| 10-14-2025, 10:24 AM | #1 |
![]() 15
Rep 46
Door Upholstery Adhesive
This piece of fabric (black vinyl) has come unglued from my door.
What's a DIY method to get it re-adhered? What I've seen online is folks removing the entire door to reglue the panel which is outside of my toolset. |
| 10-14-2025, 10:45 AM | #2 | ||
![]() 4379
Rep 3,456
Good luck, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
| 10-14-2025, 02:48 PM | #4 | |
![]() 15
Rep 46
| 10-14-2025, 03:17 PM | #5 |
![]() 2114
Rep 2,776
I was not a fan of the (uncontrollable) expanding nature of original Gorilla Glue. I'd use DAP Weldwood Contact Cement gel. To use it, apply a coat to both surfaces, let it dry to a tack-free state (15-20 minutes), and then press the surfaces together firmly.
| 10-14-2025, 06:41 PM | #6 | ||
![]() 4379
Rep 3,456
You do want to put the weight on the areas you are gluing, and then wipe away the escaping glue around the edges. Which is easy. If you miss some, it solidifies into packing popcorn type of material that is easy to cut away. The key is keeping even pressure across the surface, and a bunch of books did the trick for me. Then some more books on top to add pressure. YMMV, a P.S.: I had tried 3-4 other glues before hand, and all failed. Gorilla Glue carried the day for me.
'15 F80 M3 (SO/SS)
| 10-14-2025, 06:52 PM | #7 |
![]() 824
Rep 1,115
Fabritac
John in VA2113.50 |
| Bookmarks |
