| 08-09-2025, 04:34 PM | #1 |
![]() 246
Rep 226
PPF Headlight Prep
I'm going to put PPF on my headlights. There are a couple dings on the plastic lens. What the prep to make it smooth? 3000 grit sandpaper?
| 08-09-2025, 08:05 PM | #2 |
![]() 2114
Rep 2,776
3000 grit would be a final step, after using coarser to finer wet/dry grades & before wiping with isopropyl alcohol. Try one of the headlight restoration kits from a big box parts store to get them as smooth as possible for a good result with the PPF.
| 08-09-2025, 10:20 PM | #4 |
![]() 226
Rep 223
Are you just protecting from future dings?
The headlights can't be all that bad on a '23. I would just use a fine polish to get the road film off/shine them up and spray with what you would use for your tack solution to get rid of the polish residue. |
| 08-10-2025, 07:58 AM | #5 |
![]() 246
Rep 226
as I said, "couple". I'm assuming the plastic needs to be smooth or the film will enhance the imperfections. I have restored my wifes 2011 Mini Cooper headlights and they look brand new. I'll start with a clay bar and go from there
| 08-10-2025, 09:21 AM | #6 | |
![]() 4379
Rep 3,456
Regular paint polish will work. Just go super-gentle and super carefully since plastic is soft and will require way less pressure and time-on-target than paint. If you want something fancier, there are many plastic / headlight cluster polishing compounds (sold at AutoZone, Walmart, etc.). I would start with Griot's one: https://www.griotsgarage.com/plastic...Cm88oTW8&gQT=1 HTH, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
| Bookmarks |
