| 08-13-2024, 10:55 PM | #1 |
![]() 180
Rep 67
G70 i7 alternative tire sizing
Our i7 xDrive60 with only 17K miles has already chewed through the front tires on both outer edges. The rears aren’t much better off. I have always kept the tires inflated actually slightly above the recommended PSI so I’m not sure why the edges of the tires would even be in contact with the road unless there’s some sort of severe alignment issue.
Anyway, there’s hardly any tires available in the 20” OE 255/285 staggered widths. I am thinking about going 265/45R20 front and rear because it opens up a lot of extra tire choices and would also mean no more half tire wear warranty issues. Has anyone gone to a square fitment on the 20” or 21” wheels? These Bridgestone LS100 tires have a very high tread wear rating which is typically a sign of long life, but it appears they can’t hold up to the weight of a 3 ton vehicle. It’s disconcerting the front tires would have already worn out and the rears are soon to be bald, too. I’ve had 4 EVs and none of them except a Model 3 Performance on Pilot Sport 4S which are known to have short lifespans came even close to wearing out this fast. 90% of our mileage is interstate driving. Tires were rotated twice in 17K miles. No pulling or other obvious signs of an alignment issue, but obviously something is up. One benefit typically of square sizing is that you can rotate front to back, but with the wheels being different widths and having different offsets it would appear that won’t be possible. As an alternative I’m looking at going down to 245/45R20//275/40R20 which has many more all season tires available with actual mileage warranties, something the Bridgestones do not offer. If anyone has made a change in sizing I would love to know your experience. |
| 08-14-2024, 12:49 AM | #2 | |
![]() 29
Rep 38
| 08-14-2024, 03:15 AM | #3 | |
![]() 180
Rep 67
Have you measured the tread on your tires to see if they’re wearing normally? I’ve seen a bunch of folks reporting the exact issue I had with the front tires wearing out on the outer edge but nobody specified what tire their car had, either the Bridgestone or Pirellis. |
| 08-14-2024, 07:37 PM | #4 | |
![]() 29
Rep 38
| 08-15-2024, 03:43 PM | #5 |
![]() 180
Rep 67
Our tires went from looking fine to worn out really fast. The fact both fronts wore out on the outer edges leads me to think it’s a tire issue, but also could be alignment. I bumped tire pressures up to 45PSI. Slightly firmer ride but the car gets much better efficiency on the highway. That’s why I’m also baffled the tires wore out so quickly. Lower pressure is usually the cause of premature wear on edges.
| 08-15-2024, 07:54 PM | #6 | |
![]() 29
Rep 38
| 08-17-2024, 02:04 PM | #7 |
![]() 180
Rep 67
That’s not the recommended pressures in the US. That’s very low PSI for a car that weighs this much, especially if energy consumption is a concern of yours. Look at Teslas or even Mercedes EVs, they all have high pressures specced for lower rolling resistance. The tires are rated up to 51PSI (cold). Mercedes and BMW also recommend increasing tire pressure if you are going to be driving at higher speeds as the lower rolling resistance means less friction and heat are generated.
| 08-18-2024, 01:58 AM | #8 |
![]() 2739
Rep 3,155
You are going to bend a rim the first pothole you see….why do you have them that low?
2025 X7 40i, 2024 I7 60i, 2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
| 08-19-2024, 01:38 AM | #9 | |
![]() 2739
Rep 3,155
For the i5....there literally is not 1 all season or winter option for the 21 inch OEM wheels and I researched changing tire sizes and it's not possible because the bigger issue is the load rating on the EV. Using a slightly different tire size would be under OEM specs and I don't want to risk that. So it's a legit no-go on the i5 M60. That brought me to the i7....I found this thread here... https://www.7post.com/forums/showthread.php?t=1987794 He was able to find a good size for the 21 inch wheels that would not rub and would have lots more tire options (and they all are good in terms of the load rating). So, that might be a starting point for you. We actually have an X7 and most of us X7 people have successfully gone to a square setup. We are running 285/40/22 when the OEM sizes are 275/40/22 and 315/35/22. Most of us have all been doing this since 2019 when the X7 came out and it's worked perfectly. So, your idea of maybe going 265/40/20 would be the same really as what we did on the X7 (meaning we all just got a 10mm wider than OEM front tire and used them for all 4 tires). I'm not saying it WILL WORK but theoretically it probably would. The trade-off is we are losing a little width in the back but it's not noticeable, at all.....we also have like 55k miles on our all seasons now and they still have good tread left so we've saved a ton versus switching out staggered tire sizes all the time on tires that wear out fast. Load index I would imagine won't be an issue....nor will front to back rolling circumference ratio in terms of X-Drive. So, you are 2 for 2 there. I don't have the 20 inch wheel specs in front of me....but make sure the 265 series tire will fit the rim width on the front and back. That was an issue I ran into for 1 tire size I thought might work as Plan B for the i5.....but then I realized the 1 larger tire size would actually be too wide for the front rim size on the i5 so that ruined that option for me. Then your only other real obstacle is making sure it doesn't rub anything.....but if 295 wasn't rubbing anything on the guy's 7 in the link above then I can't imagine you will have an issue with 265.
| 08-20-2024, 02:59 PM | #10 | |
![]() 180
Rep 67
| 08-20-2024, 04:05 PM | #11 |
![]() 2739
Rep 3,155
Yeah I’ve definitely encountered SUV tires in these sizes and have wondered if there actually is any difference between that and a “car” tire.
| 08-21-2024, 08:43 AM | #12 | |
![]() 180
Rep 67
I just dropped the car off for service at my local dealer and the guy said “I’ve got 3 other i7/7er here for tires today. These new ones are chewing through the tires to the cords at 12-15K miles.” |
| 08-12-2025, 09:48 AM | #14 |
![]() ![]() 96
Rep 384
BMW Recommended Tire Pressure Cold for i7 with 20-Inch wheels (as per label on the driver's door) is 36 PSI Front and 39 PSI Rear.
The BMW app gives you real time Recommended Tire Pressure depending on Tire Temp and those usually max's out at Front 38 PSI and Rear 41 PSI (warm tires). I am averaging approx. 2.8 mi/KWh to 3.3 mi/KWh on most drives (highway and city.) That equates to a range of 285 miles to 335 miles at 100%. BMW advertised range is between 296 miles to 311 miles. Last edited by F5506m; 08-12-2025 at 09:55 AM.. |
| 08-12-2025, 10:06 AM | #15 | |
![]() 2580
Rep 2,836
Conditions: 68 degF AC temp, auto fan speed medium speed; day-time driving only, ~90degF ambient, 38 PSI @21” wheels. |
| 11-11-2025, 08:10 PM | #16 | |
Rep 11
I maintain tire pressure about 2 to 3 psi above recommended level. I had the alignment checked and the front tires were within spect; rears were not. How ever there is no uneven wear on the rears. Only the fronts have both the edges on each tire, wearing out fast. I have a 2nd i7, which does not seem to have this problem. That one has good year run flats on it. Does the brand of tires make a difference? |
| 11-12-2025, 11:11 AM | #17 | |
![]() 180
Rep 67
| 11-12-2025, 11:21 AM | #18 | |
![]() 180
Rep 67
I would really like to talk to someone who is an alignment professional that could tell me how much adjustment could be made to the car’s alignment without drastically affecting handling and stability. These cars are destroying tires like nothing I’ve ever seen. Even Model S Plaids with 2X as much power don’t eat through all season touring tires in 10-15K miles like the i7. On the other end of the spectrum, big heavy full size luxury sedans like the Genesis G90 and S-Class also don’t seem to destroy tires this quickly. The EQS is just as big and heavy but people are getting 30K+ miles out of their sets of tires. |
| 11-17-2025, 02:58 PM | #19 | |
Rep 11
I am using Good year run flats on my 23 i7. Its OEM tires were the same. Perhaps put around 8k miles on new tires. I see no sign of wear on either of the edges. Ordered the same for my 24 i7 (currently has the factory bridgestone). Wheel alignment was done on this car, 2000 miles/2 months ago and the tires seem to be wearing down at both edges on the front two tires, even more rapidly after the alignment. You are on your 3rd set in 40k miles? Which model year i7 is yours? A friend has a 24 i7 with about 6.6k miles; no visible tire wear at the edges. |
| 11-17-2025, 07:32 PM | #20 | |
![]() 2580
Rep 2,836
I think the life of tires depend on the region and climate, and driving habbits. Summer tires in moderate lower-temp climate zones will not last long. All-season in very hot climates also will not last too long. |
| 11-18-2025, 11:02 PM | #21 |
Rep 16
Mine came with Bridgestone LS100s, and the fronts are basically toast now with outer edges looking like drifting tires (at 15k miles)
What sucks is BMW (and other brands like Mercedes) put lower thread tires on cars. For example my tires started at 8/32 when ideally they should have started at least at 10-11/32. I've previously had an EQS, and it went through tires as quick, actually even faster than the i7. Bought brand new set for rear and it only lasted 9k miles. I'm switching to 22 inch wheels now (265/35/22 and 295/30/22 size Toyo tires), so we will see how long they would last. |
| 03-17-2026, 10:25 AM | #22 | |
![]() 180
Rep 67
| Bookmarks |
