04-18-2019, 09:51 PM | #1 |
Rep 39
Bootmod3 Cold Start Issue
Hi guys,
So I pulled the plug and flashed my car with the bootmod3 stage 0+ GTS tune. Paired with the m performance exhaust, the tune transformed the way the car sounds. But leaving work the next day, I noticed an issue on cold start. The car would rev up then down (almost as if it was about to stall). I immediately turned it back off and on and it was fine. I flashed it to the CS tune and noticed the same thing happen today while leaving work (+4 degrees). Not sure if this is relevant, but this does not happen during all cold starts. Its completely fine in the mornings. I have only had it happen these two times so far (both after work, car is sitting for 8 hours). Can anyone chime in? I don't have the cold start delete. Thank you |
04-19-2019, 07:15 AM | #6 |
Rep 39
Car only has 8000kms and stock intakes. It only started doing this after the tune. Do you think it could still be the MAF? Is there some sort of "learning period" for the car that I should expect after the tune?
04-19-2019, 11:28 AM | #7 |
Rep 24
04-23-2019, 03:42 PM | #11 |
Rep 39
Update: Bootmod3 customer service replied to me and suggested to try reset adaptations under diagnostics. This seems to have worked and the car hasn't done this since.
04-24-2019, 03:57 PM | #12 |
BimmerPost Supporting Vendor
24348
Rep 191,145
