01-01-2024, 08:53 PM | #1 |
Rep 22
Single turbo s55 tuners?
Hello I hope all is well, I recently ordered a big boost efr 8474 turbo kit for my 18 m3 6 spd and have been stuck with looking for a good tuner to work with. I should add that I am not looking to make the most power but rather keep things low around 550 whp until I have the time to do the clutch/fueling and possibly building the motor down the line. For all F8x owners with single turbos please any recommendations would be helpful so I am not steered in the wrong direction. It would be worth noting that my car will be tuned with MHD as well. Thanks in advance to all
01-02-2024, 09:20 AM | #2 | |
Rep 3,729
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
01-02-2024, 10:22 AM | #3 |
Rep 549
01-02-2024, 07:40 PM | #4 |
Rep 955
Can you elaborate a bit as to why, thanks.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
01-03-2024, 09:36 AM | #6 |
Rep 556
Drives: F82 M4 BSM
Three of my friends with big singles are tuned with ABP
17' F82 BSM - Current Built Motor/PS2+
16' F82 Silverstone - Totaled FBO |
01-03-2024, 11:00 AM | #8 | |
Rep 556
Drives: F82 M4 BSM
One is running a Big Boost 8474 bottom mount with PI, no meth, stock motor, tuned on 93 and I think low E. The weld quality on the big boost kit was not the best by the way, charge pipe was welded kinda janky (see pic). The Y portion was rubbing on his CS hood. One is running DG Autowerke’s top mount (not sure about turbo size), PI, 50/50 meth, built motor and trans, full flex fuel, and he’s removed the TMIC to go to some front intercooler setup (air-to-air maybe?) Hes been working with ABP ever since he was stock motor and Pure S2+ (which I’m selling on his behalf here on bimmerpost 😆 The third guy I don’t know his setup nearly as well, just that it’s a bottom mount on stock motor
M_Torx335.50 |
01-03-2024, 01:45 PM | #9 | |
Rep 549
I then spoke to 4n about putting bungs in the exhaust manifold and learned that was how the kit was originally designed but the o2 sensors were being cooked very quickly on track so he moved them back to the down pipe in single bank configuration. It sounds like the sensors may hold up in the manifold on the street but the sustained higher temps on track are too much. I track mine so they are going in the downpipe. I have read good things about Motiv Tuning but cant get any response from them. I have BM3 now but would move to Ecutec. Last edited by b_w.; 01-03-2024 at 02:11 PM.. |
01-03-2024, 08:27 PM | #10 |
Rep 1,184
Tons of bm3 tuned single turbo S55 out there. Single bank is just a toggle on the map configuration. More and more people I’m reading are loving Maxxecu setup for PI and boost and it even integrates with bm3 for flex fuel like their flex fuel kit.
01-04-2024, 07:01 AM | #11 |
Rep 5,781
What do hp and torque curves look like for a single turbo? More or less linear power curve? Better or worse than stock spool time/lag? I guess this really depends on turbo size but I assume a single turbo is larger than the stock twins?
01-04-2024, 01:37 PM | #12 | |
Rep 549
M_Torx335.50 |
01-04-2024, 10:21 PM | #13 |
Rep 955
I've been eyeing this turbo kit due to the O2 sensor location on mani, it keeps both and both for DP's. Just don't know how well they work in that location.
https://speedtech.com/pages/bmw-s55-turbo-kit I'm following sideways_n55 project but it's not online yet. https://youtu.be/qhVsqyjZlvA
M4CS Frozen Blue
01-04-2024, 11:38 PM | #14 | |
Rep 549
01-05-2024, 10:14 AM | #16 |
Rep 955
Good point, I didn't think about that
M4CS Frozen Blue
01-09-2024, 09:04 PM | #17 |
Rep 549
Connected with Chris at motiv. He suggested tuning on mhd would be easy for a single turbo setup. Had some thoughtful dialog and replies. Said the bimmerworld gt more is tuned with upgraded turbos on mhd and it is obviosly heavily tracked. Not sure yet but gives me comfort knowing the tuner has worked on track oriented cars with built motors and upgraded turbos.
OG_F8710.00 |
01-10-2024, 12:11 AM | #18 | |
Rep 22
01-10-2024, 08:14 AM | #19 |
Rep 175
mhd is just a platform that tuners can use to flash the car. just like bootmod3
2015 Liberty Walk M4
F80Paul Tuned New Jersey |
DELETED MEMBER 852462106.50 M_Torx335.50 |
01-11-2024, 01:32 PM | #20 | |
Rep 549
Not like there are a ton of single turbo track cars but the ones I have seen are tuned on mhd. I was hoping ecutek would work but looks like that isn't an option. |
M3EW222.50 |
01-11-2024, 03:42 PM | #21 |
Rep 22
I don't know the specifics but there's something about ECUtek that doesn't allow for single bank tuning/integration. The 4N motorsport kit is designed around a single bank. There are dual bank kits out there but from what I've heard, the O2s won't survive in a road racing environment.
01-11-2024, 06:06 PM | #22 |
Rep 22
No doubt, I'm sure it's possible but there's a reluctance to make that step in innovation. I asked Bend Calibration about it the other day but they wouldn't budge. Hopefully we'll see some progress in the upcoming months, this platform seems to be picking up again.
