09-26-2020, 08:55 AM | #1 |
Rep 291
Eventuri carbon fiber charge pipe possible to fail?
I am discussing with a friend who design single piece carbon charge pipes, and we started discussion about new eventuri charge pipes, he is profesional in carbon fiber work. I asked him why he not use cnc machine ring same as eventuri and he said eventuri use it because 2 piece of carbon are weld togheter to create a pipe, so without ring when you tight clamp pipe will crack. So this thing make me ask at upgraded turbos and high pressure eventuri will fail?
I am helping him for 100% fitment to his new charge pipes design. He want to desing 2 types of charge pipes, one full carbon(flange also carbon) and one version with aluminium flange and also he follow oem sway carbon texture. Ps: the red lines where eventuri welding supposed to be. |
09-26-2020, 09:37 AM | #2 |
Rep 5,181
You figured it out...
Eventuri CF CPs look so nice BUT they're only rated to 24PSI. I found this out from Kies who called Eventuri to ask.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
Info@mad-us.com1969.50 WarMachineM356.50 |
09-26-2020, 10:18 AM | #3 | |
Rep 291
I am impatient to use my friend one piece charge pipes as it will be ready. I will choose version with aluminium flange at turbo side for easy fitment His version is supposed to be stronger and resist upgraded turbos without any problems. |
09-26-2020, 10:56 AM | #4 |
Rep 511
Bmp'd.!!
"single piece" - no seam? First off, those who are looking to buy C.F. charge pipes do not have "performance" as their top priority! The reason Eventuri uses dual (Al.) flanges - separate from the pipes themselves, is because of the engines' movement under load. The type of silicone couplers used can play a part here as well. The weld(s) (one or two pieces) are not necessarily the reason why these may crack under lateral pressure. The properties of Carbon Fiber's elemental structure and it's actual lay out play a major role. As an example of the latter - Take a look at "forged" () carbon fiber. What is your friends target psi? Let us know who your friend is and his progress. Cheers!
///M Joy
09-26-2020, 10:58 AM | #5 |
Rep 5,181
The issue for Eventuri CF is both the coupler welds and also how they're made (moulded).
If you're going to make CF pipes make a hollow rubber mould of the inside of stock CPs, then make a hard form of the outside of the stock CPs. Make the rubber mould inflatable. Use the rubber mold as a form for the wet CF, then clamp it in the outer form, and inflate the rubber. This will squeeze strong "full wrap" CF against the form and replicate the factory pathway. Another thought...before wet wrapping you could insert steel rings inside the TMIC coupler and an o-ring coupler (turbo connector) on the turbo side for strength and easy connections. Doing the hand-wrap method with multi crisscross pattern you can probably hold high PSI boost without popping. Personally I prefer silicone tubes. No bling but NO heat soak from turbos to TMIC. I'm a power hog, bling comes second.
WarMachineM356.50 |
09-26-2020, 11:31 AM | #7 | |
Rep 5,181
Sorry if this is too much. I work for German Engineering so we always seem to go a little too far.
09-26-2020, 01:50 PM | #8 |
Rep 291
Guys, eventuri produce half pipes separetly and then glue them togheter, thats the main reason for that metals at the ends, without them when you tight clamps it crack. Thats why eventuri rate that low pressure because will crack in the others places where carbon pieces are welded. My buddy said something very high pressure, i don’t want to talk before tests, what i can say we will test pipes at ~5 bars and we will try to add heat(100degrees celsius) and test them also at pressure. C-mon is carbon, is suposed to be stronger than aluminium charge pipe...
09-26-2020, 04:19 PM | #9 |
Rep 511
There is no issue here.
There have been no reported (AFAIK) incidents of failure with Eventuris C.F. Charge Pipes! We're talking design/engineering - In theory! Most everything can be improved upon, on paper. Cheers!
///M Joy
09-26-2020, 07:38 PM | #10 |
Rep 1,144
I just feel Eventuri components are merely for looks and not performance related mods, can't see myself shelling my hard earned money just to see teh same failure rate as stock pipes. that just my 2 cents.
SYT_Shadow11500.00 |
09-26-2020, 09:53 PM | #11 | |
Rep 511
I hear you! Again, C.F. parts that aren't structural or weight saving related are not necessarily performance/track parts. As far as "failure rate(s)" go, I haven't seen any such metric being studied and/or published for stock charge pipes, much less for (specifically) Eventuri charge pipes. This is staring to sound like a Russian blog thread. And, that's Just my $0.02 Cheers!
///M Joy
09-26-2020, 10:04 PM | #12 | |
Rep 1,885
Fitment was average at best. |
09-27-2020, 05:59 AM | #13 |
Rep 1,337
Maybe I'm missing your point but the turbos and charge cooler are bolted to the engine so everything rocks in unison.
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
09-27-2020, 09:47 AM | #14 | |
Rep 511
This is what I was told by Eventuri during their testing phase. Cheers!
///M Joy
09-27-2020, 09:52 AM | #15 | |
Rep 511
Was the intake (Not - charge pipes) you received subject to failure? If so, did you contact Eventuri?
///M Joy
05-20-2022, 05:07 PM | #16 | |
Rep 120
We installed Eventuri CPs and V2 intakes (absolute PITA to install - cannot emphasize that enough. It looks nice and fits perfectly ONCE INSTALLED, but the installation itself took longer than swapping his downpipes - dual silicone couplers with a "by design it's loose" aluminum flange is a poor design, IMO), flashed BM3 stage 2. His CPs have blown off / out of the couplers 4 times now in two days on the stage 2 map (even once on a CS map). And yes, the clamps are all tight. |
05-20-2022, 08:06 PM | #17 | ||
Rep 5,181
10-01-2022, 10:27 PM | #19 | |
Rep 43
04-02-2023, 11:19 AM | #20 |
Rep 1,044
Drives: 2018 M4 Competition
I've had these for quite some time with my previous build + aftermarket turbos and they worked flawlessly. Now, on my new replacement stock engine with stock turbos, I've blown them out of the coupler 4 times in 2 days.
Update: I reached out to Eventuri and they stated these charge pipes are tested to 5 bar and can handle it (way more than 24PSI). I was told to check the installation. I've taken them off so many times I'm sure it's not the install but perhaps it's basic clamps. I asked and was told that the lower clamps are 32-50mm and the lower silicone couplers are 42mm end to end (despite the tapering). I upgraded my upper clamps with v-bands for aesthetic reasons but I know they work better so I'll probably do the same for the lower to see if that helps. When I find some that fit with that flange without contact I'll share back for those who may be curious.
Instagram: Slaughter.Mode
04-03-2023, 10:41 PM | #21 | |
Rep 84
TopJimmy5495.50 |
04-05-2023, 12:35 PM | #22 |
Rep 1,044
Still trying to find the right ones. I ordered a set but the way the flange works (and I suspected this would happen) it interferes with the 'bulkiness' of a vband. I'll keep searching for a better clamp.
Simon P.88.50 |
