| 03-16-2026, 03:18 PM | #2 |
Rep 526
Recent Bulletins
InVeh-InApp-Comm (2026-03-25) BMW M3 2025 (plus 1 other model) ENGINE It was determined that due to a manufacturing defect, there may be a peeling of the sliding layer of the main bearing shells. The peeling may cause engine damage to your vehicle in some cases. The main bearing shells will need to be replaced. MC-11030317-0001.pdf SIB 11 01 26 (2026-02-06) BMW M3 2026 BMW M4 2026 (plus 1 other model) ENGINE Delivery Stop - Bearing Shell MC-11029098-0001.pdf SIB 65 20 25 (2026-01-15) BMW M3 2025 BMW M4 2025 (plus 11 other models) ELECTRICAL SYSTEM After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound. MC-11027777-0001.pdf SIB 41 07 25 (2026-01-08) BMW M3 2021,2022,2023,2024 BMW M4 2021,2022,2023,2024,2025 (plus 6 other models) STRUCTURE: BODY While driving on a smooth and/or unevenroad, a “cracking” sound is heard from therear wheel arch area (highlighted in orange) on either the right or left side. MC-11027766-0001.pdf SIB 34 09 25 (2025-12-17) BMW M3 2024,2025,2026 BMW M4 2024,2025,2026 (plus 3 other models) SERVICE BRAKES There may be an internal leakage in the brake fluid expansion tank (aka brake fluid reservoir). In the rarecase of a leak, the filling level sensor might malfunction over a relatively long period of time. MC-11026950-0001.pdf SIB 84 06 25 (2025-10-03) BMW M3 2023,2024,2025 BMW M4 2024,2025,2026 (plus 17 other models) ELECTRICAL SYSTEM In some situations, an emergency call may be triggered in the vehicle without either the customer pressing the SOS Call button, or an airbag deployment event. In some cases, the customer may not even be inside the vehicle. MC-11024211-0001.pdf RECALL 25V643000 (2025-09-26) Affecting 4 total vehicles BMW M4 2026 (plus 1 other model) ELECTRICAL SYSTEM: 12V/24V/48V BATTERY: CABLES, ELECTRICAL SYSTEM: WIRING: POWER DISTRIBUTION MODULE/IPDM BMW of North America, LLC (BMW) is recalling certain 2026 M4 and 430i vehicles. The positive battery cables may not be properly connected to the power distribution box, resulting in an engine stall and a fire. SIB 51 22 22 (2025-09-17) BMW M3 2021,2022,2023,2024,2025 BMW M4 2021,2022,2023,2024,2025 (plus 11 other models) LATCHES/LOCKS/LINKAGES: HOOD: LATCH, STRUCTURE: BODY Hood lever is pulled twice but the hood only achieves the pre-latch position on both sides. MC-11024208-0001.pdf SIB 65 19 25 (2025-08-26) BMW M3 2025 BMW M4 2025 (plus 9 other models) ELECTRICAL SYSTEM Central Information Display (CID) in the vehicle is black or only displays “BMW”. The head unit (HU-H5) is not responding in ISTA. Additionally, the Receiver Audio Module (RAM), Instrument Cluster (KOMBI) and Telematic Module 4 (TCB4) may not be responding in ISTA. MC-11022856-0001.pdf SIB 41 04 24 (2025-08-20) BMW M3 2025 BMW M4 2025 (plus 12 other models) STRUCTURE: BODY A groaning sound from the front of the vehicle while driving can be heard, particularly while cornering. The groaning sound can be heard in the A-pillar/instrument panel area. MC-11022859-0001.pdf SIB 32 01 23 (2025-08-08) BMW M3 2021,2022,2023,2024 BMW M4 2021,2022,2023,2024 (plus 17 other models) STEERING When turning the steering wheel while stationary or when driving on uneven roads; cracking, creaking, or knocking noises may be heard. MC-11021817-0001.pdf SIB 12 01 25 (2025-06-06) BMW M3 2022,2023,2024,2025 BMW M4 2022,2023,2024,2025 (plus 4 other models) ELECTRICAL SYSTEM EMISSIONS RECALL 25E-A03: PROGRAM CONTOL UNITS (DME) MC-11019550-0001.pdf SIB 66 07 25 (2025-05-30) BMW M3 2024 BMW M4 2024 (plus 14 other models) ELECTRICAL SYSTEM The speed limit warning adopted speed, which is set by the customer, is automatically reverting to lowervalue after an extended duration of the sleep cycle. MC-11018732-0001.pdf SIB 34 06 25 (2025-05-02) BMW M3 2024 BMW M4 2024 (plus 5 other models) SERVICE BRAKES Brake “groaning” noises heard at the rear axle at slow speeds, i.e. close to standstill, stop and go driving;when parking or maneuvering. MC-11018518-0001.pdf SIB 51 46 16 (2025-02-03) BMW M3 2021,2022,2023 BMW M4 2021,2022,2023 (plus 71 other models) STRUCTURE: BODY, STRUCTURE: BODY: TAILGATE Upon opening and closing the tailgate, a creaking/groaning sound can be heard from tailgate actuator. MC-11014038-0001.pdf SIB 34 09 21 (2025-01-14) BMW M3 2021,2022 BMW M4 2021,2022 (plus 5 other models) POWER TRAIN: AXLE ASSEMBLY, SERVICE BRAKES A turbine-like noise can be heard from the rear axle while deceleration during the first 300 miles of operation when braking from low speed. MC-11013041-0001.pdf SIB 11 05 21 (2024-12-06) BMW M3 2022 (plus 17 other models) ENGINE, ENGINE AND ENGINE COOLING, FUEL SYSTEM, GASOLINE The belt pulley on the mechanical coolant pump may fracture allowing the engine drive belt to come off thecoolant pump and alternator. MC-11012077-0001.pdf SIB 51 09 23 (2024-08-19) BMW M4 2021,2022,2023 (plus 10 other models) VISIBILITY/WIPER, VISIBILITY: POWER WINDOW DEVICES AND CONTROLS Sudden failure of the power window(s). MC-11006730-0001.pdf SIB 11 02 24 (2024-07-17) BMW M3 2024 BMW M4 2025 (plus 1 other model) ENGINE The drive belt idler pulley bracket material does not have adequate hardness and the attaching bolts may loosen. MC-11005212-0001.pdf SIB 65 04 21 (2024-06-04) BMW M3 2021 BMW M4 2021 (plus 17 other models) EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC., STRUCTURE: BODY A rattling/ droning noise is heard in the vehicle interior when the air conditioning (AC) is activated. Vibrationsare felt in the driver’s footwell. MC-11002861-0001.pdf SIB 36 01 21 (2024-05-01) BMW M4 2021,2022,2023,2024 (plus 74 other models) EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, SERVICE BRAKES, AIR: DISC, STEERING At low outside temperatures (below 40 degrees F) and slow driving speeds (i.e. when parking, maneuvering)with a large steering angle, the front end can be slightly axially misaligned. MC-11000563-0001.pdf SIB 64 04 22 (2024-02-16) BMW M3 2021,2022,2023 BMW M4 2021,2022,2023 (plus 20 other models) ELECTRICAL SYSTEM, VISIBILITY: DEFROSTER/DEFOGGER/HVAC SYSTEM An interference noise (groaning noise) can be heard from within the heating and air-conditioning unit in thecenter of the instrument panel. The groaning noise always occurs when either a ventilation flap, air stratification flap or the recirculated airflap moves to a different position. Due to the complex design of the heating and air-conditioning unit, the kinematics causing it (top or bottom,left or right) may not be able to be precisely located. Depending on the vehicle model, the number of servomotors (and the associated kinematics unit) varies.Various models use either 2 or 3 servomotors. MC-10250374-0001.pdf SIB 61 13 05 (2024-01-11) BMW M3 2021,2022,2023,2024 BMW M4 2021,2022,2023,2024 (plus 362 other models) ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY The electrical system of BMW vehicles has been subject to an ongoing development process over the last few years. This has led to increased demands being placed on the battery. This document covers important information for the dealer on how to handle "discharged battery" complaints. MC-10249027-0001.pdf SIB 31 01 24 (2024-01-09) BMW M3 2021,2022,2023,2024 BMW M4 2021,2022,2023,2024 (plus 9 other models) SUSPENSION With the vehicle is on a lift and the front struts are in the extended position, there may be a cracking and orclicking type noise when turning the steering wheel left/right. See attached video V31 01 24. The sound can reoccur when the vehicle is lowered, and the wheels are once again under load. The noise might also be heard for a short time while driving. MC-10249016-0001.pdf SIB 61 05 24 (2024-01-05) BMW M4 2021,2022,2023,2024 (plus 57 other models) ELECTRICAL SYSTEM, EQUIPMENT: ELECTRICAL: INFOTAINMENT The Central Information Display goes black intermittently due to resets of the Head Unit (HU-H3). FaultB7F8F9 " "HU-H: Reset" will be stored in the HU-H3. MC-10249032-0001.pdf SIB 16 01 23 (2024-01-05) BMW M3 2021,2022,2023,2024 BMW M4 2021,2022,2023 (plus 51 other models) FUEL SYSTEM, GASOLINE A vehicle arrives at your center to be diagnosed for a micro-leak in the fuel evaporative (EVAP) system(NVLD natural vacuum leak detection). For this condition, the following fault is stored in the DME: 190302 - fuel tank ventilation and scavenging air system, micro-leak: leakage more than 0.5mm For: Model vehicles other that the ones listed above, or for EVAP faults related to a "large leak," after confirming that the fuel filler cap is fitted properly, then, proceed to follow the corresponding test plan MC-10249015-0001.pdf SIB 52 17 23 (2024-01-02) BMW M4 2021,2022,2023,2024 (plus 17 other models) ELECTRICAL SYSTEM, SEATS Customer states one of the front seats is inoperative. The seat heater and power supply are inoperative. During the vehicle test, the seat module does not respond. The power supply fuse for the seat module isfound to have blown. MC-10249023-0001.pdf SIB 84 03 23 (2023-12-06) BMW M3 2022,2023 (plus 15 other models) ELECTRICAL SYSTEM, EQUIPMENT: ELECTRICAL: WIRELESS CHARGER/CRADLE, EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL BMW AG has issued a Delivery Stop (effective February 9, 2023) on certain Model Year 2022 " 2023 BMW vehicles that were produced between June 29, 2022 and February 16, 2023. This was originally called "Wireless Charging Tray". Software in potentially affected vehicles may not recognize the removal of the digital key (Key Card or mobile phone) from the wireless charging tray, and thereby not meeting a federal requirement. On February 17, 2023 , the Delivery Stop was upgraded to a Non-Compliance Recall (see SI B84 01 23 ). SIB84 01 23 outlined a procedure for vehicles at that time which were- a) in BMW center inventory b) already delivered to customers This new SI B84 03 23 addresses vehicles which were in BMW center inventory or at the Vehicle Distribution Center (VDC) at that time. Those vehicles had the Key Card removed and were able to be retailed to the customer Such vehicles now need to return to the center to receive a new Key Card and updated programming. Please note that vehicles which were already in customer hands will be addressed by an update to SI B8401 23 MC-10248092-0001.pdf SIB 34 07 14 (2023-10-13) BMW M3 2021,2022,2023,2024 BMW M4 2021,2022,2023,2024 (plus 29 other models) SERVICE BRAKES, HYDRAULIC Functional noises (squealing/honking) when braking shortly before the vehicle comes to a stop. CAUSE Material- MC-10244237-0001.pdf SIB 24 04 23 (2023-09-28) BMW M3 2023 (plus 8 other models) POWER TRAIN BMW AG has issued a Delivery Stop (effective September 28, 2023) on certain Model Year 2023 BMWvehicles that were produced between January 23, 2023, and June 15, 2023. MC-10242970-0001.pdf SIB 84 09 17 (2023-07-01) BMW M3 2021 BMW M4 2021 (plus 35 other models) ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT: ELECTRICAL While using the wireless charger, one or both of the following may occur: 1) The BMW display key or mobile phone becomes hot to the touch, 2) The device switches off due to over temperature (built-in device protection). MC-10241374-9999.pdf SIB 63 08 21 (2023-06-01) BMW M3 2021,2022,2023 BMW M4 2021,2022,2023 (plus 42 other models) ELECTRICAL SYSTEM, EXTERIOR LIGHTING Headlight check control (CC) message 128 "High beam headlight failure" is displayed. The following fault codes are stored during a vehicle test: 80419A - Left high-beam headlight: Short circuit and/or 8041A5 - light outputs: Number of permitted short circuit cycles exceeded MC-10239611-9999.pdf SIB 63 03 21 (2023-06-01) BMW M3 2021,2022,2023 BMW M4 2021,2022,2023 (plus 19 other models) EXTERIOR LIGHTING, EXTERIOR LIGHTING: TAIL LIGHTS Condensation is present on the inner surfaces in one or both taillights (circled). MC-10239610-9999.pdf SIB 12 03 23 (2023-06-01) BMW M3 2021,2022,2023 BMW M4 2021,2022,2023 (plus 34 other models) EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL BMW AG has issued a Delivery Stop effective June 6, 2023 on certain Model Year 2023 - 2024 BMW vehicles that were produced between October 26, 2022 and May 8, 2023. MC-10239601-9999.pdf SIB 12 01 23 (2023-04-01) BMW M4 2023 (plus 6 other models) ENGINE AND ENGINE COOLING In hot ambient conditions, if the engine was running for a prolonged time while the vehicle is stationary, a jolt may be experienced while lightly accelerating. MC-10236218-9999.pdf SIB 84 14 22 (2023-03-01) BMW M3 2021,2022,2023 BMW M4 2021,2022 (plus 47 other models) EQUIPMENT: ELECTRICAL: NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM), LANE DEPARTURE: LANE KEEP: NAVIGATION SYSTEM/SOFTWARE Customer is shown an incorrect GPS location in the vehicle (i.e., Nav Map, coordinates). MC-10235206-9999.pdf SIB 65 16 23 (2023-03-01) BMW M3 2021,2022,2023 BMW M4 2021,2022 (plus 49 other models) EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC. Customer states there is no audio playback (telephony, navigation, radio) and system sounds (PDC, turn indicators, acoustic signals) may also have failed. MC-10235203-9999.pdf SIB 62 02 23 (2023-03-01) BMW M3 2021,2022,2023 BMW M4 2021,2022,2023 (plus 9 other models) ELECTRICAL SYSTEM: INSTRUMENT CLUSTER/PANEL In SPORT mode, a black square appears in the RPM gauge (tachometer) section of the instrument cluster display. MC-10235198-9999.pdf RECALL 23V118000 (2023-02-23) Affecting 120 total vehicles BMW M3 2023 (plus 6 other models) ELECTRICAL SYSTEM: BODY CONTROL MODULE: SOFTWARE BMW of North America, LLC (BMW) is recalling certain 2023 330i, 330i xDrive, M340i, M340i xDrive, M3, 330e, 330e xDrive, 430i Convertible, 430i xDrive, M440i, 2022-2023 430i, 430i xDrive, M440i xDrive, i4 eDrive40, and i4 M50 vehicles. During a service visit, a replacement electronic control unit (ECU) may have been installed with incorrect programming, which can cause the automatic door locking (ADL) function to not lock the doors as intended. RCRIT-23V118-0454.pdf SIB 61 01 20 (2023-02-01) BMW M3 2021,2022 BMW M4 2021,2022 (plus 23 other models) ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, EQUIPMENT: ELECTRICAL: WIRELESS CHARGER/CRADLE, POWER TRAIN Customer is unable to power up or charge accessories through a plug adapter inserted in the front 12-volt power socket plug. Alternatively, it will only operate when constant downward hand pressure is maintained. MC-10233162-9999.pdf SIB 84 12 22 (2022-12-01) BMW M3 2021,2022 (plus 7 other models) EQUIPMENT: ELECTRICAL, EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL BMW AG has issued a Delivery Stop (effective November 10, 2022) on a small number of Model Year 2023 BMW vehicles that were produced between August 8, 2022 and October 18, 2022. MC-10230739-9999.pdf SIB 61 33 22 (2022-12-01) BMW M4 2021,2022 (plus 24 other models) EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL Due to a software error, Remote Software Upgrade (RSU) and Remote Support are currently not possible. Additionally, the Integrated Owner's Handbook cannot be displayed. MC-10230734-9999.pdf SIB 17 03 22 (2022-12-01) BMW M3 2021,2022 BMW M4 2021,2022 ENGINE AND ENGINE COOLING: COOLING SYSTEM The charge air cooler housing may sperate and lose charging pressure. MC-10230723-9999.pdf SIB 12 10 21 (2022-11-01) BMW M3 2022 (plus 13 other models) ELECTRICAL SYSTEM, ENGINE, EXTERIOR LIGHTING, POWER TRAIN Due to an unfavorable operating point, primarily in the low-end torque range, an incorrect detection of amixture that is too rich could happen. MC-10228426-9999.pdf SIB 65 20 22 (2022-11-01) BMW M3 2021,2022 BMW M4 2021,2022 (plus 6 other models) AIR BAGS, ELECTRICAL SYSTEM, LANE DEPARTURE A check control message for the restraint system appears. In the instrument cluster, the red air bag warning light lights up permanently. One of the following fault codes is stored in the ACSM (air bag control unit): 930949 - Knee airbag, driver: short circuit to negative terminal 93094F - Knee airbag, front passenger: short circuit to negative terminal 93094C - Knee airbag driver's side: Resistance too great 930952 - Knee airbag, front passenger: Resistance too great. MC-10227929-9999.pdf SIB 65 19 22 (2022-10-01) BMW M3 2021,2022 BMW M4 2021,2022 (plus 40 other models) EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC. The customer complains that the radio stations change by themselves. MC-10227575-9999.pdf SIB 61 12 22 (2022-10-01) BMW M3 2021,2022 BMW M4 2021,2022 (plus 41 other models) VISIBILITY After opening the vehicle with the radio remote control and changing the profile, the exterior mirror settings are lost. MC-10227558-9999.pdf SIB 66 24 19 (2022-09-01) BMW M3 2021,2022 BMW M4 2021,2022 (plus 61 other models) ELECTRICAL SYSTEM, ENGINE, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, EQUIPMENT: ELECTRICAL, STEERING Vehicle cannot be opened or closed using comfort access, engine start is not possible, and the vehicle may not start when placing the key against the steering column. MC-10225126-9999.pdf SIB 65 13 22 (2022-09-01) BMW M3 2022 (plus 6 other models) ELECTRICAL SYSTEM After updating dealer owned vehicles to software 22-07-5XX, many current BMW customers and previous Demo users may receive emails stating that they are linked to BMW vehicles they do not own. Also, many users of the MyBMW app may find additional vehicles in their "My Garage" tab that they do not recognize. MC-10225124-9999.pdf SIB 61 14 21 (2022-09-01) BMW M3 2021,2022 (plus 12 other models) ENGINE AND ENGINE COOLING: ENGINE: OIL/LUBRICATION: PRESSURE/TEMPERATURE SENSOR, EQUIPMENT: ELECTRICAL The BMW Gesture Control function may fail permanently as a result of high temperature fluctuations. MC-10225117-9999.pdf SIB 65 09 22 (2022-08-01) BMW M3 2021,2022 BMW M4 2021,2022 (plus 49 other models) EQUIPMENT: ELECTRICAL The sound output intermittently drops out entirely. This can be reproduced with all audio sources as well as telephone and voice output. MC-10224210-9999.pdf SIB 51 13 22 (2022-08-01) BMW M3 2021,2022 BMW M4 2021,2022 VEHICLE SPEED CONTROL During strong acceleration, the fuel filler door possibly opens automatically. MC-10224205-9999.pdf SIB 66 24 19 (2022-06-01) BMW M4 2021,2022 (plus 45 other models) ELECTRICAL SYSTEM, EQUIPMENT Vehicle cannot be opened or closed using comfort access, engine start is not possible, and the vehicle may not start when placing the key against the steering column. Note: Opening, closing and starting via the BMW Digital Key or the Digital Key Card are not affected. MC-10218384-9999.pdf SIB 65 13 12 (2022-05-01) BMW M3 2021,2022 BMW M4 2021,2022 (plus 91 other models) ELECTRICAL SYSTEM The Headunit High (HU-H), also called NBT, began replacing the Car Information Computer (CIC) on certain MY2013 vehicles with option 609 (as of 7/2012 production). This uses map North America NEXT. The Headunit High 2 (HU-H2), also called NBT-EVO, superseded the NBT HU and was introduced in 3/2014. This uses map North America EVO. The Headunit High 4 (HU-H4, also called MGU21) superseded the MGU starting with certain MY2021 vehicles with option code 6U3 Live Cockpit Professional. This uses map North America JOY. The ENTRY Media/Navigation (HU-B) is the low line business version of the navigation system and was introduced in 3/2014. This uses map North America ROUTE. The ENTRY NAV EVO (HU-B2) replaced Entry Media/Navigation as the low-line business version and was introduced in certain MY2018 vehicles. This uses map North America WAY. MC-10214990-9999.pdf SIB 64 02 22 (2022-05-01) BMW M3 2021,2022 BMW M4 2021,2022 (plus 38 other models) ENGINE AND ENGINE COOLING Mist formation on the windshield inside surface may occur at departure or after MSA (automaticstart/stop). Acoustic abnormality in the area of the recirculated air flap (recirculation flap closing and opening severaltimes). The above may occur individually or in combination. MC-10214989-9999.pdf SIB 63 02 22 (2022-05-01) BMW M3 2021,2022 BMW M4 2021,2022 (plus 3 other models) EXTERIOR LIGHTING: HEADLIGHTS Excessive condensation has collected in one or both headlights. MC-10214988-9999.pdf SIB 64 05 21 (2022-04-01) BMW M3 2022 (plus 3 other models) ENGINE AND ENGINE COOLING, EQUIPMENT: APPLIANCE: AIR CONDITIONER, STRUCTURE, VISIBILITY: DEFROSTER/DEFOGGER/HVAC SYSTEM: REFRIGERANT HOSES AND FITTINGS A rattling noise is heard in the vehicle interior when the air conditioning (AC) is activated. MC-10212798-9999.pdf SIB 62 02 22 (2022-04-01) BMW M3 2022 (plus 26 other models) ELECTRICAL SYSTEM: SOFTWARE Sport mode is not displayed correctly in the instrument cluster. Instead of a red background in sport mode, the background is displayed in blue (like in Eco Pro mode). Software in the instrument cluster (Kombi). MC-10212797-9999.pdf SIB 61 07 22 (2022-04-01) BMW M3 2022 (plus 41 other models) ELECTRICAL SYSTEM: IGNITION: ANTI-THEFT: IMMOBILIZER/PROXIMITY: KEY/SENDER Check Control message (CCM) displays "Vehicle key missing" after engine start. MC-10212795-9999.pdf SIB 61 01 21 (2022-04-01) BMW M3 2022 (plus 39 other models) ELECTRICAL SYSTEM, ELECTRICAL SYSTEM: 12V/24V/48V BATTERY, EQUIPMENT: ELECTRICAL, STRUCTURE: BODY: HOOD 48 V battery may become totally discharged, and possible replacement needed. MC-10212793-9999.pdf SIB 36 01 22 (2022-04-01) BMW M3 2022 (plus 11 other models) EXTERIOR LIGHTING, SERVICE BRAKES, HYDRAULIC, TIRES: PRESSURE MONITORING AND REGULATING SYSTEMS, WHEELS The customer finds an indication in the myBMWâ?" app that the tires need service due to wear. Even after replacing the tires, the tire service indicator is still present in the myBMW app. MC-10212790-9999.pdf SIB 41 02 22 (2022-03-01) BMW M4 2021,2022 (plus 2 other models) EQUIPMENT The trunk floor carpet is wet, primarily on the left side. MC-10211856-9999.pdf SIB 84 02 22 (2022-03-01) BMW M3 2022 (plus 12 other models) ELECTRICAL SYSTEM: SOFTWARE, EQUIPMENT, TIRES: PRESSURE MONITORING AND REGULATING SYSTEMS The customer finds an indication in the â??myBMWâ?" app that the tires need service due to wear. Even after replacing the tires, the tire service indicator is still present in the myBMW app. MC-10211810-9999.pdf SIB 66 15 19 (2022-03-01) BMW M3 2022 (plus 34 other models) EQUIPMENT, LANE DEPARTURE, STEERING The steering intervention for Lane Departure Warning (LDW) is too strong (severe), which can create an uncomfortable feeling for the driver. Background: Steering intervention helps keep the vehicle in the lane if the system detects that a lane marking has been crossed. The steering intervention can be noticed on the steering wheel and can be manually overridden at any time. MC-10211809-9999.pdf SIB 31 03 18 (2022-02-01) BMW M3 2021 BMW M4 2021 (plus 5 other models) STEERING Cracking noises heard from the area of the front axle when rotating the steering while stationary or at low speed. MC-10214259-9999.pdf SIB 09 03 21 (2022-02-01) BMW M3 2021 BMW M4 2021 (plus 35 other models) BACK OVER PREVENTION: SOFTWARE, EQUIPMENT: ELECTRICAL In some rare cases a customer vehicle might be excluded from one or more Remote Software Upgrade(RSU) campaigns. This SIB gives an overview how to identify these vehicles and how to proceed in case of a customer complaint. MC-10214254-9999.pdf SIB 65 12 21 (2022-02-01) BMW M3 2021 (plus 13 other models) ELECTRICAL SYSTEM, EQUIPMENT ADAPTIVE/MOBILITY, EQUIPMENT: ELECTRICAL: AUX AUDIO JACK/PLUG BMW AG has issued a Delivery Stop (effective June 9, 2021) on certain Model Year 2021 BMW vehicles that were produced between May 7, 2021 and May 21, 2021. The Receiver Audio Module (RAM) will need to be added to the affected vehicles. MC-10212528-9999.pdf SIB 84 05 21 (2021-12-02) BMW M4 2022 ELECTRICAL SYSTEM: SOFTWARE, EQUIPMENT: ELECTRICAL: ANTENNA Vehicles which require this Campaign to be completed will show it as ?Open? when checked either in Vehicles which require this Campaign to be completed will show it as ?Open? when checked either in AIR the "Service Menu" of DCSnet (Dealer Communication System), ISPA Next or Warranty Vehicle Inquiry. MC-10206768-9999.pdf SIB 84 06 21 (2021-12-01) BMW M3 2021 BMW M4 2021 (plus 37 other models) COMMUNICATION: MANUFACTURER TELEMATICS, ELECTRICAL SYSTEM, EQUIPMENT The SIM card installed in the telematics control unit (ATM2) connects to different mobile providers' networks. However, due to a missing parameter, this does not work and can cause disruption in BMW ConnectedDrive services in areas with insufficient network coverage. MC-10206692-9999.pdf SIB 65 21 21 (2021-12-01) BMW M3 2021 BMW M4 2021 (plus 37 other models) EQUIPMENT, EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC. SiriusXM satellite radio is not working and does not display a channel list. MC-10206688-9999.pdf SIB 61 16 21 (2021-11-01) BMW M3 2021 BMW M4 2021 (plus 37 other models) ELECTRICAL SYSTEM: SOFTWARE The "energy management" Check control message (ID code 415) is falsely displayed when entering the vehicle. MC-10205095-9999.pdf SIB 61 15 21 (2021-11-01) BMW M4 2021 ELECTRICAL SYSTEM: 12V/24V/48V BATTERY, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY It is possible that the EPP (expanded polypropylene) insert for the lithium-ion battery was not installed in approx. 0.3% of the G82 and G83 vehicles. MC-10205094-9999.pdf SIB 65 09 19 (2021-11-01) BMW M3 2021 BMW M4 2021 (plus 39 other models) ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT: ELECTRICAL: NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM), EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC. Customer states the following about their vehicle: active radio or music source is interrupted, the navigation is no longer available, a black screen is shown in the Control Display, the system works again after a short interruption. MC-10205070-9999.pdf SIB 11 07 21 (2021-10-08) BMW M3 2022 BMW M4 2022 (plus 2 other models) POWER TRAIN MAIN BEARING SHELL. MC-10204535-9999.pdf SIB 65 13 12 (2021-09-01) BMW M3 2021 BMW M4 2021 (plus 30 other models) EQUIPMENT: ELECTRICAL: NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) The Headunit High (HU-H), also called NBT, began replacing the Car Information Computer (CIC) on certain MY2013 vehicles with option 609 (as of 7/2012 production). This uses map North America NEXT. The Headunit High 2 (HU-H2), also called NBT-EVO, superseded the NBT HU and was introduced in 3/2014. This uses map North America EVO. The Headunit High 3 (HU-H3, also called MGU) superseded the NBT-EVO starting with certain MY2019 vehicles with option code 6U3 Live Cockpit Professional or 6U2 Live Cockpit Plus. This uses map North America LIVE. The ENTRY Media/Navigation (HU-B) is the low line business version of the navigation system and was introduced in 3/2014. This uses map North America ROUTE. The ENTRY NAV EVO (HU-B2) replaced Entry Media/Navigation as the low-line business version and was introduced in certain MY2018 vehicles. This uses map North America WAY. MC-10204660-9999.pdf SIB 61 07 21 (2021-09-01) BMW M3 2021 (plus 59 other models) EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, STEERING Groaning, scraping, or squeaking noise coming from the steering wheel area in the interior of the vehicle,when turning the steering wheel. MC-10203340-9999.pdf SIB 34 10 19 (2021-09-01) BMW M3 2021 BMW M4 2021 (plus 27 other models) SERVICE BRAKES, SERVICE BRAKES, HYDRAULIC Inform the customer during a consultation that the M Compound (standard equipment) and M Carbon Ceramic (optional) brakes are high-performance brake systems which are designed for sporty, dynamic driving styles. As a side effect of the highest possible brake performance, customers are likely to hear noises due to the extremely resilient materials. In the same conversation, inform the customer that his/her braking performance can help ensure that the noises do not occur or disappear quickly. MC-10203336-9999.pdf RECALL 21V554000 (2021-07-22) Affecting 21537 total vehicles BMW M3 2021 BMW M4 2021 (plus 15 other models) SEAT BELTS BMW of North America, LLC (BMW) is recalling certain 2021 2 Series (230i, 230i xDrive, M240i, M240i xDrive), 330e, 330e Xdrive, 4 Series Coupe (430i, 430i xDrive, M440i xDrive) M4 Coupe, M4 Competition Coupe, BMW 4 Series Convertible (430i, M440i), BMW X1 sDrive28i, xDrive28i, 2 Series Gran Coupe (228i, 228i xDrive, M235i xDrive), M2 Competition Coupe, 330i, 330i xDrive, M340i, M340i xDrive, M3, M3 Competition, 530i, 530i xDrive, 540i, 540i xDrive, MINI Hardtop 2 Door (Cooper, CooperS, JCW), X2 sDrive28i, X2 xDrive28i, X2 M35i, Z4 sDrive30i, Z4 M40i, MINI Hardtop 2 Door (Cooper SE), MINI Convertible (Cooper, Cooper S, JCW), MINI Clubman (Cooper S, Cooper S All4, JCW), MINI Countryman (Cooper, Cooper All4, Cooper S, Cooper S All4, JCW All4), Rolls Royce Ghost, MINI Countryman (Cooper S E All4), Rolls Royce Phantom, Rolls Royce Cullinan, and Toyota Supra vehicles. The passenger seat belt Automatic Locking Retractor (ALR) may deactivate early, before the webbing fully retracts. As such, these assemblies fail to comply with the requirements of Federal Motor Vehicle Safety Standard number 208, "Occupant Crash Protection." RCRIT-21V554-8499.pdf RCRIT-21V554-3237.pdf RCRIT-21V554-1114.pdf RCRIT-21V554-6570.pdf RCRIT-21V554-5638.pdf SIB 34 07 21 (2021-07-01) BMW M3 2021 BMW M4 2021 (plus 18 other models) SERVICE BRAKES, HYDRAULIC: POWER ASSIST: HYDRAULIC When starting the vehicle vehicle at standstill, various yellow Check Control Messages CCMs appear. ID code 00042: Brake system. Additional notes: Avoid abrupt braking as far as possible. Drive at a moderate speed. Have it checked by your nearest Service Center. ID code 2046: Braking force assistance. Additional notes: Braking force assistance failure. Higher pedal force required for vehicle deceleration. Drive at a moderate speed. Have it checked by your nearest Service Center. MC-10204625-9999.pdf SIB 62 03 21 (2021-07-01) BMW M3 2021 BMW M4 2021 (plus 38 other models) ELECTRICAL SYSTEM: SOFTWARE, ENGINE AND ENGINE COOLING When the vehicle is operated in Sport Mode, the engine speed is no longer displayed in the BMW Head-Up Display (HUD). MC-10202474-9999.pdf SIB 61 08 21 (2021-07-01) BMW M3 2021 BMW M4 2021 (plus 5 other models) EQUIPMENT The cigarette lighter is difficult or impossible to pull it out. MC-10202470-9999.pdf SIB 61 04 21 (2021-07-01) BMW M3 2021 BMW M4 2021 (plus 25 other models) EQUIPMENT: ELECTRICAL The customer may complain of a check control message stating "Safe share detected" (CCM-ID 953). Check control message can be verified by checking key reader information or performing the Check control message history service function. MC-10202469-9999.pdf SIB 65 17 21 (2021-07-01) BMW M3 2021 BMW M4 2021 (plus 25 other models) EQUIPMENT: ELECTRICAL The BMW key card cannot be activated. The activation menu in the BMW iDrive is missing. MC-10201148-9999.pdf SIB 51 16 21 (2021-07-01) BMW M3 2021 BMW M4 2021 POWER TRAIN Noises from the center console shifter cover at low speeds. The noise can be affected by pressing the gearshift lever knob. MC-10201142-9999.pdf SIB 65 11 21 (2021-06-01) BMW M3 2021 BMW M4 2021 (plus 36 other models) ELECTRICAL SYSTEM: SOFTWARE, EQUIPMENT ADAPTIVE/MOBILITY, EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC. SiriusXM satellite radio is not working and does not display a channel list. MC-10200247-9999.pdf SIB 61 04 21 (2021-06-01) BMW M3 2021 BMW M4 2021 (plus 27 other models) ELECTRICAL SYSTEM: SOFTWARE, ENGINE, EQUIPMENT The customer may complain of a check control message stating "Safe share detected" (CCM-ID 953). Check control message can be verified by checking key reader information or performing the Check control message history service function. MC-10200237-9999.pdf SIB 12 03 21 (2021-06-01) BMW M3 2021 BMW M4 2021 (plus 1 other model) ELECTRICAL SYSTEM: SOFTWARE, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY Due to an software error, the adaptation values of the actuator contiguous wheel slip limitation (ARB) may be lost. MC-10200230-9999.pdf SIB 65 07 21 (2021-05-01) BMW M3 2021 BMW M4 2021 (plus 35 other models) ELECTRICAL SYSTEM, EQUIPMENT: ELECTRICAL: INFOTAINMENT: BLUETOOTH/WIFI HU-H3 MGU RESETS DUE TO BLUETOOTH CONNECTION WITH SAMSUNG ANDROID 11 : The head unit resets when using various apps (e.g., YouTube, Spotify, etc) on the connected mobile phone. This affects Samsung mobile phones (e.g., Galaxy S20 / S21) with the Android 11 operating system. MC-10200482-9999.pdf SIB 51 11 21 (2021-05-01) BMW M4 2021 EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, PARKING BRAKE, STRUCTURE: BODY: ROOF AND PILLARS ROOF TRIM STRIP LOOSE AT REAR: The roof trim strip may be loose at the last (rearmost) clip as shown. This can occur on either side of the roof, or on both sides. MC-10198904-9999.pdf SIB 51 10 21 (2021-05-01) BMW M4 2021 (plus 2 other models) BACK OVER PREVENTION, STRUCTURE: BODY: TRUNK LID SERVICE ACTION: CHECK BADGE ON TAILGATE, REPLACE IF NECESSARY . The "BMW" trunklid emblem (arrow) which contains the rear-view camera may not have been correctly fastened during vehicle production. It is possible that the emblem & camera may become detached from the vehicle, such as when going through an automated car wash. MC-10198903-9999.pdf RECALL 21V298000 (2021-04-28) Affecting 12 total vehicles BMW M3 2021 (plus 3 other models) SEAT BELTS: FRONT: BUCKLE ASSEMBLY BMW of North America, LLC (BMW) is recalling certain 2021 330i, 330i xDrive, M340i, M3, and 330e xDrive vehicles. The bolt securing the seat belt assembly to the frame was not tightened to specification. RCRIT-21V298-7991.pdf SIB 51 07 21 (2021-04-01) BMW M3 2021 BMW M4 2021 (plus 8 other models) STRUCTURE: BODY: DOOR INCREASED EFFORT REQUIRED TO OPEN DOORS: One or more doors may require increased effort to open. MC-10194300-9999.pdf SIB 51 06 21 (2021-03-01) BMW M4 2021 (plus 2 other models) VISIBILITY: POWER WINDOW DEVICES AND CONTROLS STREAKS ON FRONT SIDE WINDOWS: Streak marks are visible, most commonly on the upper rear corner of the front side window. The marks can be present anywhere on the rearmost edge of either front window. MC-10190851-9999.pdf RECALL 21V062000 (2021-02-10) Affecting 893 total vehicles BMW M3 2021 BMW M4 2021 (plus 10 other models) SERVICE BRAKES, HYDRAULIC, SERVICE BRAKES, HYDRAULIC: POWER ASSIST: HYDRAULIC BMW of North America, LLC (BMW) is recalling certain 2020-2021 8 Series Coupe, Grand Coupe and convertible 840i, 840i xDrive, M850i xDrive, M8 and 740 Li, 740 Li xDrive, 750 Li xDrive, M760 Li xDrive, X6 sDrive40i, X6 xDrive40i, X6 xdrive50i, X6 M50i, X6M, and 2019-2021 X5 sDrive40i, X5 xDrive40i, X5 xDrive50i, X5 M50i, X5M, X7 xDrive40i, X7 xDrive50i, X7 M50i, and 2021 M3, M3 Competition, M4 Coupe, M4 Competition Coupe, X5 xDrive45e, 745 Le xDrive. The rotor and shaft within the integrated brake system may not have been welded properly and could separate during a hard braking event, possibly resulting in a loss of the Antilock Brake System (ABS) and braking assistance. RCRIT-21V062-2025.pdf RCRIT-21V062-7131.pdf SIB 01 12 20 (2020-12-01) BMW M4 2021 (plus 10 other models) EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL, TIRES BMW MAINTENANCE BOOKLET AND OEM TIRE MANUFACTURERS' WARRANTIES: In efforts to provide a digital experience to our customers, BMW of North America, LLC (BMW NA) is proud to announce a digital version of both the BMW Maintenance Booklet and BMW Original Equipment Manufacturers' (OEM) Tire Warranties. MC-10186206-9999.pdf This is an automated post created with code written by a human. Last edited by analogue; 03-31-2026 at 09:12 AM.. |
| 03-16-2026, 09:13 PM | #3 |
Rep 526
2026
SIB 41 07 25 (2026-01-08) BMW M3 2021,2022,2023,2024 BMW M4 2021,2022,2023,2024,2025 (plus 6 other models) STRUCTURE: BODY While driving on a smooth and/or unevenroad, a “cracking” sound is heard from therear wheel arch area (highlighted in orange) on either the right or left side. MC-11027766-0001.pdf SIB 65 20 25 (2026-01-15) BMW M3 2025 BMW M4 2025 (plus 11 other models) ELECTRICAL SYSTEM After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound. MC-11027777-0001.pdf SIB 11 01 26 (2026-02-06) BMW M3 2026 BMW M4 2026 (plus 1 other model) ENGINE Delivery Stop - Bearing Shell MC-11029098-0001.pdf |
| Bookmarks |
