08-15-2023, 04:52 PM | #1 |
Rep 648
Where to tap into for aftermarket oil cooler install
On newer G series, many non M don't come with a dedicated oil cooler or transmission cooler. Given bmw don't use a threaded oil filter, we cannot easily use the standard thermostatic AN adapter to feed the cooler.
For those with experience, where would be the best place to feed the cooler? Some kits have model specific BMW to AN fitting part but still unsure where the lines would source from. There's an oil heat exchanger mounted to the block so I was thinking to remove the line exiting the heat exchanger and run that line to one of the AN conversion pieces. No clue how this should look but input would be handy. Same question applies to the transmission too- where to tap into? |
