      02-14-2026, 02:17 PM   #1
CASHM3
CASHM3's Avatar
Drives: IOMG G80 - Insta: 1meangreenmachine
Scratch, help?
Hi what is the best fix for this? It’s deep enough to feel as you run finger over it but not too bad. Thanks
      02-14-2026, 07:48 PM   #2
JerseyM3
Drives: 2025 M3 Comp xDrive
Machine polish. Im in the same boat. Ill be doing it on a few spots once the weather gets warmer
      02-14-2026, 08:04 PM   #3
alex2364
alex2364's Avatar
3754
Drives: 2020 M4 ZCP / 2023 X3 M40i
2020 BMW M4  [9.69]
2023 BMW X3 M40i  [9.75]
Touch up paint with Dr. ColorChip. Polish isn’t going to do anything when it’s through the paint.
CASHM331.50
tcphoto5214.00
FrankL172.50
      02-14-2026, 09:47 PM   #4
silvermanor
Drives: 2022 M3 comp xdrive
Yeah dr colorchip. It's not going to look good but it'll be protected.
FrankL172.50
      02-15-2026, 08:54 AM   #5
Zig613
Zig613's Avatar
351
Drives: 2025 BMW Z4 30i
The scratch will require touch up paint. I have had good results with Dr. ColorChip . They currently have a 15% off sale https://drcolorchip.com/. Enter Code WINTER2026 at Checkout.
      02-15-2026, 12:29 PM   #6
JoeyO
JoeyO's Avatar
Drives: 2025 BMW X3
I’ve never tried DR Colorchip. Is it fairly easy for DIYers with no experience?
      02-15-2026, 01:53 PM   #7
vt100
vt100's Avatar
402
Drives: '06 Z4MC, '12 128i
CASHM3, can you see the scratch if you run water over it?
If so - then yes, you need to touch up.
If you can't see the scratch when covered with water - you can buff it out.
      02-15-2026, 02:00 PM   #8
vt100
vt100's Avatar
402
It's easy with the right tools and experience. But takes lots of time if you want to do it right.
Do watch different videos on the topic before starting it. And you'll need a set of fine brushes (I'd not use the brush that comes with the kit, it's way too large), various grit fine sandpaper (from 600 to 5000 grit), and a rubber eraser to use it as a small sanding block. Then you'd also need a polish compound(s) and micro-fiber towels to buff it out.
And lots of patience
      02-15-2026, 02:13 PM   #9
CASHM3
CASHM3's Avatar
I noticed it does almost disappear when water is over it but not 100%. Thanks
vt100402.00
      02-15-2026, 05:50 PM   #10
Zig613
Zig613's Avatar
351
Yes it is easy for DIYers. There are a number of videos on their website on how to apply.
      02-16-2026, 07:50 AM   #11
Phillies8008
Drives: BMWs, duh
2026 BMW Z4 M40i  [9.50]
2024 BMW i4 e40  [9.50]
2006 BMW Z4M  [10.00]
A toothpick also works well instead of a brush. I've also had good luck with these.
      02-16-2026, 10:41 AM   #12
afadeev
afadeev's Avatar
4379
Drives: F80 M3
As others mentioned, most likely the scratch is just clear coat deep.
If it doesn't go all the way to the base color coat, you can polish it out without a trace. That would be the best-case outcome, and is easy to DIY.
It does not look like the scratch it "through the paint". If it was, you would see the primer, instead of what appears to be just roughed-up clear coat (thus white discoloration).
The water test somewhat attests to that scenario, but can be inconclusive. What you don't want to do is polish out the entire clear-coat from the area just to make this one scratch go away. That will definitely affect the look of the entire panel.
I would start with light polishing, and go from there.
If the scratch is too deep, you may need to fill it. With either clear coat bottle, or matched base paint mix. The former will be less visible. The latter is what most touch-up kits sell.
Both will need to be allowed to dry fully, then polished level with the rest of the paint surface around the touched-up area.
Again, easy and satisfying DIY with the right tools, and something you will likely need to repeat in the future, as paint scratches are a reality of car ownership.
Vertical surfaces are trickier to fill-in with touch-up paint.
Super-thin brush from any hobby store has worked best for me in these cases. Apply as little paint as possible, allow it to harden, then apply another layer.
Resist temptation to apply too much in one go, as it will sag unevenly with gravity on a vertical panel. And it will take way longer to dry.
Give it a day to fully harden, then polish away the high spots level with the rest of the paint coat.
For polishing small touch-up areas, I found the following kit to be super-handy:
https://www.amazon.com/dp/B08G9VCHF7..._title_14&th=1
HTH,
a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White)
'25 Lexus RZ (White/Blue)
      02-16-2026, 12:50 PM   #13
CASHM3
CASHM3's Avatar
Thank you everyone. I panicked at first as we all would but I’m glad it can be repaired fairly easily. Once it gets done I’ll post the end result. Im putting it on the back burner at the moment I got some other stuff cooking right now lol.
      02-16-2026, 01:28 PM   #14
Phillies8008
Drives: BMWs, duh
Out of curiosity, which green is that? I like it a lot.
CASHM331.50
      02-16-2026, 10:33 PM   #15
CASHM3
CASHM3's Avatar
Thanks so much. It’s IOMG- Isle of Man green. I get compliments like every single time I take it out. People think it’s a wrap and when I tell them it’s not they love it more.
      02-17-2026, 06:53 AM   #16
Phillies8008
Drives: BMWs, duh
For some reason I didn't have it my head that IOMG was that bright and vibrant. I think I've got a new color to add to my list of favorites!
CASHM331.50
      02-17-2026, 11:01 PM   #17
JoeyO
JoeyO's Avatar
Drives: 2025 BMW X3
I refer to it as Hulk green. In a good way. I like the Hulk. 😃
      02-17-2026, 11:57 PM   #18
CASHM3
CASHM3's Avatar
Yeah I agree then you’ll love these. This is no filter or editing, just a lot of sun and was just detailed. It really is one of the best paint colors ever IMO
      02-18-2026, 06:58 AM   #19
Phillies8008
Drives: BMWs, duh
Wow. I never thought I liked Isle of Man Green... until now, lol.
      02-18-2026, 07:42 AM   #20
John in VA
Drives: 2015 228i M Sport
You really need to see it in person!
      02-18-2026, 07:57 AM   #21
maticCRO
Drives: BMW G82 M4 Competition 2025
Deff one of the most epic colors ever, guy that lives 500m from me has M4in IOMG, i mostly see it when there is no sun and then it looks pretty darker green, and in the sun it outshines everything. If i did repaint my car, IOMG is the No1 color i would go for
      02-18-2026, 08:37 AM   #22
Three Stents
Three Stents's Avatar
246
Drives: 2023 X5 sdrive40i M Sport PKG
c'mon people, if the scratch is below the color coat, you can not buff it out. Stop posting false info
I'm from a small Wisconsin town. We didn't have a town drunk, we all took turns.
"Was it over when the Germans bombed Pearl Harbor?"
Zig613350.50
