| 08-26-2025, 11:48 PM | #1 |
Rep 526
BMW G70 Service Bulletin List
Here you will find all of the service bulletins BMW has submitted to NHTSA for the i7 and 7 series (G70). Bulletins usually take several weeks to appear in the NHTSA database after they are published internally in BMWTIS.
This thread will be updated with recent bulletins after they land at NHTSA and a reference is published here: https://itsanalogue.github.io/bmw-tsb/G70.html. You can find all of this information on the NHTSA website if you know where to look, but this is a consolidated list and should help search engines find and index the SIB PDFs faster. |
| 08-26-2025, 11:48 PM | #2 |
Rep 526
Recent Bulletins
SIB 61 02 26 (2026-04-23) BMW 740I 2024 ELECTRICAL SYSTEM In rare occasions, control of certain vehicle security functions via the Central Information Display (CID) is restricted for a short period of time. MC-11031567-0001.pdf SIB 32 03 26 (2026-04-23) BMW 740I 2024,2025 (plus 2 other models) STEERING “Groaning” noise from the EPS when the steering wheel is at the end stops. MC-11031564-0001.pdf SIB 31 04 26 (2026-04-23) BMW 740I 2023,2024,2025,2026 BMW I7 2023,2024,2025 STEERING SITUATION When turning the steering wheel fully to the steering end stops, a ”groaning” noise can be perceived at the respective steering stop. The noise occurs at higher ambient temperatures from approx. 68°F. MC-11031562-0001.pdf SIB 61 06 26 (2026-04-22) BMW I7 2024 (plus 3 other models) ELECTRICAL SYSTEM Charging sessions cannot be started or they are interrupted while using a Level 2 AC high-power charging station, or with a Level 3 DC charging station. Charging may start normally but can interrupt after some time. Level 2 (240 V) Flex Charger and Wall box may also be affected. The red or white LED is displayed on the high-voltage charging socket; however, no associated fault codes are stored. MC-11031568-0001.pdf SIB 12 05 26 (2026-04-10) BMW 740I 2024 (plus 1 other model) ELECTRICAL SYSTEM A “knocking” sound from the fuel tank area can be heard in the passenger area. Occurrence information below. 1. The noise occurs when the engine is at idle 2. The noise occurs sporadically 3. The noise disappears when the fuel filler cap is opened 4. The noise also disappears when the tank ventilation valve is disconnected There is no relevant fault saved in the fault memory. MC-11031571-0001.pdf SIB 61 03 24 (2026-04-09) BMW 750E 2024 BMW 750E XDRIVE 2026 BMW I7 2023,2024 BMW I7 EDRIVE50 2026 (plus 11 other models) ELECTRICAL SYSTEM Gen 5 BEV/PHEV vehicles may set the Combined Charging Unit (CCU) in programming abort due to no communication to the HV charge socket electronics. MC-11031576-0001.pdf SIB 31 03 24 (2026-04-08) BMW 740I 2023,2024,2025 BMW I7 2023,2024,2025 STEERING, SUSPENSION When rolling forward or backwards with the steering at full lock (left or right) without the brake applied, a “groan”-type noise may be heard from the front axle. The noise is most noticeable after load reversal. The noise can be heard beginning at the 7 second time stamp. MC-11031573-0001.pdf SIB 61 05 26 (2026-03-20) BMW 740I 2025 (plus 3 other models) VISIBILITY/WIPER Customers might report that washer fluid is leaking from the lower reservoir area, especially around thewasher fluid pumps. MC-11030307-0001.pdf SIB 12 03 26 (2026-03-19) BMW 740I 2023,2024,2025,2026 (plus 13 other models) ELECTRICAL SYSTEM, ENGINE, UNKNOWN OR OTHER PROGRAM CONTROL UNITS (OBD) MC-11030305-0001.pdf SIB 65 08 26 (2026-03-16) BMW 740I 2025 (plus 11 other models) ELECTRICAL SYSTEM After the software update to version …25-07-5XX, existing activation points for the “Automate My Habits”function no longer work. MC-11030312-0001.pdf SIB 12 05 23 (2026-03-06) BMW I7 2023,2024 (plus 3 other models) ELECTRICAL SYSTEM, POWER TRAIN The customer states there is a Drivetrain Malfunction message displayed in the instrument cluster. In addition, the following fault memory entries are saved in the CCU (Combined Charging Unit) 0317F2 - High-voltage system, insulation fault detected: when switch contactors are closed. 0317F1 - High-voltage system, insulation resistance below warning threshold: when switch contactors are closed. The fault memory entries (isolation faults) can occur both individually and in combination and must be traced back to the eDrive motor based on the ISTA test procedure. If ISTA test procedure lists possible cause of fault as; A metal chip is found behind the brush module (between the brush module and the end shield of the electrical machine). Repair required. Refer to service solution no. 20000794435083 in Aftersales Information Research (AIR). Follow information in the Procedure section below. MC-11030059-0001.pdf SIB 61 03 26 (2026-03-05) BMW 750E XDRIVE 2025 (plus 4 other models) ELECTRICAL SYSTEM Several complaints are possible: Vehicle does not start Gear cannot be engaged Various Check Control Messages Malfunction indicator lamp (MIL) on Several Check Control messages are possible: “It is possible to continue driving. High-voltage system.” “You can continue driving. Drivetrain.” “Restart not possible. Drivetrain fault.” “Call Roadside Assistance. Drivetrain failure.” “Information: Total error of vehicle.” The following fault memory entries are stored in the CCU: D796D9 - Message (- 0x91) not up-to-date, receiver CCU, transmitter EME D796DC - No message (- 0x91), receiver CCU, transmitter EME D796D8 - No message (- 0x91), receiver CCU, transmitter EME Other fault codes below may be stored in the EGS BA09B8 – Inverter, Voltage Sensor, 5V HV AUX: Out of range or open connection detected BA0A45 – ECU internal: Internal error of the synchronous serial data bus. Additional fault memory entries are possible. Similar fault memory entries indicating a missing EMEmessage (Traction E-Machine Electronic) can also be stored in other control units. MC-11030054-0001.pdf SIB 61 19 25 (2026-03-04) BMW 750E 2023,2024 BMW 750E XDRIVE 2025 (plus 5 other models) ELECTRICAL SYSTEM The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging,charging electronics 2, internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from …24-07-500 to …25-11-5xx. MC-11030053-0001.pdf SIB 61 23 25 (2026-03-04) BMW 750E XDRIVE 2025 (plus 6 other models) ELECTRICAL SYSTEM The malfunction indicator lamp (MIL) is triggered and 0318E2 AC charging, charging electronics 1,component protection: Overload current on AC side fault may be stored during AC charging Level 1(120 VAC). Note: Despite the fault memory entry (and the malfunction indicator lamp), the AC charging process willcontinue operating as designed and there is no related drivability complaint. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU-03 (7.4 kW combined charging unit). MC-11030051-0001.pdf SIB 61 22 25 (2026-03-03) BMW 750E XDRIVE 2025 (plus 5 other models) ELECTRICAL SYSTEM Malfunction indicator lamp (MIL) is triggered by the erroneous fault code(s) BA0023 - Control unit: internalfault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor:Signal implausible faults may be stored in the CCU memory. However, AC charging is still operating as designed, without any related drivability complaints. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx. MC-11030052-0001.pdf SIB 17 01 24 (2026-02-25) BMW I7 2023,2024,2025 (plus 4 other models) ENGINE, ENGINE AND ENGINE COOLING There is coolant leaking from under the car Low heater output Possible Check Control message “Drive, you can continue driving” (ID49) Possible fault codes stored in these BEV vehicles: 224163 – Electric auxiliary heater for the high-voltage battery unit: Undervoltage or internal communication fault 8049AA - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 80124F – Electric auxiliary heater: Communication in electric auxiliary heater faulty 224F60 - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 224111 - Cooling system for power electronics: Coolant loss detected 224107 - Cooling system for high-voltage battery unit, component protection: Detection of coolant loss MC-11029046-0001.pdf SIB 61 01 26 (2026-02-20) BMW 740I 2025 (plus 9 other models) ELECTRICAL SYSTEM During vehicle start-up the Secure Element (SE) of the BCP may fail causing communication errors. TheCheck Control message “Drive carefully. Driving stabilisation.” will appear. In addition, the fault memoryentries below will be stored within 40 seconds of each other. ACSM: 02010A - Coding: Coding data not qualified VIP: 02390A - VIP control unit: Coding data not released, signature IB: 02290A - DSC control unit: Coding data not released, signature HKFM: 020D0A - HKFM: Coding data are not qualified MC-11029070-0001.pdf RECALL 26V096000 (2026-02-19) Affecting 58713 total vehicles built between 2024-06-18 and 2025-04-09 BMW 750E XDRIVE 2024,2025 BMW I7 EDRIVE50 2024,2025 BMW I7 XDRIVE60 2023,2024,2025 (plus 6 other models) ELECTRICAL SYSTEM: WIRING BMW of North America, LLC (BMW) is recalling certain 2025 M5 Sportswagon, 2025-2026 M5, 2024-2025 750e xDrive, 2025-2026 550e xDrive, 2023-2025 I7, 2023-2025 7 Series, 2024-2026 i5, and 5 Series vehicles. The electrical wiring harness for the air conditioning system may become damaged during replacement of the cabin air filter. RCRIT-26V096-5013.pdf RCRIT-26V096-1695.pdf RCRIT-26V096-5504.pdf RCRIT-26V096-2065.pdf SIB 65 27 25 (2026-02-11) BMW 740I 2025,2026 (plus 14 other models) ELECTRICAL SYSTEM The vehicle may experience various operational issues with the infotainment system such as: Resets of the head unit Delayed start-up of the head unit (longer than 30 seconds) Failed start-up of the head unit Sporadic or permanent problems with navigation Sporadic or permanent Bluetooth connection problems Sporadic or permanent audio problems Sporadic or permanent speech / IPA (international phonetic alphabet) problems Missing displays, radio stations, camera images or applications MC-11028927-0001.pdf InVeh-InApp-Comm (2026-02-05) BMW I7 2023 (plus 2 other models) POWER TRAIN A manufacturing defect in a bearing of the electronic drive unit could result in bearing damage. This is caused by an unusual acoustic signal in the area of the drive unit. The bearing could fail completely at a later stage, which will be displayed to you by means of a red Check Control message. In this case, the driver is asked to call BMW Roadside Assistance. MC-11029009-0001.pdf SIB 51 19 24 (2026-01-22) BMW 740I 2024,2025 (plus 3 other models) VISIBILITY/WIPER There is a matte “veil” or milky stain on theexterior mirror glass. MC-11027991-0001.pdf SIB 65 20 25 (2026-01-15) BMW 740I 2025 (plus 12 other models) ELECTRICAL SYSTEM After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound. MC-11027777-0001.pdf SIB 61 24 25 (2026-01-03) BMW 740I 2025 (plus 1 other model) ELECTRICAL SYSTEM A limited number of 48 (V) volt vehicle batteries may have been damaged during the manufacturing process;this could lead to a premature battery failure. The 48 V battery may fail, triggering a corresponding Check Control message. MC-11027774-0001.pdf SIB 64 09 25 (2025-12-22) BMW I7 2023,2024,2025 (plus 3 other models) ELECTRICAL SYSTEM A faulty electric auxiliary heater may have been installed in the certain vehicles. This could result in thefailure of the electric auxiliary heater, utilized for the vehicle interior. MC-11026956-0001.pdf SIB 65 28 25 (2025-12-10) BMW 740I 2026 (plus 11 other models) ELECTRICAL SYSTEM The vehicle may experience various operational issues with the Multifunction Display such as: Intermittent black screen Permanent black screen Intermittent head unit functions not displayed (i.e., Navigation screen only is black) MC-11026964-0001.pdf SIB 16 01 24 (2025-11-12) BMW 740I 2025 (plus 7 other models) ELECTRICAL SYSTEM, FUEL SYSTEM, GASOLINE RSU availability. The engine cranks but will not start. MC-11025670-0001.pdf SIB 12 11 25 (2025-11-12) BMW 740I 2024,2025 (plus 1 other model) ELECTRICAL SYSTEM, ENGINE One or both of the following faults stored in the DME: 034AA5 - Mixture control bank 1, lambda regulation, mixture too lean 034AA8 - Mixture control bank 1, lambda adaptation, mixture too rich And additionally with the faults above, these affected vehicles may have one or more of the followingirregular combustion-related faults also stored: 033812 033813 033814 033815 033816 033817 033818 033819 MC-11025668-0001.pdf SIB 12 02 24 (2025-10-31) BMW 740I 2023,2024 (plus 5 other models) ENGINE, ENGINE AND ENGINE COOLING RSU availability. VOLUNTARY EMISSIONS RECALL 24E-A02: VALVETRONIC MC-11024709-0001.pdf SIB 65 25 25 (2025-10-10) BMW 740I 2025 (plus 8 other models) ELECTRICAL SYSTEM After the software update to I-level version …25-07-530, the Alexa app may disappear from the App Menu in the head unit (HU-H5). MC-11024727-0001.pdf SIB 84 06 25 (2025-10-03) BMW 740I 2023,2024,2025 (plus 18 other models) ELECTRICAL SYSTEM In some situations, an emergency call may be triggered in the vehicle without either the customer pressing the SOS Call button, or an airbag deployment event. In some cases, the customer may not even be inside the vehicle. MC-11024211-0001.pdf SIB 34 08 25 (2025-09-18) BMW 740I 2024,2025 (plus 10 other models) ELECTRICAL SYSTEM Starting from I-level …24-07-500, it is possible that the Automatic Hold function is not automatically storedfor the next journey. The function must be activated again by the driver at the beginning of every trip. After asoftware update to 25-03-500 and higher, this occurs more frequently. MC-11024205-0001.pdf SIB 11 05 25 (2025-09-18) BMW 740I 2025 (plus 4 other models) ENGINE Due to an assembly error the upper oil pan screws may not have been torqued correctly. MC-11023247-0001.pdf SIB 32 08 25 (2025-09-03) BMW 740I 2024,2025 (plus 4 other models) STEERING When the steering column is adjusted inwards towards the instrument cluster, the noise may occur near thelimit position. MC-11023248-0001.pdf SIB 11 07 25 (2025-08-28) BMW 740I 2025 ENGINE Due to an assembly error, the valvetrain could have a mechanical failure. MC-11022356-0001.pdf SIB 65 19 25 (2025-08-26) BMW 740I 2025 (plus 10 other models) ELECTRICAL SYSTEM Central Information Display (CID) in the vehicle is black or only displays “BMW”. The head unit (HU-H5) is not responding in ISTA. Additionally, the Receiver Audio Module (RAM), Instrument Cluster (KOMBI) and Telematic Module 4 (TCB4) may not be responding in ISTA. MC-11022856-0001.pdf SIB 41 04 24 (2025-08-20) BMW 740I 2025 (plus 13 other models) STRUCTURE: BODY A groaning sound from the front of the vehicle while driving can be heard, particularly while cornering. The groaning sound can be heard in the A-pillar/instrument panel area. MC-11022859-0001.pdf SIB 51 03 24 (2025-08-20) BMW 740I 2024,2025 (plus 5 other models) STRUCTURE: BODY While opening any of the doors, a groaning sound is heard from the door brake. Doors open and close stiffly. MC-11022103-0001.pdf SIB 63 10 23 (2025-08-19) BMW 740I 2024,2025 (plus 6 other models) EXTERIOR LIGHTING, EXTERIOR LIGHTING: TAIL LIGHTS, VISIBILITY/WIPER Condensation is present in the inner surface in one or both (inner and/or outer) taillamps. MC-11022112-0001.pdf SIB 11 06 25 (2025-08-04) BMW 740I 2024 (plus 2 other models) ENGINE Due to an assembly error, the oil pump screws may not have been torqued correctly. MC-11021816-0001.pdf SIB 64 04 25 (2025-07-30) BMW 740I 2025 (plus 2 other models) ELECTRICAL SYSTEM, STRUCTURE: BODY After performing a cabin air filter replacement maintenance service task, or after a similar repair thatrequired the removal and installation of the filter’s housing cover; the following air flap and/or air temperaturesensor faults are stored in the BCP: 80114D - Stepper motor: Unexpected error in Driving Cycle 801168 - Temperature sensor ventilation left or ventilation: short to ground 80116A - Temperature sensor ventilation right: short to ground 80116B - Temperature sensor ventilation right: short to plus or open circuit 80116C - Temperature sensor footwell left or footwell: short to ground 80116D - Temperature sensor footwell left or footwell: short to plus or open circuit 80116E - Temperature sensor footwell right: short to ground 80116F - Temperature sensor footwell right: short to plus or open circuit 80435B - Stepper motors: short-circuit by mass MC-11021112-0001.pdf SIB 61 20 24 (2025-07-30) BMW 740I 2023 BMW I7 2023 (plus 1 other model) ELECTRICAL SYSTEM In the event of a voltage drop, comfort functions of the BMW interaction bar may fail and not respond. MC-11021111-0001.pdf SIB 63 04 18 (2025-07-21) BMW 740I 2024 (plus 47 other models) AIR BAGS, ELECTRICAL SYSTEM, EQUIPMENT, EXTERIOR LIGHTING, EXTERIOR LIGHTING: HEADLIGHTS: DAYTIME RUNNING LIGHTS: BULBS, VISIBILITY/WIPER One or more of the LED daytime running lights are dim or discolored. MC-11020927-0001.pdf SIB 61 01 25 (2025-07-18) BMW 740I 2024 (plus 2 other models) UNKNOWN OR OTHER During highly dynamic driving, washer fluid may be forced out of the windshield washer nozzles. This canlead to the washer fluid reservoir being completely emptied. MC-11020928-0001.pdf RECALL 25V470000 (2025-07-17) Affecting 136 total vehicles built between 2021-11-03 and 2024-02-14 BMW I7 2023,2024 (plus 2 other models) ELECTRICAL SYSTEM: PROPULSION SYSTEM: TRACTION BATTERY BMW of North America, LLC (BMW) is recalling certain 2022-2025 IX, 2023-2024 I7, and 2022-2023 i4 vehicles. The high-voltage battery cell modules may not have been assembled properly, resulting in stress on the module frame and possible module failure. SIB 66 03 25 (2025-07-14) BMW 740I 2023,2024,2025 (plus 10 other models) ELECTRICAL SYSTEM, STRUCTURE: BODY Check control message is displayed indicating the parking assistance systems have limited functionality dueto errors detected within PDC sensors. The warning indicates parking assistance features have limitedfunctionality while the errors continue to be detected. Following faults may be stored 8031BA Ultrasonic Sensor Rear Side Left Software Error 8031CO Ultrasonic Sensor Rear outer left Software error 8031AE Ultrasonic Sensor Rear Outer Right Software Error 8031A8 Ultrasonic Sensor Rear Side Right Software Error 8031B4 Ultrasonic Sensor Rear Middle Right Software Error 8031C6 Ultrasonic Sensor Rear Middle Left Software Error MC-11020916-0001.pdf SIB 34 10 25 (2025-07-14) BMW 740I 2025 (plus 9 other models) SERVICE BRAKES After programming from the I-Levels between …24-03-505 and lower than …24-03-540 to I-Level …24-11-530 or higher, the following CCM may be displayed: “CCM-2525: Brake system. Drive at moderate speed” MC-11020910-0001.pdf SIB 61 33 23 (2025-07-03) BMW I7 2023,2024 (plus 1 other model) ELECTRICAL SYSTEM The Combined Charging Unit (CCU) may not have been built to specifications. MC-11020915-0001.pdf SIB 11 03 25 (2025-07-01) BMW 740I 2024 BMW 760I 2025 (plus 4 other models) ENGINE The “Check Engine Oil Level” warning is displayed while driving due to one of the following: Shortly after a detailed measurement has been carried out Shortly after engine oil has been topped up Shortly after an engine oil service has been carried out MC-11020906-0001.pdf SIB 41 05 25 (2025-06-27) BMW 740I 2024 BMW I7 2024 (plus 7 other models) ELECTRICAL SYSTEM, STRUCTURE: BODY While attempting to fuel/charge the vehicle,the fuel/charge door will not open. MC-11020066-0001.pdf SIB 52 08 25 (2025-06-17) BMW 740I 2024 SEATS The rear seat leg rest can fold down when a heavy load/weight is placed on it. MC-11020067-0001.pdf RECALL 25V395000 (2025-06-16) Affecting 71286 total vehicles built between 2021-02-04 and 2024-01-16 BMW I7 2023,2024 (plus 5 other models) ELECTRICAL SYSTEM: PROPULSION SYSTEM: TRACTION MOTOR: CONTROLLER: SOFTWARE BMW of North America, LLC (BMW) is recalling certain 2022-2025 i4, 2022-2024 IX, 2023-2024 I7, and 2024 I5 vehicles. The electric drive motor software may shut down the high-voltage system, causing a loss of drive power. RCRIT-25V395-8044.pdf SIB 34 07 25 (2025-06-11) BMW 740I 2025 BMW I7 2025 (plus 3 other models) SERVICE BRAKES A loud “click”- type noise can be heard from the rear axle brakes when driving off forwards, and/or in reverse. MC-11019564-0001.pdf SIB 34 04 25 (2025-06-11) BMW 740I 2023,2024 (plus 9 other models) ELECTRICAL SYSTEM, SERVICE BRAKES As a result of a data input error, certain fault memories are permanently stored. The permanent storage offault memories does not comply with the legal specifications of the authority (California Air Resources Board– CARB). The fault has no effect on the use of the vehicle by the customer. MC-11019563-0001.pdf SIB 12 04 25 (2025-06-11) BMW 740I 2023,2024,2025 (plus 12 other models) ELECTRICAL SYSTEM EMISSIONS RECALL 25E-A02: PROGRAM CONTROL UNITS MC-11019554-0001.pdf SIB 27 02 20 (2025-06-06) BMW 740I 2023,2024,2025 (plus 39 other models) LANE DEPARTURE, POWER TRAIN, WHEELS There is a jerking or shuddering during either or both of the following: Cornering or accelerating from low speeds Driving with low to medium loads MC-11019579-0001.pdf SIB 64 06 25 (2025-06-06) BMW I7 2024 (plus 2 other models) ENGINE, UNKNOWN OR OTHER A faulty electric auxiliary heater may have been installed in the certain vehicles. This could result in the failure of the electric auxiliary heater. MC-11019570-0001.pdf SIB 65 35 24 (2025-06-03) BMW 740I 2025 (plus 14 other models) ELECTRICAL SYSTEM Customers may report that the Central Information Display (CID) side of the Multifunction Display flickersonce on and off. This flickering is not continuous but may occur once every 15 to 50 seconds. No fault memory entry is stored for this customer complaint. MC-11019580-0001.pdf SIB 54 04 25 (2025-06-02) BMW 740I 2025 (plus 2 other models) ELECTRICAL SYSTEM The Sky Lounge sunshade does not open/close. Concern may be intermittent. The following fault codes are stored in the FZD (Roof Centre Function) control module during a vehicle test: 0302A0- ESH (electrical sunshade): No standardization system 03029C- ESH (electrical sunshade): No init because boundary conditions not valid (motordiver) MC-11019567-0001.pdf SIB 66 07 25 (2025-05-30) BMW 740I 2024 (plus 15 other models) ELECTRICAL SYSTEM The speed limit warning adopted speed, which is set by the customer, is automatically reverting to lowervalue after an extended duration of the sleep cycle. MC-11018732-0001.pdf SIB 12 06 25 (2025-05-22) BMW 740I 2024 FUEL/PROPULSION SYSTEM The electrical connector for the bank 1 high pressure pump may not have been locked correctly. MC-11018545-0001.pdf SIB 65 15 25 (2025-05-20) BMW 740I 2024 (plus 9 other models) ELECTRICAL SYSTEM When initiating a phone call to a specific saved contact, Intelligent Personal Assistant may not be able tolocate the contact or may call the incorrect contact. MC-11018549-0001.pdf SIB 01 04 25 (2025-05-19) BMW 750E 2023 (plus 4 other models) ENGINE The high-voltage battery assemblys refrigerant circuit expansion valves limited warranty for defects in materials and/ or workmanship has been extended to 15 years / 150,000 miles as determined from theoriginal first in-service / delivery date. MC-11018560-0001.pdf SIB 84 02 25 (2025-05-13) BMW 740I 2024 (plus 12 other models) ELECTRICAL SYSTEM When making phone calls via BMW Bluetooth (not Apple CarPlay) in the vehicle, the person in the calloutside the vehicle hears a distorted voice reproduction. MC-11018554-0001.pdf SIB 65 09 25 (2025-05-08) BMW 740I 2024 (plus 9 other models) ELECTRICAL SYSTEM Customer may complain that Projected Modes (Apple CarPlay/Android Auto) do not connect in the vehicle. Itis found that the WiFi in the vehicle is also not active and cannot be turned on. MC-11018546-0001.pdf SIB 32 02 25 (2025-05-02) BMW 740I 2024,2025 BMW I7 2024,2025 (plus 4 other models) STEERING Parts of the steering shaft universal joint may have been joined together without having beengreased. As a result, there can be audible squeaking and cracking noises. In some cases, moresteering force is required. MC-11018513-0001.pdf SIB 34 01 25 (2025-03-27) BMW 740I 2025 (plus 2 other models) SERVICE BRAKES The parking brake actuator cannot be activated or deactivated due to a failed weld. Check Control message “Parking brake failed. When parking, secure the vehicle against rolling away. Mustbe checked by the Service Partner.” The vehicle is still held by the unaffected side and the transmission lock. MC-11016432-0001.pdf SIB 61 03 25 (2025-03-05) BMW I7 2023 (plus 2 other models) ELECTRICAL SYSTEM This is an informational bulletin regarding Plug & Charge function complaint diagnosis. Possible customer complaints: Plug & Charge menu does not appear in the vehicle, function not available Problems with the configuration, for example: Contracts cannot be installed Fault / problems when attempting charging with Plug & Charge Plug & Charge contract disappeared Plug & Charge payment method expired MC-11015537-0001.pdf SIB 62 02 25 (2025-02-26) BMW 740I 2024 (plus 4 other models) UNKNOWN OR OTHER For certain model vehicles with the S68T engine, the Condition Based Service (CBS) data may show sparkplug replacement is due at a considerably “earlier” interval than specified in the Service and WarrantyInformational Booklet. MC-11014663-0001.pdf SIB 61 30 23 (2025-02-25) BMW 740I 2023 BMW I7 2023 (plus 1 other model) ELECTRICAL SYSTEM, EQUIPMENT In the event of a voltage drop, comfort functions of the interaction bar may fail and not respond. MC-11014515-0001.pdf SIB 51 04 25 (2025-02-22) BMW 740I 2025 (plus 4 other models) STRUCTURE: BODY BMW Service Action - Tailgate Lock B51 04 25 MC-11014969-0001.pdf SIB 11 07 23 (2025-02-20) BMW 740I 2023,2024 (plus 5 other models) ENGINE, ENGINE AND ENGINE COOLING, ENGINE AND ENGINE COOLING: EXHAUST SYSTEM The return springs on the exhaust camshaft followers (switchable rocker arm) may break. MC-11014420-0001.pdf SIB 51 08 24 (2025-02-14) BMW 740I 2024 (plus 9 other models) UNKNOWN OR OTHER The Augmented Reality Camera (ARCAM) shows up blurry when activated. MC-11014509-0001.pdf SIB 52 02 25 (2025-02-12) BMW 740I 2024 (plus 1 other model) ELECTRICAL SYSTEM The electric front seat adjustment does not work. The problem can occur to the left, as well as the right seat. MC-11014511-0001.pdf SIB 51 04 25 (2025-02-07) BMW 740I 2025 (plus 4 other models) STRUCTURE: BODY Due to changes in the opening mechanism ofthe trunk/tailgate latch, it is possible that thetrunk/tailgate may not completely lock afterclosing it. MC-11014036-0001.pdf SIB 52 01 25 (2025-02-04) BMW 740I 2023 ELECTRICAL SYSTEM The customer sees various check control warnings of 'Drive Fault', along with windows, doors, and seatsthat do not function. There may be restraint system check control warnings. The entire K-CAN9 / Body3 CAN bus may not communicate. Various fault memory entries for the above-mentioned components may be stored: 930D86 - Function restraint system driver restricted. 930D87 - Function front passenger restraint system restricted. C9544D, C9544F - Message Missing C95452, C95454 - Signal invalid 035BF4, 035BFB, 035BFC, 035BFD - Communication via Body3_CAN corrupt. CD052C, E3852C, E4852C, E3452C, E4452C, DF852C, DFC52C, DDC52C, DF452C, E6052C, E5852C- BODY3-CAN Control Module Bus OFF 802A00, 802E00, 802C00, 803000 - Functions seat heating not available 803003, 802C03, 802E03, 802A03 - Functions seat adjustment limited MC-11014039-0001.pdf SIB 51 46 16 (2025-02-03) BMW 740I 2023,2024 BMW 760I 2023 BMW I7 2023 (plus 70 other models) STRUCTURE: BODY, STRUCTURE: BODY: TAILGATE Upon opening and closing the tailgate, a creaking/groaning sound can be heard from tailgate actuator. MC-11014038-0001.pdf SIB 34 01 24 (2025-01-29) BMW 740I 2024 BMW I7 2024 (plus 8 other models) ELECTRICAL SYSTEM, SERVICE BRAKES After replacement of the Integrated Braking system (IB)/Power Brake the total distance covered might be lower than when handed over to the workshop for the repair. MC-11013438-0001.pdf SIB 12 06 24 (2025-01-29) BMW 740I 2024 (plus 4 other models) ENGINE BMW AG has decided on a service campaign for certain vehicles from the G0x, G12 and G20 series. Please have the starter motor checked and, if necessary, replaced in the vehicles concerned (according to the vehicle identification number selection) if possible before vehicle delivery. If vehicles have already been delivered, please have the measure carried out the next time the vehicles enter the workshop. A bolting fault on the long bolt screws can cause the magnets in the starter motor to twist. As a result, the power of the starter motor decreases. As a result, the engine does not start. MC-11013434-0001.pdf SIB 35 01 23 (2025-01-24) BMW 740I 2024 BMW I7 2024 (plus 1 other model) SERVICE BRAKES When the brake pedal is pressed/ released, a creaking noise may be heard from the pedal area for the Integrated Brake System (IB). This noise may be present with the vehicle stationary and the engine running. MC-11013115-0001.pdf SIB 11 10 24 (2025-01-24) BMW 740I 2023,2024 (plus 3 other models) ENGINE The engine oil pump mounting screws may not have been tightened with the correct torque. MC-11013114-0001.pdf SIB 65 02 25 (2025-01-14) BMW 740I 2025 (plus 7 other models) UNKNOWN OR OTHER If the Head-Up Display (HUD) is deactivated when Navigation View is selected, upon reactivation the Head-Up Display (HUD) will revert to the Standard View. This is most noticeable when the Head-Up Display (HUD) deactivates for automatic mandatory reasons, such as rear camera activation or emergency call activation. MC-11013062-0001.pdf SIB 63 04 24 (2025-01-10) BMW 740I 2025 (plus 4 other models) ELECTRICAL SYSTEM After the vehicle has been programmed with either RSU (Remote Software Update) or ISTA (I-Level 24-07-5xx), the ambient light on the door panel speakers will only illuminate in white. MC-11013053-0001.pdf SIB 32 01 25 (2025-01-10) BMW 740I 2024 (plus 3 other models) STEERING Rumbling, groaning type noises from the EPS when the steering wheel is at the end stops. MC-11013039-0001.pdf SIB 61 11 24 (2025-01-07) BMW 740I 2023,2024 BMW 750E 2024 BMW 760I 2023,2024 (plus 12 other models) ELECTRICAL SYSTEM After performing a BMW Remote Software Upgrade (RSU), the functionality of the Comfort Access and Passive Go/Exit features may be reduced. MC-11013050-0001.pdf SIB 61 01 24 (2025-01-06) BMW 740I 2023,2024 BMW I7 2023,2024 (plus 6 other models) EQUIPMENT, STRUCTURE: BODY, UNKNOWN OR OTHER When driving over rough surfaces, a low-frequency rattling noise can be heard inside the vehicle's cabin. The noise typically sounds as though it is coming from the front right footwell area. MC-11013049-0001.pdf SIB 06 01 25 (2025-01-04) BMW 740I 2024 STEERING SWIVEL JOINT RETURN MC-11013107-0001.pdf SIB 65 38 24 (2024-12-13) BMW 740I 2024 (plus 7 other models) ELECTRICAL SYSTEM Customers may report issue with Personal eSIM operation, to include: Personal eSIM does not finish the set-up process in the vehicle Telephone function via eSIM is not possible WiFi Hotspot function cannot be used Streaming video service via the BMW Theater Screen is not possible MC-11012099-0001.pdf SIB 65 36 24 (2024-12-13) BMW 740I 2024 (plus 4 other models) ELECTRICAL SYSTEM Customers may report issue with Personal eSIM operation, to include: Personal eSIM does not finish the set-up process in the vehicle Telephone function via eSIM is not possible WiFi Hotspot function cannot be used Streaming video service via the BMW Theater Screen is not possible MC-11012097-0001.pdf SIB 64 11 24 (2024-12-09) BMW I7 2023,2024 (plus 2 other models) ELECTRICAL SYSTEM Quality checks have determined that the coolant changeover valve may develop a coolant leak undervery low outside temperatures (significantly lower than 32º F (0 C)). MC-11012093-0001.pdf SIB 84 04 24 (2024-12-06) BMW 740I 2024 (plus 8 other models) ELECTRICAL SYSTEM Customers may report issue with Personal eSIM operation, to include: Personal eSIM does not finish the set-up process in the vehicle Telephone function via eSIM is not possible WiFi Hotspot function cannot be used Streaming video service via the BMW Theatre Screen is not possible MC-11012103-0001.pdf SIB 51 29 24 (2024-12-05) BMW 740I 2023 (plus 5 other models) STRUCTURE: BODY The tailgate/trunk will not latch when closed. MC-11012082-0001.pdf SIB 11 08 24 (2024-11-22) BMW 740I 2024 (plus 3 other models) ENGINE Delivery Stop Check PCV System MC-11010891-0001.pdf SIB 16 02 24 (2024-11-15) BMW 740I 2024 (plus 1 other model) FUEL/PROPULSION SYSTEM There may be a restriction in the low-pressure fuel line at the tank flange for the in-tank delivery pump (lowpressure pump). As a result, the required fuel flow volume is not available. If there is an insufficient supply offuel (even if only for a very brief period), the high-pressure pump might suffer preliminary damage. Inaddition, in the event of a fault, there might be a power reduction or “jerking” motions while driving. MC-11010757-0001.pdf SIB 24 03 24 (2024-11-14) BMW 750E 2024 (plus 4 other models) ELECTRICAL SYSTEM Electric driving: A power reduction while electric driving Electric driving is not possible even though the high voltage (HV) battery is sufficiently charged Starting of the internal combustion engine (ICE): There is a noticeable cutting in of the ICE when it starts The cutting in of the ICE is slower Check Control Message (#2390): “Engine is starting… Please wait.” The possibility of the electric drive not starting the ICE Hybrid Driving: Reduced acceleration Jolts during upshifts Delays during downshifts Possible stored fault codes- EGS-EME: 039A2A – EGS-EME, temperature sensor, coolant: Excess temperature 039A2B – EGS-EME: Excess temperature BA0842 – EGS-EME, temperature sensor, coolant circuit: upper threshold value exceeded BA0845 – EGS-EME, temperature sensor, coolant circuit: Gradient implausible DME: 034D5C – Cooling failed: Inverter MC-11010756-0001.pdf SIB 51 27 24 (2024-11-04) BMW 740I 2024 (plus 9 other models) ELECTRICAL SYSTEM The Ethernet bus of the Body Domain Controller (BDC) is interrupted so that audio output, rear viewcamera, or the driver assistance systems fail. The symptoms begin to appear during auto locking at approx.10 mph, or after the Central Locking button is activated. Dependent upon vehicle equipment, the following permanent SAE faults may be stored in the vehicle: S 0219, No Communication possible with: Amplifier S 0261, No Communication possible with: Camera-based driver assistance S 0273, No Communication possible with: Headunit S 0313, No Communication possible with: All-round vision camera S 0386, No Communication possible with: Instrument Panel S 0394, No Communication possible with: Telematics control unit MC-11010762-0001.pdf SIB 41 08 24 (2024-11-04) BMW 740I 2024 STRUCTURE: BODY DELIVERY STOP: REAR BUMPER BRACKET MC-11010761-0001.pdf SIB 34 03 24 (2024-10-11) BMW 740I 2024 BMW I7 2024 (plus 8 other models) SERVICE BRAKES Improved diagnostic software for the brake system. MC-11008992-0001.pdf SIB 61 24 24 (2024-10-10) BMW 740I 2024 (plus 2 other models) UNKNOWN OR OTHER Small debris may accumulate inside the volume control thumbwheel of the iDrive Controller. Existing gaps between the glass application and the light guide could allow external debris to enter inside the volume thumbwheel under normal usage. This debris can be seen through the crystal volume thumbwheel, giving the appearance of a cosmetic defect with the thumbwheel itself. Active lighting makes this debris more visible when illuminated. This could make the false illusion of a cosmetically defective volume thumbwheel more visible (many small dark spots or streaks). MC-11008996-0001.pdf RECALL 24V739000 (2024-10-02) Affecting 11579 total vehicles built between 2022-11-12 and 2023-10-18 BMW 740I 2023,2024 BMW 750E XDRIVE 2024 BMW 760I XDRIVE 2023,2024 BMW I7 EDRIVE50 2024 BMW I7 M70 2024 BMW I7 M70 XDRIVE 2023 BMW I7 XDRIVE60 2023,2024 (plus 9 other models) ELECTRONIC STABILITY CONTROL (ESC), SERVICE BRAKES, HYDRAULIC: POWER ASSIST: ELECTRIC: CONTROL MODULE BMW of North America, LLC. (BMW) is recalling certain 2023-2024 X1, X5, X6, X7, XM, 530i, i5, 740i, 760i, i7, and 750e vehicles. Please see the recall report for a complete list of models and model years. The integrated brake (IB) system may malfunction and result in a loss of power brake assist or cause the Antilock Brake (ABS) and Dynamic Stability Control (DSC) systems to not function properly. RCRIT-24V739-1109.pdf RCRIT-24V739-5692.pdf RCRIT-24V739-5275.pdf RCRIT-24V739-9702.pdf RCRIT-24V739-5310.pdf RECALL 24V714000 (2024-09-26) Affecting 982 total vehicles BMW 740I XDRIVE 2024 BMW 750E XDRIVE 2024 BMW 760I XDRIVE 2024 BMW I7 EDRIVE50 2024 BMW I7 M70 XDRIVE 2024 BMW I7 XDRIVE60 2024 (plus 5 other models) STEERING: LINKAGES: KNUCKLE: SPINDLE: ARM BMW of North America (BMW) is recalling certain 2024-2025 530i xDrive, 540i xDrive, 2024-2025 i5 eDrive40, i5 M60 xDrive, 2025 i5 xDrive40, 2024 740i xDrive, 760i xDrive, 750e xDrive, i7 eDrive50, i7 xDrive60, and i7 M70 xDrive vehicles. The steering spindle may break requiring a greater steering effort to control the vehicle. RCRIT-24V714-9650.pdf RCRIT-24V714-3745.pdf RCRIT-24V714-5744.pdf RCRIT-24V714-6996.pdf This is an automated post created with code written by a human. Last edited by analogue; 04-28-2026 at 06:19 PM.. |
| 01-23-2026, 07:32 AM | #3 |
Rep 526
New 2026-01-23
BMW 740I 2025 (plus 12 other models) ELECTRICAL SYSTEM After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound. MC-11027777-0001.pdf SIB 61 24 25 (2026-01-03) BMW 740I 2025 (plus 1 other model) ELECTRICAL SYSTEM A limited number of 48 (V) volt vehicle batteries may have been damaged during the manufacturing process;this could lead to a premature battery failure. The 48 V battery may fail, triggering a corresponding Check Control message. MC-11027774-0001.pdf SIB 61 23 25 (2026-01-03) BMW 750E 2025 (plus 4 other models) ELECTRICAL SYSTEM The malfunction indicator lamp (MIL) is triggered and 0318E2 AC charging, charging electronics 1,component protection: Overload current on AC side fault may be stored during AC charging Level 1(120 VAC). Note: Despite the fault memory entry (and the malfunction indicator lamp), the AC charging process willcontinue operating as designed and there is no related drivability complaint. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU-03 (7.4 kW combined charging unit). MC-11027773-0001.pdf SIB 61 22 25 (2026-01-03) BMW 750E 2025 (plus 4 other models) ELECTRICAL SYSTEM The malfunction indicator lamp (MIL) may be triggered by the erroneous fault code: BA0023 - Control unit: internal fault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor: Signal implausible faults may be stored in the CCU memory. However, AC charging will still operate as designed, without any related drivability complaints. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU_P1 (7.4 kW and 11 kW) with I-levels from …24-07- 500 to …25-11-5xx. MC-11027772-0001.pdf SIB 61 19 25 (2026-01-03) BMW 750E 2023,2024,2025 (plus 4 other models) ELECTRICAL SYSTEM SITUATION The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging, charging electronics 2,internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx MC-11027771-0001.pdf |
| 02-03-2026, 07:50 AM | #4 |
Rep 526
New 2026-02-03
BMW 740I 2024,2025 (plus 3 other models) VISIBILITY/WIPER There is a matte “veil” or milky stain on theexterior mirror glass. MC-11027991-0001.pdf |
| 02-24-2026, 07:59 AM | #5 |
Rep 526
New 2026-02-24
BMW 740I 2025,2026 (plus 14 other models) ELECTRICAL SYSTEM The vehicle may experience various operational issues with the infotainment system such as: Resets of the head unit Delayed start-up of the head unit (longer than 30 seconds) Failed start-up of the head unit Sporadic or permanent problems with navigation Sporadic or permanent Bluetooth connection problems Sporadic or permanent audio problems Sporadic or permanent speech / IPA (international phonetic alphabet) problems Missing displays, radio stations, camera images or applications MC-11028927-0001.pdf SIB 61 01 26 (2026-02-02) BMW 740I 2025 (plus 8 other models) ELECTRICAL SYSTEM SITUATION During vehicle start-up the Secure Element (SE) of the BCP may fail causing communication errors. TheCheck Control message “Drive carefully. Driving stabilisation.” will appear. In addition, the fault memoryentries below will be stored within 40 seconds of each other. ACSM: 02010A - Coding: Coding data not qualified VIP: 02390A - VIP control unit: Coding data not released, signature IB: 02290A - DSC control unit: Coding data not released, signature HKFM: 020D0A - HKFM: Coding data are not qualified MC-11028925-0001.pdf |
| 02-25-2026, 07:56 AM | #6 |
Rep 526
New 2026-02-25
Affecting 58713 total vehicles built between 2024-06-18 and 2025-04-09 BMW 750E XDRIVE 2024,2025 BMW I7 EDRIVE50 2024,2025 BMW I7 XDRIVE60 2023,2024,2025 (plus 6 other models) ELECTRICAL SYSTEM: WIRING BMW of North America, LLC (BMW) is recalling certain 2025 M5 Sportswagon, 2025-2026 M5, 2024-2025 750e xDrive, 2025-2026 550e xDrive, 2023-2025 I7, 2023-2025 7 Series, 2024-2026 i5, and 5 Series vehicles. The electrical wiring harness for the air conditioning system may become damaged during replacement of the cabin air filter. |
| 02-27-2026, 07:46 AM | #7 |
Rep 526
New 2026-02-27
BMW I7 2023,2024,2025 (plus 4 other models) ENGINE, ENGINE AND ENGINE COOLING There is coolant leaking from under the car Low heater output Possible Check Control message ?Drive, you can continue driving? (ID49) Possible fault codes stored in these BEV vehicles: 224163 ? Electric auxiliary heater for the high-voltage battery unit: Undervoltage or internal communication fault 8049AA - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 80124F ? Electric auxiliary heater: Communication in electric auxiliary heater faulty 224F60 - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 224111 - Cooling system for power electronics: Coolant loss detected 224107 - Cooling system for high-voltage battery unit, component protection: Detection of coolant loss MC-11029046-0001.pdf |
| 02-27-2026, 11:53 AM | #8 | |
![]() 2580
Rep 2,835
| 02-27-2026, 04:21 PM | #9 | |
Rep 526
The air conditioning system’s electrical wiring harness will be inspected and, if necessary, replaced, and a retaining strap / bracket will be attached to the harness. |
| 02-27-2026, 07:38 PM | #10 | |
![]() ![]() ![]() 635
Rep 408
| 02-28-2026, 12:00 AM | #11 | |
![]() 2580
Rep 2,835
| 02-28-2026, 12:08 AM | #12 |
Rep 408
Customer notification isn't scheduled until April anyway. So unless dealers have it in their system that it's a recall job now and no longer just an open bulletin, they can't fix it for free for you because it will still show as "wait til next cabin air filter replacement" on their system.
| 02-28-2026, 12:51 AM | #13 | |
![]() 2580
Rep 2,835
| 03-08-2026, 01:14 PM | #14 |
Rep 310
My dealer called me and wanted me to bring my I7 I for the repair, but I refused and said they could do it when I needed to bring the car in for something else.
I have pretty much always enjoyed bringing my new cars in for servicing over the years, but find that with BMW, it just isn’t as interesting as it used to be. I so LOVE my I7, that driving much of anything else is a huge letdown. ![]() |
| 03-09-2026, 12:13 PM | #15 | |
![]() 2580
Rep 2,835
For the first time ever IN MORE THAN A DECADE, I no longer ever wake up on Saturdays/Sundays looking at autotrader, or have email alerts for certain car or models. I no longer look around for anything. There is no car on earth that I’d want to trade in with (well unless I want to put >200K + my car for a RR Spectre or Bentley phev). But in in the sub 200K MSRP range, EVEYRTHING is abosutelyl a huge letdown and downgrade. Am so spoiled with this car in a way I never thought I would. To make it even worse, even the other options that used to be great in the past, are now worse than ever before, exactly when 7 is becoming better than ever before. Last edited by BMW5and7; 03-09-2026 at 12:19 PM.. |
| 03-09-2026, 03:44 PM | #16 |
Rep 562
Definitely a personal emotional situation.
| 03-09-2026, 04:07 PM | #17 | |
Rep 310
BMW5and72580.00 |
| 03-14-2026, 08:35 AM | #18 |
Rep 526
New 2026-03-14
SIB 12 03 26 (2026-03-11)
BMW 740I 2023,2024,2025,2026 (plus 11 other models) ELECTRICAL SYSTEM BMW AG is conducting Voluntary Emissions Recall (effective March 11, 2026) on certain Model Year 2023 -2026 BMW vehicles that were produced between January 14, 2022, and September 16, 2025. MC-11030061-0001.pdf SIB 12 05 23 (2026-03-06) BMW I7 2023,2024 (plus 3 other models) ELECTRICAL SYSTEM, POWER TRAIN The customer states there is a Drivetrain Malfunction message displayed in the instrument cluster. In addition, the following fault memory entries are saved in the CCU (Combined Charging Unit) 0317F2 - High-voltage system, insulation fault detected: when switch contactors are closed. 0317F1 - High-voltage system, insulation resistance below warning threshold: when switch contactors are closed. The fault memory entries (isolation faults) can occur both individually and in combination and must be traced back to the eDrive motor based on the ISTA test procedure. If ISTA test procedure lists possible cause of fault as; A metal chip is found behind the brush module (between the brush module and the end shield of the electrical machine). Repair required. Refer to service solution no. 20000794435083 in Aftersales Information Research (AIR). Follow information in the Procedure section below. MC-11030059-0001.pdf SIB 61 03 26 (2026-03-05) BMW 750E XDRIVE 2025 (plus 4 other models) ELECTRICAL SYSTEM Several complaints are possible: Vehicle does not start Gear cannot be engaged Various Check Control Messages Malfunction indicator lamp (MIL) on Several Check Control messages are possible: ?It is possible to continue driving. High-voltage system.? ?You can continue driving. Drivetrain.? ?Restart not possible. Drivetrain fault.? ?Call Roadside Assistance. Drivetrain failure.? ?Information: Total error of vehicle.? The following fault memory entries are stored in the CCU: D796D9 - Message (- 0x91) not up-to-date, receiver CCU, transmitter EME D796DC - No message (- 0x91), receiver CCU, transmitter EME D796D8 - No message (- 0x91), receiver CCU, transmitter EME Other fault codes below may be stored in the EGS BA09B8 ? Inverter, Voltage Sensor, 5V HV AUX: Out of range or open connection detected BA0A45 ? ECU internal: Internal error of the synchronous serial data bus. Additional fault memory entries are possible. Similar fault memory entries indicating a missing EMEmessage (Traction E-Machine Electronic) can also be stored in other control units. MC-11030054-0001.pdf SIB 61 19 25 (2026-03-04) BMW 750E 2023,2024 BMW 750E XDRIVE 2025 (plus 5 other models) ELECTRICAL SYSTEM The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging,charging electronics 2, internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from ?24-07-500 to ?25-11-5xx. MC-11030053-0001.pdf SIB 61 23 25 (2026-03-04) BMW 750E XDRIVE 2025 (plus 6 other models) ELECTRICAL SYSTEM The malfunction indicator lamp (MIL) is triggered and 0318E2 AC charging, charging electronics 1,component protection: Overload current on AC side fault may be stored during AC charging Level 1(120 VAC). Note: Despite the fault memory entry (and the malfunction indicator lamp), the AC charging process willcontinue operating as designed and there is no related drivability complaint. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU-03 (7.4 kW combined charging unit). MC-11030051-0001.pdf SIB 61 22 25 (2026-03-03) BMW 750E XDRIVE 2025 (plus 5 other models) ELECTRICAL SYSTEM Malfunction indicator lamp (MIL) is triggered by the erroneous fault code(s) BA0023 - Control unit: internalfault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor:Signal implausible faults may be stored in the CCU memory. However, AC charging is still operating as designed, without any related drivability complaints. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx. MC-11030052-0001.pdf |
| 04-28-2026, 06:29 PM | #19 |
Rep 526
New 2026-04-28
SIB 61 02 26 (2026-04-23) BMW 740I 2024 ELECTRICAL SYSTEM In rare occasions, control of certain vehicle security functions via the Central Information Display (CID) is restricted for a short period of time. MC-11031567-0001.pdf SIB 32 03 26 (2026-04-23) BMW 740I 2024,2025 (plus 2 other models) STEERING “Groaning” noise from the EPS when the steering wheel is at the end stops. MC-11031564-0001.pdf SIB 31 04 26 (2026-04-23) BMW 740I 2023,2024,2025,2026 BMW I7 2023,2024,2025 STEERING SITUATION When turning the steering wheel fully to the steering end stops, a ”groaning” noise can be perceived at the respective steering stop. The noise occurs at higher ambient temperatures from approx. 68°F. MC-11031562-0001.pdf SIB 61 06 26 (2026-04-22) BMW I7 2024 (plus 3 other models) ELECTRICAL SYSTEM Charging sessions cannot be started or they are interrupted while using a Level 2 AC high-power charging station, or with a Level 3 DC charging station. Charging may start normally but can interrupt after some time. Level 2 (240 V) Flex Charger and Wall box may also be affected. The red or white LED is displayed on the high-voltage charging socket; however, no associated fault codes are stored. MC-11031568-0001.pdf SIB 12 05 26 (2026-04-10) BMW 740I 2024 (plus 1 other model) ELECTRICAL SYSTEM A “knocking” sound from the fuel tank area can be heard in the passenger area. Occurrence information below. 1. The noise occurs when the engine is at idle 2. The noise occurs sporadically 3. The noise disappears when the fuel filler cap is opened 4. The noise also disappears when the tank ventilation valve is disconnected There is no relevant fault saved in the fault memory. MC-11031571-0001.pdf SIB 61 03 24 (2026-04-09) BMW 750E 2024 BMW 750E XDRIVE 2026 BMW I7 2023,2024 BMW I7 EDRIVE50 2026 (plus 11 other models) ELECTRICAL SYSTEM Gen 5 BEV/PHEV vehicles may set the Combined Charging Unit (CCU) in programming abort due to no communication to the HV charge socket electronics. MC-11031576-0001.pdf SIB 31 03 24 (2026-04-08) BMW 740I 2023,2024,2025 BMW I7 2023,2024,2025 STEERING, SUSPENSION When rolling forward or backwards with the steering at full lock (left or right) without the brake applied, a “groan”-type noise may be heard from the front axle. The noise is most noticeable after load reversal. The noise can be heard beginning at the 7 second time stamp. MC-11031573-0001.pdf This is an automated post created with code written by a human. |
| Bookmarks |
