      05-18-2008, 06:28 PM   #1
mjovic
Drives: 135i
Please help with garage door opener
Any trick to getting the universal garage door opener to work? Mine won't seem to recognize!? BTW, I have a NEW 135i in my garage!!!!!! BSM w/coral interior, ZSP, ZPP, heated seats. W00t!!!! :headbang:
      05-18-2008, 06:50 PM   #2
3toM
Drives: 2013 335i EB Msport
I know on some garage openers you need to press a button on the opener to begin the process of allowing a new device to activate it. Then I believe you press the desired button in the car to be the opener and hold it until the two link up. I think - it's been awhile since I did mine.
      05-18-2008, 07:28 PM   #3
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
Try this link:
http://www.homelink.com/training/train.taf
Tom
      05-18-2008, 07:34 PM   #4
Zirenz2006
Zirenz2006's Avatar
Drives: G80 M3 Comp IOMG
On my 335i I had to press a button on the garage motor unit to get it to pair with the car. I couldn't pair it using the garage remote.
      05-18-2008, 07:51 PM   #5
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
I had issues too. I just kept trying to get the GDO remote to be learned from different distances. It turned out that GDO remote had to be about an inch from the mirror in my case. I did finally get the confirmation that it was learned. Once I got the confirmation, I just pressed the learn button on the GDO unit, and then hit that button on the mirror.. worked like a charm.
      05-18-2008, 11:28 PM   #6
mjovic
Drives: 135i
Yes, this worked for me too. Even though the manual says 4-12 inches, I too needed to have the transmitter about 1 inch away for it to register. Thanks for all the replies!!!
      05-18-2008, 11:28 PM   #7
mjovic
Drives: 135i
BTW, where can I get a nifty 1 addicts sticker?
      05-19-2008, 01:49 AM   #8
Dan203
Drives: 2016 340i xDrive
Most garage door openers built in the last 6-10 years will require the opener to learn the code of the car, rather then the car learning from the remote. It's a safety measure that uses some sort of rolling code system and minor encryption to prevent unauthorized remotes from opening your door.
Dan
      05-20-2008, 11:24 AM   #9
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I have the secret fix for this. :biggrin:
This has happened to me before, simply following the instructions and wipe all the codes from the car. Then try the process over again. For some reason, my 3 year old GDO wouldn't recognized the car until I did this. After that, I press the button on the GDO (puts it into learning mode) press the button you like in the car...presto.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      05-20-2008, 11:46 AM   #10
Tom K.
Tom K.'s Avatar
Was it just me, or is the BMW owner's manual somewhat unclear on this?
Tom
      05-20-2008, 12:08 PM   #11
Atorak
Drives: 2021 BMW M2 Comp
Originally Posted by Tom K. View Post
Awesome website, I'm going to try this when I get home. I hate the unsightly garage door opener I've had on my visor for a month.
      05-20-2008, 12:10 PM   #12
mistermojorizin
mistermojorizin's Avatar
40
Drives: 135i
do you guys find the homelink has less range than the garage door opener? any way to amplify its range? i want the door opened by the time i come down the block, lol
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production
      05-20-2008, 08:04 PM   #13
mchaskell
Traveler
Drives: 135i
The range on my Homelink is less than the remote.
135i SGM, Grey w/Grey Poplar interior.
      05-20-2008, 08:05 PM   #14
larryn
I can open my garage doors from a much further distance in my BMW than with the actual GDO remote.
      05-21-2008, 09:22 AM   #15
kfiducia
Happy 1er
32
Drives: 08 135i, 05 R6, 67 Camaro
If the unit is having trouble learning, it may also be helpful to try one of the secondary buttons on the original remote (Homelink told me they have a higher TX power) or replacing your batteries. Varying the distance also helps. If all else fails their customer service is one of the best I have experienced. They knew just how to fix the problem I was having. If you need more help, post your Make/Model of GDO as well as what the blinky lights are telling you.
      05-21-2008, 11:27 AM   #16
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I agree, my remote opens the garage from 4 times the distance the car does. Sometimes I need to be in my driveway to get the door to open.
      05-21-2008, 11:28 AM   #17
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Tom
Totally
      05-21-2008, 11:47 AM   #18
scs
Drives: 135i
hold down button 1 until it blinks quickly then press the button on the garage door remote repeatedly (keep the remote about 8" away from the home link). i had to do this several times before it snatched the code. next press the learn button on the garage door opener itself then hit the 1 button in the car, next hit the learn button again and all should be well
      05-21-2008, 12:53 PM   #19
Atorak
I can 100% confirm that this works! I had to hit the button on the garage door opener itself, then run inside the car, and hold the button I wanted using a "hold-release-hold-release" pattern every 2 seconds between holds, and it worked!
THANKS!
      06-20-2008, 12:41 AM   #20
sfAddict
Drives:
Getting Genie intellicode to work
I struggled with my genie intellicode remote, which is the really small one (see attached pic or http://www.amazon.com/Genie-GMI-3BL-...f=pd_rhf_p_t_1)
It would train at 1 inch away, but based on the code learned from the remote, homelink never was able to complete training via the receiver unit.
After many tries following the instructions exactly and repeatedly failing with it, I finally found an older, larger remote, and that one worked the first time around: 1. train 1 inch from homelink; 2. get on the ladder and press the train button on the receiver, and 3. press homelink button a couple of times.
Anyone else trying to train with a really small intellicode may want to find a bigger one to train with. Hope this helps some people out.
      08-05-2008, 01:14 AM   #21
jnynetwk
Drives:
thanks to everyone on this forum. I picked up my new car on Sunday and have been trying to program the damn Homelink for hours!
FYI... like many, I had to have my remote an inch from the mirror to recognize and then I had to hit the button on my Craftsman GDO, and then the homelink again. But that worked like a carm.
Thanks!
135i Convertible
Blue Water, Savanna Beige leather
Premium, Sport, Steptronic, Comfort Access, Heated Seats, Navigation, Premium Hi-fi, Satellite radio
www.gwolcast.net
      08-05-2008, 07:24 AM   #22
Lexington
Lexington's Avatar
53
Drives: 2008 135i Blue Water
I must have an older GDO, I simply took the remote opener with me when we did PCD and the SA programed it into the car. We did have to hold the remote about an inch from the mirror and with the remote facing the mirror the same as it would face the garage door.
1addicts
