10-17-2021, 12:02 PM | #1 |
Rep 3
19 Inch Wheel Dilemma
Currently have a 2017 750i with the MSport package. I'm not a fan of the tire options available to me with the 20" staggered setup. I know it's an unpopular opinion, but I like to run on run-flats for peace of mind. With the current wheels on the car, an all-season run flat option does not exist and I don't want the hassle of winter tires as I feel like i'd be changing them often due to weather weirdness and periodic trips to florida in the winter.
Looking for recommendations for a 19" wheel to run 245 45R19s as a square setup that will fit over the front brake caliper. Having a hard time finding options that I know will be ok with the calipers. Tirerack configurator doesn't even recognize that the 750 has MSport brakes like it does with other cars. |
10-17-2021, 12:39 PM | #2 |
Rep 313
Are you able to access the 2017 brochure to see if the MSport brakes you have were conditional on 20” wheels or not.
10-17-2021, 01:15 PM | #3 |
Rep 7,586
You could also use one of the online part database sites like realoem.com or bimmercat.com and input the last 7 digits of your VIN…then go to the wheel diagrams.
Look to see if there are any 19” wheel offerings…if they are listed, then click on the diagram and read the info to see if any of them can NOT be used with the sport pkg.
10-17-2021, 01:42 PM | #4 |
Rep 1,618
OP: If you can't go to 19" but want to stay with RFT, there should be non staggered 20" options avaialable for All Season RFT. That may require 2 or 4 new wheels but you were willing to buy new wheels anyhow.
BMWCCA
Atomsplitter0.00 |
10-18-2021, 08:12 AM | #5 |
Rep 1,487
I have a 2019 M Sport 750i with the stock 19" wheels. They are a squared setup with 245/45/19 tires.
These would definitely work on your car. Wheel code is 647M
Blessed Beyond Measure
Atomsplitter0.00 |
10-18-2021, 09:34 AM | #8 | ||
Rep 1,487
You think that they would be setting the ride height different from the factory based on the several rim choices available? You can get 21's as stock too from the factory. You're saying these cars are higher up? Nahhhhh.
10-18-2021, 07:44 PM | #9 |
Rep 7,586
Ditto…all of the wheel/tire recommendation listed in your owners manual all have the same rolling diameter/circumference. If you don’t believe us…just google for a wheel/tire calculator and compare the 19”/20”/21” tires and you’ll see how close in spec they are:
Another term you can google to get an understanding is “plus sizing”. As the wheel size increases, you decrease the aspect ratio of the tire…which will maintain the same rolling circumference.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-18-2021 at 08:22 PM.. |
10-23-2021, 01:57 PM | #10 | |
Rep 61
10-23-2021, 06:59 PM | #11 |
Rep 852
I have the same setup for winter with Michelin run flats, no issues with the height or the rider. Not sure what the other guy is talking about!
10-24-2021, 07:51 AM | #12 | |
Hide! My wife's coming!
814
Rep 2,816
When you maintain the stock wheel and tire sizes on 19,20,21… you don't need to calibrate the suspension. This is from personal experience as I have ran all 3 stock sizes and I am very familiar with the calibration system. You aren't changing the overall circumference of the wheel/tire combo. So suspension heights remain the same. Ask any BMW dealer to confirm. If I were to go outside of those stock parameters increasing or decreasing overall circumference, then I will need to calibrate the suspension to adjust for the differences in sizes and keep a stock suspension setup and yes, it could impact safety systems and components if you're not running the proper parameters. Example, you decided to do 245/45/20 in the front and 275/30/20 in the rear. You'll have roughly an 8% difference in circumference front to back and difference in revs per mile which will throw systems off. They need to be in alignment and the rule of thumb usually is not more than 3%
10-24-2021, 09:13 AM | #14 | |
Rep 1,618
BMWCCA
10-24-2021, 11:02 AM | #16 |
Rep 1,618
Ok, Lucky. You win. You are smarter than I am. In fact, you are smarter than everyone. Thank you for everything.
BMWCCA
10-24-2021, 11:57 AM | #17 |
Rep 107
LuckyW
I accept that ISTA+ uses the rim size for calibration. I accept that the measurement A is from the rim edge at the bottom to the lower edge of the wheel arch labeled 1. I ask you to accept that factory rim sizes with appropriate OEM tire sizes have a diameter that is equivalent and let's call it D. If it were not, your speedometer accuracy would change drastically with different wheels. Let's call the height of the tire sidewall H such that the diameter D is the sum of rim size R and 2H. Let's call the gap between the bottom of the wheel arch 1, to the top of the tire, X for ride height computation. So, ride height, for these purposes, is D, the diameter of the wheel, plus X, the gap between bottom of the wheel arch and top of tire. Since the calibration opted to measure A from the bottom rim edge it is logical that the rim size is required to compute X. I also submit to you that desired X, regardless of rim size with OEM suggested tire sizes, is consistent given the compression capabilities of the suspension in a given driving mode. Yes, X does become smaller by a certain amount when the suspension is stiffened in sport mode and the car is lowered. If one were to compute the relationship between A and rim size R you will note that it is a strictly linear relationship. Yes, ISTA+ uses rim size R but only because it opted to compute using the rim edge. D = diameter of wheel - rim and tire assumed to be a constant H = height of tire sidewall X = gap between top of tire and edge of wheel arch labeled 1 assumed to be a constant R = rim size A = distance from rim edge at the bottom to the lower edge of the wheel arch labeled 1 D = 2H+R D = A+H-X Solving for H in both... (D-R)/2 = D-A+X Solving for A... A=X+D/2+R/2 Assumption is that D and X are constants. Therefore: A=K+R/2 where K is a constant. Yes, your measurement A would vary with different rim sizes R, but that is expected because of the nature of A's start/end point. However, your ride height overall does not change with different OEM wheels and therefore no calibration is necessary. |
10-24-2021, 12:03 PM | #18 | ||
814
Rep 2,816
It's all good. You do you.
10-27-2021, 06:24 PM | #21 |
Rep 3
Found a solution i'm very happy with. Drag DR77 19 inch, 8.5 width, 22 offset. Love the look and plenty of room between wheel and caliper.
Thanks for all of the input. I did not get the suspension recalibrated |
