      08-26-2025, 10:52 AM   #1
starlights
Drives: G05 50i
Can I polish over after applying Dr Colorchip?
I am about to refresh my Ceramic on my vehicle hood, primarily because there are a few scratches that I want to address and I noticed some high spots that I missed when I applied ceramic previously.
I got Dr Colorchip but not sure what sequence to follow. I will first have to remove old graphene by orbital polisher. What should be my process thereafter?
Can I polish over Dr. Colorchip after application as final step to prepare for ceramic/graphene?
Thanks in advance for your guidance
      08-26-2025, 04:13 PM   #2
starlights
Drives: G05 50i
I will add more context to my question above. When watching some you tube videos about Dr. Colorchip, I recall that the suggestion was to apply Dr Colorchip after polishing as a final step. While that may be how it should be, I was wondering if the difference between polished areas and unpolished area where Dr Colorchip was applied would be accentuated by graphene or ceramic.....
Any harm polishing over the touched up area once it's dry ? (24-48 hours after touch up)? Will polishing pull out the touchup paint?
      08-26-2025, 05:22 PM   #3
Zig613
Zig613's Avatar
351
Drives: 2025 BMW Z4 30i
This may help answer your question. From the Dr Colorchip website…
WHAT IS THE PROPER PROCEDURE FOR DETAILING WITH DR. COLORCHIP PAINT?
Wash & dry the vehicle. Do any “hard” detailing first, like wet-sanding, compounding and buffing. Then use our paint. Follow up with standard waxing a week later. Refrain from using a circular buffing wheel and wool pad for at least 30 days. We suggest using a random-orbit buffer with a foam pad and quality compound at all times for the best, swirl-free results (rather than the circular buffer and wool pad.)”
Llarry30095.50
      08-26-2025, 05:32 PM   #4
starlights
Drives: G05 50i
Thanks! I guess I should have looked there first
So I guess it's true, not to polish over after touch up ...well for at least 30 days.... Thanks!
So maybe I just don't polish and ceramic around the touched up area for a while and proceed with the rest I suppose.
      08-26-2025, 05:41 PM   #5
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
Why not?
      08-27-2025, 12:28 AM   #6
afadeev
afadeev's Avatar
4379
Drives: F80 M3
Polish your hood first, then apply chip repair.
Let the new paint firm up fully (1-30 days, read the instructions), then you can treat it the same as any other painted surface of the car!
Highly unlikely to be necessary to go that far.
Depending on what exact ceremic coating you used, manyof consumer grade coatings will come off with a few rounds of acidic chemicals. Start with a nice acidic/strip-wash shampoo, follow-up with fallout/iron remover on one panel, and see where it gets you.
https://adamspolishes.com/products/a...h&_ss=e&_v=1.0
If that fails, only then would you you can escalate to Light Abrasive Removal (clay bar), or Heavy Abrasive Removal (polishing with a polishing or abrasive compound).
Easy to test - if the water stops beading on the paint - the ceramic coating is gone!
Yes, after it's fully dried!
HTH,
a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White)
'25 Lexus RZ (White/Blue)
      08-28-2025, 07:47 AM   #7
starlights
Drives: G05 50i
HTH,
a
Cool! Appreciate you sharing your knowledge as usual
      08-29-2025, 10:48 AM   #8
TboneS54
YNWA
TboneS54's Avatar
Drives: '04 M3 6MT, '11 M3 DCT, '22 X7
Polish yes (step 2)
Compound no (step 1)
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
