Go Back   7Post - 7 Series Forum > BIMMERPOST Universal Forums > Site Related Announcements - Suggestions - Feedback - Questions
      06-29-2024, 11:57 AM   #1
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
I get a 403 Forbidden to access error
Right now, I get a 403 Forbidden to access error on both my PC and my cell phone on the same wifi. I had to switch to another IP address via VPN to be able to see/access the Bimmerpost site. I am not "banned", so what could be the issue?
In the past two months there have been numerous site outages at random times, not just at the 2am EDT site backup/updates.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
      06-29-2024, 02:28 PM   #2
fe7565
fe7565's Avatar
I tested on my cell phone on 5G/LTE cell data on the road and I can access. At home using my wifi I cannot access the forum, I get 403 Forbiden error. Can you check please?
When I change to the different IP address on the same wifi network using VPN, then I can access again. I tried a different browser Firefox (and Chrome) and both. So my IP Address is blocked by Bimmerpost.
      06-29-2024, 02:42 PM   #3
fe7565
fe7565's Avatar
My IP Address is blocked by Bimmerpost. I used two different browsers Chrome and Firefox, and the same 403 Forbidden. I also released my IP address and renewed it.
I am only able to type this using VPN.
      06-29-2024, 04:23 PM   #4
fe7565
fe7565's Avatar
I can now access again Bimmerpost using my normal wifi IP address. Thank you.
      07-03-2024, 09:02 AM   #5
pirategenes
Drives: E90 M3
It looks like my IP address is blocked in the past few days. I can access through cell connection but not home WiFi. So strange. Can you let me know how you resolved this?
Thanks so much!
      07-03-2024, 06:20 PM   #6
fe7565
fe7565's Avatar
Thanks so much!
I didn’t resolve it on my end. Something that Bimmerpost did to fix it. I don’t know if there was an error during their updates, or somebody accidentally added me to the blocked list?
      07-03-2024, 06:59 PM   #7
pirategenes
Drives: E90 M3
Thanks for the quick reply.
Turns out something similar happened on my end. I wrote the the hosts and after explaining the situation in now no longer get the 403 Forbidden error. All good now.
fe75651118.00
      07-03-2024, 09:24 PM   #8
pnwwagon
Drives: 2019 F31 AW MSport
Are you PMing a mod or something to get that fixed?
      07-03-2024, 11:23 PM   #9
pirategenes
Drives: E90 M3
I clicked on the contact link at the bottom of the main page and sent a message there.
      07-04-2024, 01:15 AM   #10
apptest
all I do is test!!6
apptest's Avatar
Drives: I lost count of how many2
If anyone is having this issue please pm me directly
fe75651118.00
      07-06-2024, 08:27 AM   #11
chris3g
chris3g's Avatar
5759
Drives: 2023 M3 xdrive
getting 403 since yesterday, sent you a PM. have to browse the forum now through tor or on mobile data.
      07-06-2024, 12:04 PM   #12
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
3076
Drives: 2024 Golf R DSG Lapiz
I don't remember if I get 403 error but I also cannot access this website anymore from my workplace. Been like that for a few weeks now.
      07-06-2024, 12:23 PM   #13
apptest
all I do is test!!6
apptest's Avatar
If really for a few weeks then it makes you wonder if your work is blocking it
      07-06-2024, 01:58 PM   #14
TheMidnightNarwhal
3076
I know it's not blocked by like the firewall/website blocker. I get that workplace blocked page on other websites that are blocked. On E90 post it's different.
What happens is that the page just doesn't load, I get the web browser error page that can't reach/load the website, I can't remember the exact error code I'd have to check at work again and report back.
      07-06-2024, 02:00 PM   #15
apptest
all I do is test!!6
apptest's Avatar
Ok check again and let me know. Include your ip address and send it to me via pm
      07-10-2024, 09:18 PM   #16
M850i BSM
Drives: 2019 m850ix black sapphire met
I can comment on posts but I cannot see the pms. It shows me that I have 2 pms yet when I click on them the screen turns blurry almost immediately. Is this from my browser Brave or is it on the Bimmerpost side?
      07-10-2024, 09:27 PM   #17
M850i BSM
Originally Posted by apptest droid View Post
Strange, this is on the app or on your desktop?
On the app. I've checked my settings and don't see anything obvious that would cause this issue
      07-10-2024, 09:31 PM   #18
M850i BSM
I just checked the website and I get the same thing. It will load the pm but as soon as it comes up it turns blurry to where I can't make out any words. This is new as 2 days ago I could send pms and read them no problem.
      07-10-2024, 11:59 PM   #19
apptest
all I do is test!!6
apptest's Avatar
Ok it looks like its a bug on the app (not website). Ive corrected the bug, and will publish the fix on the app store within a few days.
Thanks! 👍
      07-11-2024, 01:21 AM   #20
M850i BSM
Thanks! 👍
If you still need it, I did a screen recorder of everything I mentioned. It also says no connection even though I'm logged in and I def have internet connectivity. I'm going to toggle wifi on and off to see if that changes anything. Thanks for the help!
apptest5567.50
      07-11-2024, 07:47 AM   #21
apptest
all I do is test!!6
apptest's Avatar
Let’s try the new version and see if it also helps with the connection issue. The two might be related. It usually takes only 1-2 days for an app update to get approval so hopefully it will be soon 👍
      07-13-2024, 06:47 AM   #22
apptest
all I do is test!!6
apptest's Avatar
Ok the new version is now available on the App Store which I believe fixes your problem 👍
