      11-14-2025, 11:53 AM   #1
kmr760i
Drives: 2025 760i
7k miles warped rotors needs all new brakes etc?
Took car in for service for pulsating feel while braking. Knew it would be the rotors. They are warped. They are saying from my aftermarket wheels which keep in mind have only been on 3k miles. They are a closed face more so but come on these are not going to cause the brakes to overheat and warp. Anyone else had issues?
      11-14-2025, 12:41 PM   #2
BMW5and7
BMW5and7's Avatar
2290
Drives: B8 Alpina; X7 M60; Mbenz GLS
Can you post a photo of your wheels?
      11-15-2025, 03:55 PM   #3
hufington
hufington's Avatar
Drives: 2025 760ix
It can be due to one or a combination of the following: excessive heat, improper installation, or manufacturing defects.
Excessive heat can be continuous driving up and downhill or aggressive city driving or riding the brakes. Also driving hard in wet conditions or going through puddles with very hot brakes may cause it. Improper installation can be a reason as well since tightening the lug nuts with improper torque can create uneven or too much pressure on brakes and brake pads and brake pad material can be deposited unevenly on the brake surface. It may also be manufacturing defects.
I've had "warped" brakes once on my Infiniti G37 and it happened after I was commuting daily in bad weather in a very hilly area full of sharp turns that required a lot of hard braking. They resurfaced the front brakes and replaced the pads. Never had that with any of my BMWs most of which had msport brakes.
I always uninstall any aftermarket accessories that may be a reason for the issue before bringing the car to the dealer so that they don’t immediately blame it on anything that is not factory. I'd put the OEM wheels on and bring the car to a different authorized service and ask them to look if it's due to manufacturing defects.
      11-16-2025, 11:21 AM   #4
ArviHujan
ArviHujan's Avatar
Drives: M5
My m760li suffered constant warped discs as the mating surface had clearcoat on it and stopped heat transfer from hub to wheel causing the discs to overheat
Copyright ©2000 - 2025, vBulletin Solutions Inc.
