      07-06-2022, 11:16 PM   #1
ScaldedDog
ScaldedDog's Avatar
458
Drives: 2022 X5 45e
What do you use for daily bug gut removal?
It's grasshopper season here, so every time my wife drives her new Alpine white X5, there's a grasshopper massacree on the front of the thing. What do you use to remove the remains, if the car doesn't otherwise need washed? The front is freshly PPF'd, if that matters.
I used some SprayAway foaming glass cleaner that worked pretty well, but I don't know if that's the best thing to use on PPF.
Mark
2022 X5 45e - Wife's daily driver
2023 GX460 - My daily driver
2017 JKU Sahara - Beach jeep
1988 4Runner on 40's - Off-road trailer queen
2001 PSD Excursion - The slave that drags the queen
      07-07-2022, 05:32 PM   #2
malvern_man
Drives: X5 M60i LCI
Gyeon Bug and Grime remover or Gyeon APC and then agitate with an ultra soft detailing brush, then rinse off.
nZtiZia7437.00
wingflex317.00
      07-07-2022, 07:05 PM   #3
ScaldedDog
ScaldedDog's Avatar
458
Drives: 2022 X5 45e
Thanks! If I buy any more Gyeon crap I'm going to have my own seat on their company jet.
Mark
I2P41.50
wingflex317.00
      07-13-2022, 05:43 PM   #4
malvern_man
Drives: X5 M60i LCI
Mark
You and me both 😂
      09-05-2022, 12:43 PM   #5
Miata13
Miata13's Avatar
87
Drives: '23 BMW x3 M40i (on order)
I've used Griots Bug and Tar Remover with success. Spray the bug infested area...let it dwell a bit and then hose it off....
Always helps too to have a good coat of wax or ceramic on the paint too.
'23 G01 BMW x3 M40i (via PCD Arp 2023)
'15 R59 MINI Roadster S
'19 F22 BMW 230i xDrive THP (retired)
'14 F31 M-Sport ED & PCD (retired)
I2P41.50
      09-16-2022, 04:47 PM   #6
GerryC
GerryC's Avatar
4213
Drives: BMW Z4 M40i, BMW X5x40i
I use that too. And when I know bugs are bad (primarily lovebug season around here) I coat the front and the mirrors with Griot's Bug Barricade. Between that and the ceramic coat, the bugs come off pretty easy.
Gerry
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch
      09-18-2022, 09:21 AM   #7
P1
P1's Avatar
11850
Drives: 2004 3/4 ton Duramax
Try filling a spray bottle with a heavy mix of your favorite soap/APC and water. Spray it on and let it dwell for a bit. Bugs will come right off and won't cost you $15.
FiatLux17.50
      09-24-2022, 08:28 AM   #8
I2P
Drives: 2022 BMW X5 xDrive 40i
Gyeon EVO Can Coat
After washing my G05, I applied Gyeon EVO Can Coat. The surface now feels really slick. When I got home after recent short drives, I saw some bugs (not many) on the front. I wiped my finger across the stuck on bug and they just fell right off, leaving no residue. It may be different with a road trip, which I have coming up in 3 weeks. I'll post again after that 9 hour drive.
      09-24-2022, 05:16 PM   #9
malvern_man
Drives: X5 M60i LCI
How easy was the new EVO Can Coat to apply and what are your initial thoughts on it?
      09-25-2022, 08:21 PM   #10
I2P
It was easy to apply. Do a section at a time. I used two microfiber towels. Spray twice on the application microfiber. Directions are to do the towel spray away from the surface of the vehicle. Then wipe the section. Use the second microfiber to buff it. If you search for the EVO can coat, you will find several You Tube videos. Look for the Gyeon one. I think it took me a little over 30 minutes to do the whole X5.
This is my first ceramic coating. I like it a lot. Much easier and looks better than traditional wax.
      08-04-2025, 10:49 PM   #11
JoeyO
JoeyO's Avatar
Drives: 2025 BMW X3
It seems like Gyeon Bug and Grime remover is popular. Any other recommendations?
Is there any spray to remove bugs where I don’t have to perform a follow-up car wash afterwards? There’s nothing worse than washing my car during the day and then getting it bombed with lots of bugs at night. The car is still mostly clean. I just need to remove the bug carnage.
      08-04-2025, 10:56 PM   #12
afadeev
afadeev's Avatar
4379
Drives: F80 M3
That is my go-to for summer bug cleanup as well.
However, my car has real paint, not the PPF condom, so your solution might be different.
Good luck,
a
P.S.: The above works on all situations other than driving through Canada in August. Drove through Ottawa once, then it took multiple acts of God to remove the carnage from the front of my car.
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White)
'25 Lexus RZ (White/Blue)
      08-05-2025, 09:49 PM   #13
RCKYMTN M34OI
Drives: 2020 M340i
Pickup some Dark Fury from Oreilly. You may have to order it but it's very effective. I run a detail business and use this for bug guts and traffic film remover. They sell it by the gallon also
https://www.oreillyauto.com/detail/c...pt?q=dark+fury
      08-06-2025, 12:13 AM   #14
DubaiRich
Drives: 2010 Z4; 2008 118D
2010 BMW Z4  [8.17]
I use Simple Green. The bugs just melt away and it doesn't harm the paint
      08-06-2025, 08:50 PM   #15
wingflex
wingflex's Avatar
317
Drives: 25 G80 M3 MT Dravit Grey
2025 BMW M3  [9.50]
Gtechniq W8 bug remover is also great in case you wanted some more choices. I mostly use Gyeon and Gtechniq products !
      08-08-2025, 08:08 AM   #16
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
Adams Bug and Tar remover followed up with detailing spray.
