 M3 wheels because they can be found really cheap. Let me know how they work out.
06-23-2008, 11:30 AM | #17 |
Rep 1,436
Drives: E70 X5 M
LOL, that's fo sho!
'13 E70 S63B44A
'17 95B GTS |
06-23-2008, 12:08 PM | #18 |
Rep 17,017
I'd go with a set of 18" CSL Style Wheels which are affordable at $749 for the set in staggered and are relatively lightweight.
06-23-2008, 03:29 PM | #19 | |
Rep 1,436
Drives: E70 X5 M
'13 E70 S63B44A
'17 95B GTS |
06-23-2008, 06:52 PM | #20 |
Rep 1,429
+1 on all of that
06-23-2008, 11:21 PM | #21 |
Rep 6,926
06-23-2008, 11:52 PM | #22 | |
Rep 17,017
These are about 24-25lbs per wheel and they are hub centric. |
