10-28-2022, 10:32 AM | #1 |
Rep 129
headlight height adjustment
Where is the height adjustment screw for the driver side LH headlight on a G12? Is there a cover I need to remove?
11-01-2022, 09:55 AM | #2 |
Rep 8,098
What type of headlights do you have?
US version: Remove the horizontal blocking before adjusting the headlamp
If you're still under warranty, is there a back story to why you need to adjust the left/driver headlight? Just curious because the adaptive headlights are designed to be lower & have a slightly different cut-off on the left to not blind oncoming traffic. You can get an idea in the info below about BMW's variable light distribution.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-01-2022 at 10:02 AM.. |
11-05-2022, 11:39 AM | #3 |
Rep 129
S552A Adaptive LED headlight
The headlight was replaced recently under warranty as it would get condensation - only the left one, never the right. I think it is a little TOO low given where my eyes fall on the road while driving at city speeds - like off by about 3 feet as computed by where my eyes are on the road in front vs. the cutoff of the beam. So to gain 3 feet about 20 feet out(?) I am probably raising it about a degree. Yes, the right cutoff is further out as you have described and it will remain. |
09-20-2024, 09:18 PM | #4 | |
Rep 1,296
