04-06-2020, 10:01 PM | #3 |
BimmerPost Supporting Vendor
8265
Rep 18,849
Drives: BMW
Has to be performed in ISTA or autologic.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
04-06-2020, 11:25 PM | #5 |
Rep 815
I’m having problems with high WGDC, surging and boost oscillations with my Pure Stage 2+ turbos. Have reached out to Pure who recommend “actuator calibration” to troubleshoot
04-06-2020, 11:59 PM | #6 |
Rep 844
Have you tried swapping the WG actuators from left bank to right bank or with a different set? It might be something as simple as needing a replacement. Just a thought.
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+ |
04-07-2020, 12:00 AM | #7 |
Rep 98
I'm having the same issue with my PS2+. Called all over town and no shops provide this ISTA calibration. I've also contacted Pures with no solution.
04-07-2020, 12:09 AM | #8 | |
Rep 815
04-07-2020, 10:34 AM | #10 |
Rep 107
This is how I understood it:
When you turn your ignition on, your dme cycles the wastegate actuator between fully open and fully closed. It knows the voltage for both extremes and can adjust the opening/closing of the wastegate accordingly. I have used ISTA to set the linkage length correctly. Basically ISTA runs a test and tells you to increase or decrease the linkage length accordingly. If you not out of this specification (drivetrain error), then I'm not sure how this calibration can help? |
04-07-2020, 10:47 AM | #11 |
Rep 274
Drives: 2015 M3
Please note that if the waste gate linkage is more than 2mm out of spec ISTA will not read it. Adjust linkage all the way out and then incrementally adjust it inward using the adjustment nuts and keep checking ISTA as you adjust.
This is a common problem if you're not familiar with the limitations of ISTA. |
mdma-zn51.50 |
04-07-2020, 11:42 AM | #12 | |
ECUTek Master Tuner
10445
Rep 1,735
Drives: F80 M3 YMB
I have done the WG calibration several times using ISTA+
It is not a hard operation to do. But usually if your WG's do require adjustment, your car will immediately throw a drivetrain malfunction. It will throw the error even if you are 1mm outside of the calibration, so it is very sensitive. Usually low boost with high WGDC is indicative of a boost leak.
04-07-2020, 03:21 PM | #14 |
Rep 853
I just was speaking to pure about this as I have compressor surge with pure stage 2+. I have a JB4 with blue tooth connect and was adjusting my user settings this is where I sit with my wastegate adaptation is at 80 it was originally at 10. I set it and drove the the surge seemed to go away only to come back when I stepped on the gas then backed off the throttle and slowly increased it, but other times when I just floored it (multiple highway pulls) it was fine. Car def feels slower with just a JB4 and not a DME flash stacked.
Danlnyc88440.50 |
04-07-2020, 09:12 PM | #15 |
Rep 815
i did get a bunch of these a couple weeks back. Anyway both Pure and my tuner are telling me i need a wastegate calibration most likely. might have been some issue during install. |
04-07-2020, 10:06 PM | #17 | |
Rep 853
I clear the air mass codes and they usually come back every few days or after some spirited driving. I'm not sure what to make of those codes tho. |
04-09-2020, 06:27 PM | #20 | |
Rep 1,337
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
04-09-2020, 07:10 PM | #21 | ||||
Rep 274
Drives: 2015 M3
MR RIZK757.50 |
06-16-2020, 05:29 AM | #22 |
Rep 128
Where is the calibration done within ISTA please?
I've found where to measure what it currently is (IE, value for closed limit position in mm etc) but not any 'calibration' of sorts. Thanks!
F82 M4 CP Retrofitted: HUD + CS Dash, Fully adaptive/HBA LED headlights, shadowline LCI taillights, KAFAS2 / pedestrian detection / Speed Limit Info / Front Collision Avoidance, Fullscreen CarPlay / ID6, latest iStep. Mods: Carbon diffuser. Carbon side skirts. Bootmod3 Stage 2. BMS intakes. Decat downpipes. AA midpipe. Custom exhaust with akrapovic tips.
