      01-16-2025, 02:41 PM   #1
BlkGS
BlkGS's Avatar
6369
Drives: BMW X5 M50i
What's the TDS of your water?
Ordered a TDS meter to check my water, trying to figure out how much DI I'll need.
My tap water came back at 273. I was seeing people saying their TDS was like, in the 50s on their city water, so I was a bit surprised to say the least. Going to be investing in a DI system for sure to try to get spot free finish, but had me curious just how bad our water actually is.
      01-16-2025, 03:34 PM   #2
louielouie
Drives: '18 F80
I'm in LA and my TDS is about 150. I have prefilters for carbon and sediment which gets you a little more efficiency. I change my resin about once a year, using only DI for final rinse while washing every or every other weekend. You'll likely have to change it closer to every 6 months or so.
Your best option is RO/DI with tanks but if you don't have a self priming pressure washer like a Kranzle, you'll need a pump. Gets more complicated as not all pressure washers play well with pumps.
      01-16-2025, 03:56 PM   #3
MPWRZME
Drives: 2021 M3 Competition
I am on a well and my TDS is 400-500. I have RODI which brings to 0. I use a 5 gallon container that gravity feeds an electric power washer for final rinse only.
      01-16-2025, 06:15 PM   #4
BlkGS
BlkGS's Avatar
6369
Drives: BMW X5 M50i
We just had a new sprinkler well dug out, something like 600' deep, it free flows water. I was curious so I checked it... 980ppm. That's sure to leave some.spots.
      01-17-2025, 06:04 AM   #5
jwmFcreek
Drives: Xm
I have 180 city water treated in a softener still … city water as a whole is harder water … but wash inside out of the sun so not a big issue i believe. Good luck
      01-17-2025, 07:05 AM   #6
Clarkie52
Clarkie52's Avatar
100
Drives: 24 M240i
Bought this just after Xmas.It has a carbon pre filter followed by 2 resin and also has a built in TDS meter.The filter can be by passed using the fitted valves on either side.Only used it once but it’s taken my ppm down from 70 to 0.
I only use the filter stage for the final rinse so should last well over 12 months.
Size:  126.6 KBName:  IMG_9018.jpeg
Size:  236.7 KBName:  IMG_9019.jpeg
Size:  297.0 KBName:  IMG_9020.jpeg
      01-17-2025, 10:50 AM   #7
TboneS54
YNWA
TboneS54's Avatar
Drives: '04 M3 6MT, '11 M3 DCT, '22 X7
Mine's 0
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
