08-25-2022, 01:21 AM | #1 |
Rep 25
MHD Stage 2 E85 OTS
Hello, kind gentlemen.
Has anyone ran the Stage 2 E85 OTS map on stock fuel system ? My car is catless dp & titanium chargepipes .. currently on the 93 map ! I live in TX so there is E everywhere ! I reached out to PureBoost to see if it’s ok to run the E85 map on the stock fuel system & they said yes!! But I’m a little scared 😵*💫 Just wanted to get some input from the experts before I blow my car up 😰 Thnx!!!! |
08-25-2022, 09:24 AM | #3 | |
Rep 25
How’s ur car running and how long have u been on it ? I am considering getting the MHD flex fuel kit just so I know the exact E content ! Also, are u on a custom e85 tune or the stage 2 e85 OTS? |
08-25-2022, 01:11 PM | #4 |
Rep 49
I'm thinking about doing the same. I've done a bit of research on the forum and the main recurring issue is your injectors can get stuck open when running E85.
It's not clear what causes it, some people think that the ethanol dislodges gunk built up in the fueling system and fouls up the injectors. If you're planning on going with flex fuel they say you should get the more expensive Bend Calibration kit with the extra fuel filter. Others say its not necessary and not to worry about it. Another theory is running an aggressive tune at 6.5k+ rpm pushes the injectors too close to their limit, so they get stuck open. Some think you need to fill up the tank with regular gas every 4-5 fillups to help keep them lubricated. Or maybe injectors failing is rare and nothing needs to be done. I found this thread on E85 in which Bend Calibration suggests cleaning your injectors yearly! And other people suggesting getting more frequent oil changes (every 3k miles!) And suggestions that you shouldn't leave your car parked for more than a week! on a tank of E85. I'm trying to figure out how necessary all of this advice is. https://f80.bimmerpost.com/forums/sh....php?t=1758624 Most of the threads I've found are a year+ old at this point so hopefully we can get some more recent experience in here. Last edited by nick_xd; 08-25-2022 at 01:18 PM.. |
08-25-2022, 08:38 PM | #5 | |
Rep 25
08-26-2022, 07:18 AM | #6 | |
Rep 5,179
1) Kratos confirmed this with Bosch engineers… When running HPFP pressure above normal pressures (>3600?) the gate inside can break. This causes a "stuck injector" that does not fix if cleaned, it keeps leaking. In this case you're over fueling a cylinder and the car bogs/chugs, white smoke, stinky tailpipes… This problem is the one where people run Top Lube (Power Plus grape?) to try and prevent the issue, but lube doesn't help. If an injector is gonna break it's usually found out early in E85 tuning when fueling is worked out. 2) A dirty or clogged injector can come from debris or gunk/slime. Some crap fuel has an additive that doesn't mix with E right (you gotta search for the thread). Also, E left in the tank unused long term will absorb moisture. This might be where the "gas every three tanks/months" comes from. Yes, a fuel filter can help catch the gunk or debris upstream from your engine. And there may be more issues I've missed or forgotten. I hope above helps de-stress. I installed M5 injectors to supply more fuel at standard pressures, and a filter came with my LPFP kit so it got installed too.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
JAI///M3528.00 theweebabySeamus380.50 |
08-26-2022, 12:59 PM | #7 | |
Rep 49
08-26-2022, 03:14 PM | #8 | ||
Rep 5,179
08-29-2022, 07:21 AM | #9 |
Rep 167
I also live in texas and just went from bm3 flex tune on e65 to Paul johnson custom flex tune at full e85. The only parts needed for me were the ngk flex spark plugs gapped at .020 and the bm3 flex sensor and catless dps and charge pipes, the car runs amazing.
If you do go flex I highly highly recommend a custom tune. I can't say this enough. If your gonna do it, do it right the first time. But to answer your question, yes it can easily be done with just a flex sensor on the lpfp , spark plugs and a tune.. I tried doing it the cheap way, ots tune, stock plugs, stock dps.. lol it worked but I would t recommend it! Just get ahold of a tuner and tel them what you want to do and listen to their advice. I just finished my custom tune last week and took off a full second from my ots e65 tune to my full e85 tune on my 60-130 times! Not too mention the car runs like butter! So smooth , drives like stock or how stock should be at 40% throttle. But when you floor it, you unleash the beast from within and everything you thought you knew about your car before goes out the window! I'm having to relearn how to drive it still, but it's simply amazing. Especially in this Houston heat, I can't believe not only how fast it is but absolutely no issues with heat soak or anything temp involved. These cars on ethanol are a completely different animal and it still blows my mind all that's needed it a $600 sensor …. I've had my sensor since March , changed plugs in may , changed dps in July and cus tune finally in august. My car is night and day from March. And I won't ever say what my draggy times where in March on e50 compared to now lol it's pathetic!
2010 e92 M3
08-29-2022, 12:05 PM | #10 | |
Rep 49
How do your new e85 dragy times compare to OTS stage 2 on 93? That's where I'm at right now... |
08-29-2022, 02:46 PM | #11 | |
Rep 25
Edit: I’m also in Houston !! But yeah bro just hang in there ! The heat here is pretty bad rn ! Everytime I push my car I feel bad for my turbos .. on another note .. boostszn is approaching Last edited by icyf82; 08-29-2022 at 02:58 PM.. Reason: Added more stuff |
08-30-2022, 08:19 AM | #12 |
Rep 138
Knock on wood, car runs great. I have been on it for two weeks now. I am on a custom e85 tune. Not a fan of OTS maps.
'15 335 Sportline xDrive
Jb4 - ER: Downpipe, Charge Pipe, TTIC Pipes, Intercooler - BMS Intake |
08-30-2022, 11:14 AM | #13 | |
Rep 911
09-01-2022, 04:59 AM | #14 | |
Rep 131
https://datazap.me/u/tommix/e85-ots-...data=4-6-24-46 I have also tried a custom map where the boost pressures are even over 20 psi even after 6500 rpm. On that map, my car's engine started to jerk after 6500 rpm. |
09-01-2022, 06:03 PM | #15 | |
Rep 25
Did you have a MHD flexfuel kit and did you do your spark plugs? The E85 pumps here aren’t exactly E85 (E75-E80) but I should be fine .. right? What u think good sir ? Thank u In advance 🤟🏻 |
09-05-2022, 12:37 PM | #16 | |
Rep 131
At first I used NGK 97506 spark plugs. The engine worked fine on them. Later, I updated NGK F8S flexfuel plugs. In both plugs, the gap was/is adjusted to 0.020". According to the technical specification, the ethanol content of E85 fuel can vary between 70-85 percent by volume. In Finland, however, the ethanol content is typically between 82 and 83 percent by volume. The quality and purity of the fuel is of a very high standard. The interesting thing is that RE85 contains about 80% renewable ethanol, which is produced in Finland from domestic waste and residues. Real eco driving |
09-05-2022, 04:50 PM | #17 | ||
Rep 167
as for my draggy times it's like this 60-130 Stage 2 multi e60 ots pre spark plugs gapped at .20 and dps - in average 2500 DA 92 degrees 8.8 seconds Stage 2 ots e60 2800 DA on different roads in 96 degrees would sometimes do 9.2-9.5 Then changed plugs and dps Ots on e65 averaged 8.6-8.8 over many many runs. My best time prior to the custom tune was 8.55 in 72 degree weather back in March Now on full e85 I'm at 7.62 as my fastest with an average of 7.75-7.83 However, it's still hot and I really haven't gotten a good run because I have issues with traction at 60! Lol if I floor it in 3rd around 50-60 it will spin, sometimes just a little sometimes it gets sideways . And I told Paul to keep the power and tq linear so I caiuld use it! So I shaved off over a full second and am hitting 60-130 in like 1110ft compared to my 8.68 of 1280 ft I think.. almost 200 ft faster on custom tune with e85 compared to ots with e65 , Thsts unbelievable! And once it cools down and I get better tires I know for sure I'll be around 7.4 at least, I'm hitting 60-100 in 3.52 / 60-110 in 4.81 / 60-120 in 6.20 - I haven't run a quater under 11.97 because of traction. And I've tried probably 15 times , mostly 12.5 plus lol I have to play around with my Xhp settings and my bm3 tq settings. I even reduced tq by 45% in 1sr and 35% 2nd 10% 3rd yesterday and still couldn't get traction . My Michelins are 6 weeks old lol 295/30/20's Car runs like a monster and all around smoother and better than ever . It's better in every single way. Definitely do it!
2010 e92 M3
