      08-26-2025, 12:18 PM   #1
goodyearwing1
goodyearwing1's Avatar
22
Drives: X7 2025 M60I
Gloss black wheel cleaning/HELP
Hey guys, so exactly like the title states, when are you having luck with breaking down brake Grime but not damaging the finish on the gloss black wheels…
Have tried Dark fury and also Diablo wheel cleaner from chemical guys…
These wheels will be the death of me lol
      08-26-2025, 02:21 PM   #2
stbm5
Drives: 2018 M5 DG
1. get low dust pads
2. learn to live with less than perfect appearing wheels
3. I use WheelX then just power wash it off, doesn't come out perfect but it's decent
tcphoto5214.00
      08-27-2025, 07:46 AM   #3
dudley@07726
dudley@07726's Avatar
340
Drives: 25 MB CLE53 Cab, 23 BMW M340i
I use Brake Buster as the spray cleaner. It's cheap and it works. No matter what cleaner you use, you have to agitate the wheels. Spraying them and then spraying water doesn't remove all the brake dust. If you are going to use brushes to clean the wheels, use only boars hair brushes. Any other will mar the finish.
2025 MB CLE53 AMG
2023 M340i X drive (Mineral White Metallic, Oyster Vernasca Leather, DAPP, Shadowline, PAP, Premium, Cooling & High Perf Tire, Adap M Susp, HK, Drive Recorder, Sensatec Dash)
      08-27-2025, 08:04 AM   #4
Phillies8008
Drives: BMWs, duh
2026 BMW Z4 M40i  [9.50]
2024 BMW i4 e40  [9.50]
2006 BMW Z4M  [10.00]
Ditto – Brake Buster works very well, in my experience. I've also ceramic coated my wheels, which makes the dust come off much easier – if it isn't too heavy, a quick rinse with my pressure washer along with a spray down of Brake Buster will often get enough of it off to be good enough until the next thorough wash.
      08-27-2025, 10:28 AM   #5
RussV
Drives: 2025 BMW M340i
I use Brake Buster then use Gyeon Wet Coat which helps in future cleaning.
      08-27-2025, 10:38 AM   #6
dudley@07726
340
I should have stated that my wheels are coated as well.
2025 MB CLE53 AMG
      08-27-2025, 10:40 AM   #7
BIGW0RM
"Distinguished Fellow"
BIGW0RM's Avatar
5190
Drives: Ice Cream Truck
2025 BMW G87 M2  [10.00]
2025 BMW G87 M2  [9.90]
Get some isweep IS2000 pads and your dust will drop 70%. Your pads will not squeal either (your OEM ones will eventually if they are not already). The dust the IS2000 make is much drier, and silvery in color. Its not at tacky/wet feeling as stock dust. It wipes off much easier.
2025 G87 M2 /// 2025 X5 40i X /// 2025 Ford Raptor 37
      08-27-2025, 01:12 PM   #8
I coat my 343M's with wax polish and wipe off to further delay the grey dust from the low dust TWR pads.
      08-29-2025, 07:14 AM   #9
USMC G2
USMC G2's Avatar
353
Drives: 2025 M4 Competition
Greetings,
I use a two step approach.
Step One
1. After driving 75 miles, the wheels need cleaning. Yes, sarcasm.
2. I rinse thoroughly with water, then spray heavy duty wheel cleaner from Griot’s Garage.
3. Agitate, brush, massage, clean with a variety of brushes…I typically dip the brushes in Car Wash and Wax soap from GG.
4. Rinse thoroughly.
5. Use my battery powered leaf blower to remove water.
6. Wipe wheels down with microfiber towel to remove any water or brake dust.
Step Two
1. The next day, use GG rinseless ceramic wash to go over each wheel, each spoke, each crevice and all lug nuts.
2. Wipe dry with another microfiber towel for a nice shine.
3. Apply copious quantities of tire shine for that show room finish.
4. Don’t drive the car for several days…but walk by it to admire the wheels.
5. Drive the car and wipe off the brake dust with detail spray.
Okay…a little sarcasm, but you get the point…the brake dust is incredible and cleaning the wheels is time consuming, but once clean…they look awesome.
Semper Fi
      08-31-2025, 11:20 AM   #10
JerseyM3
Drives: 2025 M3 Comp xDrive
Sonax Plus wheel cleaner and Wheel mitt by the Rag Company work the best.
      08-31-2025, 01:50 PM   #11
BruinMan
BruinMan's Avatar
238
Drives: BMW X5 M50i Unicorn
Originally Posted by USMC G2 View Post
Greetings,
Step One
Step Two
Semper Fi
Love your humor!!
1st: Change out the OEM brake pads to ceramic. It is an ez DIY project.
2nd: The advise above.
2021 BMW X5 M50i Tanzanite Blue II Metallic
USMC G2353.00
      08-31-2025, 05:28 PM   #12
allinon72
allinon72's Avatar
5835
Drives: 21' M5, 23' X1
Ceramic coating is a must. I like Armor Detail Supply wheel coating.
I use Brake Buster or Adam's Wheel Cleaner when washing (depending on how bad the dust is). Brake Buster is the milder of the two.
For maintenance in between washes I pressure wash with DI water and spray the rotors with Hyde's Ruststopper to prevent rotor rust. It at least makes then look 7/10.
Yes this is a big process but black wheels are a bitch.
      09-01-2025, 08:27 AM   #13
dudley@07726
340
Naples Auto Armour, who makes that product you mentioned, are the ones who coated my wheels.
2025 MB CLE53 AMG
      09-18-2025, 10:17 AM   #14
WytLytnyn
WytLytnyn's Avatar
78
Drives: 2023 AW G87
+1 for P+S Brake Buster. Tried Sonax on my black wheels and it didn't work as well and smelled like ass.
I've also heard good things about the Ethos wheel cleaner.
      09-23-2025, 07:22 AM   #15
Three Stents
Three Stents's Avatar
246
Drives: 2023 X5 sdrive40i M Sport PKG
I used Chemical Guys Decon Iron Remover and Sonax Plus yesterday on all wheels, removed them too. I found Sonax to be the better of the two. Ceramic coated them too. The inside of the wheels sure get beat up from tire change outs and balancing.
I'm from a small Wisconsin town. We didn't have a town drunk, we all took turns.
"Was it over when the Germans bombed Pearl Harbor?"
      11-07-2025, 11:03 AM   #16
WytLytnyn
WytLytnyn's Avatar
78
Drives: 2023 AW G87
Same here. Then use the leaf blower>microfiber drying procedure. As soon as its done, I spray them down with 303 Graphene Detailer and wipe them down with a different microfiber.
Its extra work but appears to have a minor effect on the dust that accumulates. You can't quite hose it it off and call it done but it is easier to get to a clean state on these damn wheels.
If I seem distracted, it is because I'm imagining I'm driving very twisty mountain roads at somewhat unlawful speeds......
      01-29-2026, 09:23 AM   #17
John in VA
Drives: 2015 228i M Sport
Originally Posted by XxCREAMxX View Post
Like you just swapped out the pads to ceramic or the whole brake system?
You only need to change to the ceramic pads (check Akebono for your application) to reduce the black dust.
      01-31-2026, 01:57 PM   #18
TimmyTurbos
Drives: 2017 M3 Comp
Thumbs up
Jesus..Sounds like you just need to swap to a full CCB set up..You can get very nice used sets for decent $ in the forums..Now I know you guys are gonna be like - That's just stupid, they're so expensive, too much for street use, yada, yada, yada..
My argument is you buy once, you cry once. Problem solved.
Or you clean your wheels every 3 days with all of these sprays, ceramic coats, special regiments, dinosaur hair brushes, microfiber this and that and the 3rd...At the end of the day you're still spending thousands on all these products and breaking your back over and over for the next 10 years of ownership..Just my 2c.
