07-27-2022, 01:43 PM | #1 |
Rep 5
Changing to 19x9.5 & 19x10.5 staggered setup
Hey all,
I need some opinions on whether this will work. I am looking at a new wheel setup, while keep my existing tires. (Based on the number below, I suspect I will need to get different profile size tires). I have a 2013 E93 M3. I am currently using the stock 19" tire sizes - 245/35 (F) and 265/35 (R). New wheels (Aodhan DS01): Front: 19x9.5 +25 Rear: 19x10.5 +25 If I keep the same tires, according to the online calculators here are the clearance differences (from stock): Front: Inner (-8.7mm) Outer (+16.7mm) Rear: Inner (-14.7mm) Outer (+10.7mm) What do you think? Cheers. |
07-27-2022, 02:31 PM | #2 |
YNWA
1056
Rep 816
I would do 255/275. I did 255/275 on 9"/10" and it's perfect. 245/265 are quite narrow for 9.5"/10.5"
If you have Michelin PS4S, 245/265 would be a little better because of how wide michelins are.
lhaire7.50 |
07-27-2022, 08:31 PM | #3 |
Rep 129
Check this article out, helped me a lot.
https://support.apexraceparts.com/hc...-Fitment-Guide Scroll down to performance street and track fitments and your wheel specs are basically there (3mm offset off) with tyre size options which will work. I wouldn't keep the same tyres, bit too much stretch imo and being 19s the side wall is hard enough as it is.
2011 E92 M3 - Mineral White - Pure Edition I
lhaire7.50 |
07-28-2022, 09:56 PM | #4 | |
Rep 5
