03-31-2019, 08:07 PM | #1 |
Rep 61
Crank Bolt Locking
Has anyone tried to solve the crank hub issue by locking the bolt with this washer? If the problem is with the bolt backing out, this should work.
https://www.nord-lock.com/nord-lock/products/washers/ |
03-31-2019, 08:25 PM | #2 |
Rep 3,820
Crank bolt capture is a cheap and easily fix for the bolt backing out and doesn't require removing the bolt, which adds considerable complexity. In addition, there have been several reports of the hub spinning with the bolt still tight.
04-01-2019, 07:25 PM | #4 |
Rep 466
It is assumed that the bolt was still at full tightness. Nobody has tested, if there even is a method to test the bolt torque before removal. It's a stretch bolt. A static bolt cold be easily checked. I don't think anybody has ever bothered to measure the bolt torque before removal. Other than the "it felt tight" on removal.
04-01-2019, 10:47 PM | #5 | |
Rep 3,820
overlook637247.00 |
