08-05-2023, 09:22 PM | #1 |
Rep 63
Vehicle PPI results are out!
Hi all, I’m considering a 2019 m850i and here are main issues found.
Are these issues I should be concerned about? |
08-05-2023, 09:35 PM | #2 |
Rep 2,448
Drives: 9Y0 Cayenne S
First and third items are the dealer trying to generate revenue from you to replace the brakes and battery. Neither seem serious.
Engine coolant smell could be normal, depends on the vehicle. MBs for example "sweat" coolant at the hose joints, and coolant smell is common. Search the forums for coolant smell. It could be normal, or it could be a water pump or cylinder head gasket making its way to Heaven. |
08-08-2023, 08:54 AM | #3 |
Rep 63
I’m guessing just using the brakes will remove that?
08-08-2023, 09:53 AM | #4 |
Rep 843
Beware the Hot Vee! That very same drivetrain in my '20 M550i was plagued with issues and the vehicle was brand new off the dealer lot. That coolant smell(and subsequent leakage)is a common issue,was back to the dealer 13x in 1.5yrs for warranty work for that,as well as other issues.
Make sure you have ALL the extra add-on warranty you can afford to purchase chances are you'll need it...
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582) Gone but not forgotten: -'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG |
F36Donut94.50 tracer bullet3432.50 |
08-08-2023, 02:32 PM | #5 | |
Rep 63
08-08-2023, 03:34 PM | #7 |
Rep 63
08-09-2023, 07:32 AM | #8 |
Rep 4,099
I can't say for all cases of course but historically I've seen "warped" rotors (pedal vibration) turn out to be pad deposits on the rotors that can be scrubbed off with a couple aggressive stops from higher speeds. If there's a test drive option without a sales person present, maybe give it a try (be safe)? If it works, there's really no issue, but if they don't know that it might still be some leverage with the seller?
I don't think the seller was ever explained - the dealer, a different dealer, private party, Carmax...? This might factor into the overall situation. |
08-09-2023, 09:26 AM | #9 | |
Rep 63
He said there was a spot on the rotor that was removed and the issue was fixed. I will be going there in person so will see haha. |
08-09-2023, 09:46 AM | #10 | |
Rep 843
This is strictly 100% my opinion,so take it w a grain of salt
-'24 X5MC,'22 430i
xander_g1055.50 |
08-09-2023, 01:04 PM | #12 |
Rep 63
08-09-2023, 01:06 PM | #13 | |
Rep 63
I will be getting the extended warranty so not too worried but just annoying to deal with fixing potential issues. |
08-09-2023, 08:07 PM | #14 |
Rep 1,158
Drives: G30 M550i
