Autotalent
      11-20-2020, 09:40 AM   #1
DavidGP
Drives: 2016 MG F80 6spd
charge pipe removal for engine troubleshoot
Can the charge pipes be left off of the engine when running. Trying to troubleshoot some misfires on cylinder #5 after changing to NGK spark plugs. Its a pain putting them on and taking them off.
150502 Ignition, Cylinder 5, burning time is too short
140510 misfires, Cylinder 5
140501 misfires, Cylinder 5, injection is switched off
Thanks,
DP
      11-20-2020, 10:45 AM   #2
m3elmo
Drives: F80 M3
try to start it and found out? Don't think anything bad would happen minus it not running right. Not sure how much that would help your troubleshooting. if last thing you did is plugs then could be something related to that or through the install.
the MAP or is it MAF sensor is on the intake side too, so without any flow there not sure how the ECU would react though.
Danny
Bay Area, CA
      11-20-2020, 11:01 AM   #3
Kilabyte
I'm Batman!
Poland
3949
Drives: Mineral White M3 6MT
It should run, I drove home fine when my silicone one popped off because I forgot to tighten the clamp. Be VERY careful not to drop anything into one of the turbos though.
S55, 2JZ, M48.00
      11-20-2020, 04:17 PM   #4
DavidGP
Thanks, issue fixed.
      11-20-2020, 11:39 PM   #5
Kilabyte
I'm Batman!
Poland
3949
Glad to hear. Out of curiosity, what was the issue and how did you fix it?
S55, 2JZ, M48.00
      11-21-2020, 09:22 PM   #6
DavidGP
# 5 plug was loose and not torqued to spec.
      10-08-2021, 08:18 PM   #7
f0rgivM3
f0rgivM3's Avatar
Drives: F80 m3
Thanks,
DP
Did you fix this issue? Having same problem with same codes.
      10-09-2021, 04:27 AM   #8
MJ6
MJ6's Avatar
Drives: 2018 M4 ZCP 6MT
2018 BMW M4 ZCP  [10.00]
The OP literally answered this question one post above yours.
I swear, reading is a lost art.
2018 F82 ZCP 6MT: FBO, Kratos KRAS55Bi, EU5 Injectors, Dorch HPFP Lift Kit, Stage 3 LPFP, Bend Calibration Zeitronix ECA-2, BM3 Flex-Fuel Tune by ABP
For Sale
spidy512502.00
Kilabyte3949.00
      10-09-2021, 12:05 PM   #9
f0rgivM3
f0rgivM3's Avatar
Drives: F80 m3
Been reading forum after forum. That post must have slipped. I apologize
f80post
