07-19-2019, 07:47 AM | #1 |
Rep 137
OEM M5/M6 brakes
Hi All
How do you guys find the braking performance at high speed, from 120mph to 20mph/complete stop? I don’t think the oem brakes inspire much confidence when braking at high speed. Also, do you know if the F series M6 use a different brake fluid spec when compared to other BMW cars? Or is it the same brake fluid spec for all BMWs? Thank you for all the advice |
07-19-2019, 09:11 AM | #2 | |
Rep 1,847
07-19-2019, 06:38 PM | #6 |
Rep 137
07-20-2019, 04:30 AM | #7 |
Rep 19,809
If your still not happy with the brakes I suggest a rolling road brake test to see if the brake balance is uniform for all four wheels and observing that no fluid of any kind is being transferred onto the discs.
Are there any flat spots on discs with juddering at high speed when b/pedal is pressed but not connected to when ABS is working. |
07-20-2019, 03:19 PM | #8 | |
Rep 137
Thanks for your advice. Do you know where in the UK, can I do this rolling Road brake test? Car recently passed its Mot with no issues. No flat spots or juddering. I was just going at high speed recently and braked quite hard coming to a roundabout. The car did stopped eventually, but there was a point, where I was wondering if this was "the end" for me as I was pressing the pedal relatively hard but the "slowing down" didn't match the rate I was pressing the pedal (if that makes sense). |
07-20-2019, 04:04 PM | #9 | |
Rep 19,809
In that case I would take the car back to BMW where they changed the pads and tell them the pads are not working to optimum performance, parts and work are guaranteed.It's not unknown to get a rogue set of pads even for an M which may be your problem. GL with that. *Have them check the Brake Booster also and to check for contaminated brake fluid. Last edited by M5Rick; 07-20-2019 at 04:29 PM.. |
07-22-2019, 03:42 PM | #11 | ||
Rep 385
I have also noticed that the stock pads and rotors work better warm, as hard braking has much more bite on a second application within a few seconds of a first. So sometimes when I am really going at it fast on back roads I will brake occasionally just to keep the brakes warm. I have never driven this car on a track so I can only guess that the brakes get plenty hot and stay hot. |
07-23-2019, 07:26 AM | #13 | |
Rep 19,809
07-23-2019, 03:15 PM | #14 |
Rep 385
07-24-2019, 05:08 AM | #15 |
Rep 687
