| 08-27-2025, 05:47 PM | #1 |
![]() ![]() ![]() 1598
Rep 434
Hello. I'm new here
![]() I recently purchased a 850i and the previous owner had some modifications done to it. I want to revert it back to OEM as much as possible while doing small tweaks here and there to make it a more drive-able vehicle. 5L V12, 6mt, with an LSD. Those are the basics. It came with "Deep dish Momo wheels" Pictures attached. I'm not at all familiar with 90s BMW "stuff". Are these wheels decent? should I be looking for something that fits more readily available tire sizes?
![]() '25 M4 CS Riviera Blue - '23 M4 XD SPY - '11 E92 M3 6MT - '00 E39 M5 6MT - '98 E38 750iL - '91 E31 850i 6MT |
| 08-27-2025, 08:51 PM | #2 | |||
![]() 4405
Rep 3,474
Congrats on a cool car. Condolences to your wallet, as all new E31 and E32 parts will be priced *10x by BMW, if even if available. Literally. More info here: https://bmwccae31.com/ Quote:
They are definitely NOT stock. However, if they are round and manage to keep the air in the tires, they are better than nothing already. Quote:
Depending on your budget and intended purposes, either getting OEM wheels (or clones), forged wheels (for durability and performance), or any wheels that fit desirable set of tires (summer performance? winters?). That would be the most reasonable starting point. HTH, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 09-09-2025 at 11:58 AM.. |
Gottagofast1598.00 DDDGGG_M604.50 |
| 08-27-2025, 09:36 PM | #3 | |
Rep 434
Mechanically, the car is great. It does have a bunch of non critical issues but it seems manageable. Here's the PPI report: "Steering wheel has play up and down, headliner sagging, horn not working, windshield washer sprayers weak pressure, 2 front jack pads missing, trunk liners redone, tires out of date (2012), FR tie rod end play, FR wheel bearing play, Front right and left thrust arms worn, upgraded sway bars front and rear, engine oil leak potentially from upper oil pan, rear left lower ball joint boot split, rear muffler rust holes, left rear shock mount previously repaired, fuel filters dated 2006, front left and right door paint bubbling, front right fender repainted, front bumper lip painted, valve cover gaskets x2 leaking, drivers seat bottom rear portion not operating, passenger seat lower bottom twist, front to rearward motors on passenger seat slow, passenger seat not folding forward, pass strut tower bolts potentially redrilled or slotted to fit shock" I looked at this site to determine original wheel size and specs, I hope it's correct: https://www.wheel-size.com/size/bmw/8-series/1991/ "7.5Jx16 ET15 Center Bore / Hub Bore: 72.5 mm Bolt Pattern (PCD): 5x120 Wheel Fasteners: Lug bolts Thread Size: M12 x 1.5" I need to determine the max tire size I can fit without rubbing, then I'll look for wheels.
W2k664.00 |
| 08-29-2025, 09:51 PM | #4 |
Rep 771
Nice Momo Quasar Wheels!!
Gottagofast1598.00 M-technik-34024.00 |
| 08-30-2025, 02:41 AM | #5 |
Rep 434
Cheers.
I decided on 18x8.5 fronts and 18x9.5 rears. I have a friend that is sponsored by Superspeed so we can order the wheels and test fitment. Debating between A-S 4 or EC DWS 06 Plus for longevity.
| 09-08-2025, 07:49 PM | #6 |
Rep 434
Delivery complete
| 09-09-2025, 10:36 AM | #8 |
![]() ![]() 695
Rep 395
Congrats! I remember seeing one while passing a dealership in the early 2000s. I turned in and parked my MKIII Toyota Supra next to it and took a pic, since they look related.
| 09-11-2025, 08:11 PM | #11 |
Rep 434
Yes. Good eye.
| 09-19-2025, 05:35 AM | #12 |
Rep 434
A nice family gathering.
| 12-24-2025, 12:21 AM | #13 |
Rep 5
Sick whip man! Love those wheels
Gottagofast1598.00 |
| 03-25-2026, 12:28 AM | #14 |
Rep 177
Nice looking car. The manual transmission version is especially sought after.
While this forum is good for a lot of things, if you want a superb resource for E31s, check out the E31 forum on bimmerforums.com. I’m not sure how I would have been able to keep my cars (yes, plural — a 1996 850Ci and a 1994 850CSi) on the road without the knowledge and assistance from that group. |
Gottagofast1598.00 TboneS541538.50 |
| Bookmarks |
| Tags |
| 1991, 6mt, 850i, e31, lsd, m70 |
