      08-10-2025, 09:13 AM   #1
jjkusaf
Deadhead
jjkusaf's Avatar
97
Drives: '26 50e and '25 Maverick
How to remove this? Goo gone?
Bought the X5 through a broker and the dealer (about 3.5 hours away) delivered it. I noticed these two areas on the lift gate (opposite sides at the same level)...but didn't think much about it. Figured they would remove easily during the first wash.
Boy was I wrong.
Would something like Goo Gone be safe. Any other ideas...I was able to remove some (in the first image)...but it took sooo long to do that plus I started to worry I might scratch the underlying paint.
      08-10-2025, 09:46 AM   #2
Frostynorth
Weirdo
Frostynorth's Avatar
Drives: 2011 e92 M3
Wouldn't use goo gone.
Maybe mineral spirits.
      08-10-2025, 12:32 PM   #3
eleven11
eleven11's Avatar
530
Drives: -F31-
Is it some type of adhesive residue? If so, I'd consider heat (hair dryer, heat gun) and experiment with rubbing alcohol, WD-40, and Goo Gone.
      08-10-2025, 12:53 PM   #4
erickonphoenix
erickonphoenix's Avatar
2429
Drives: F31 Gray 328xi, G20 330i
Always start with 70% isopropyl alcohol, then move down the order, bug remover, mineral spirit, after that you'll be in paint remediation territory. compound, clay bar etc
      08-10-2025, 12:57 PM   #5
mjj
Drives: 25 Z4 M40i / 26 Eray HTC
3M adhesive remover.
biz77281.00
      08-10-2025, 01:25 PM   #6
jjkusaf
Deadhead
jjkusaf's Avatar
97
Disregard...ended up using rubbing alcohol followed immediately by cheap car shampoo in hot tap water and a microfiber towel ... a little elbow grease and time and I was able to remove it.
No idea what it was...came with the car.
afadeev4379.00
      08-10-2025, 02:29 PM   #7
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
I'd try a little Adams Bug and Tar Remover, if it comes off then compound and polish. It may be smart to do a full detail and then ceramic coat.
      08-11-2025, 03:45 PM   #8
SteveGiant
Drives: 2018 M2 - LBB /6-spd / Exec.
This looks familiar. I get the same kind of drip on my M2 near the headlights. I believe it's some kind of waxy spray between the metal panels that liquifies when the car gets too hot. It's a PITA to clean and it comes back.
      08-21-2025, 10:17 AM   #9
MikeGreenwich
Drives: Mini F55 Cooper S 210
Be careful and test any products you use inside the car, preferably behind some carpet.
      08-29-2025, 12:05 PM   #10
Dan B
Drives: 2024 M440i xDrive Gran Coupe
I do not think he needs use compound unless he needs to do paint correction.
Also, if someone is asking for advice on removing a foreign substance, they probaly don't want to use compound. That is a quick way to damage the paint.
And OP, nothing meant by my statement, just need to be careful using rubbing compund.
