10-08-2018, 12:26 PM | #1 |
Rep 12
rear diff bushing crack
Hello, I went through forum but could not find this issue, hope its not been covered already.
When having the car on lift, I noticed a leakage on rear subframe near rear diff bushing mount. Under closer inspection, cracks were found on rear diff bushing, bushing is probably filled with hydraulic oil for vibration dampening, maybe that is the reason for oil leakage. As the car has rear subframe bolted directly to chassis there must be high loads on the bushing and unfortunately at the rear differential is mounted only on one bushing. Is there a reliable solution to prevent this, e.g. Powerflex bushing kit or conversion bracket to double mounted rear differential ? I am not sure if the bracket will fit through diff locking servomotor. Any input appreciated. |
10-08-2018, 01:31 PM | #2 |
Rep 444
Historically bmw diffs had one front mount and two rears. F8x platform has flipped that with two front mounts and one rear. Presumably, this would reduce the "torquing" effect of the diff relative to the subframe under load which was usually rough on the single front mounts.
Based on your pics as well as the price of the lone rear mount i suspect you're correct that it's fluid filled and replacing will probably stink given the location unless there are some creative special service tools bmw has employed for this one... check ista for details on that one. I'd also be included to talk to bimmerworld, turner, maxpsi etc to see failure rates on the bushings for track, strip, or big power cars. Wondering if you might have just had a bad bushing so swap it like for like and go forward. Might also explain why your search didn't produce any similar experiences on the forum. The knock on the higher durometer bushings is diff noise/whine entering the cabin. I'm guessing that's the major reason for the fluid filled factory spec part. If you go with poly expect to be annoyed for a street car. Not a lot of help on this one but hopefully there's some worthwhile council here. |
10-08-2018, 02:50 PM | #4 | |
Rep 475
papasmurf_m3454.50 |
01-08-2019, 06:48 PM | #6 |
Lost Motorcyclist
167
Rep 379
I noticed mine cracked also, curious to see what path you go.
01-12-2019, 08:00 PM | #7 |
Rep 120
Mine cracked as well. BMW replaced it under warranty. This was a while ago, but I wanna say it would have been ~$800 if not covered.
I only noticed it due to vibration in the steering wheel under acceleration. |
papasmurf_m3454.50 theweebabySeamus380.50 |
02-14-2019, 12:01 AM | #8 |
Rep 1,183
did you do the front ones as well as the back one? Mines cracked at 37k miles and now its got a crack on both sides. I saw there is one for the back and few in the front.
02-14-2019, 12:22 AM | #9 | |
Rep 475
Greg FEightytwo1312.50 jacobe92619.00 |
02-14-2019, 12:52 AM | #10 | ||
Rep 1,183
papasmurf_m3454.50 jacobe92619.00 |
02-14-2019, 12:31 PM | #11 | |||
Rep 475
02-14-2019, 08:12 PM | #12 |
Rep 674
That's pretty lame. I'm sure this issue is fairly isolated but every part on these cars should hold a lot more than that without issues given that's what it was designed for.
02-15-2019, 12:07 AM | #13 | |
Rep 475
02-15-2019, 03:59 AM | #14 | |
Rep 374
What shall i buy for my next track toy
04-04-2019, 04:54 PM | #17 |
Rep 90
Has anyone done this themselves? I’m trying to figure out if it’s possible to replace the bushing without dropping the whole diff. Dealing with the driveshaft seems like a PITA. Lots of special tools needed.
04-05-2019, 03:51 AM | #18 |
Rep 475
04-05-2019, 08:29 AM | #20 |
Rep 475
04-06-2019, 06:25 PM | #21 |
#LSBM3
1423
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
Might as well do a front diff bushings if you're at it.
/// M3 |
09-22-2019, 05:20 PM | #22 |
Rep 71
42k miles and cracking, was noticed on my last inspection.
Not sure if I'm going to tackle this switch of these busing or not. Not sure if they are pressed into the diff or will they pull out with a screwdriver and a little patience. Any brave soldiers already tackle this? |
