02-19-2011, 11:10 AM | #1 |
14
Rep 178
BMW 7 Series and ADV.1 Wheels Deep Concave
Model ADV10 Deep Concave Satin Brushed Gunmetal Centers Gloss Brushed Gunmetal Lips Wheel Size - 22x9.5 / 22x12 (no rolling) 255x30x22 and 315x25x22 Last edited by GMP - MATTHEW; 02-21-2011 at 12:04 PM.. |
02-19-2011, 04:43 PM | #3 |
Rep 53
I'm not a fan of aftermarket rims but those look amazing!! Also excellent photography!
2013 M5 | '12 650i | '09 750li | '06 750li | '03 745li | '00 540i | |
02-20-2011, 10:17 AM | #5 |
BMW Alpina Enthusiast
13
Rep 67
02-21-2011, 12:03 PM | #8 |
14
Rep 178
The size on this car is really agressive and although it doesn't rub ADV.1 generally builds with a slightly higher offset for the new 7 series unless the customer specifically says he wants something aggressive like this.
The Tire Size is 255x30x22 and 315x25x22 |
02-21-2011, 03:54 PM | #10 | |||
13
Rep 67
second, I notice you made correction on your original post. The Correct Width of the wheel was actually LARGER than you first posted ! That is amazing. The front wheel is actually 9.5inch wide, and the Rear Wheel is actually 12 inch wide ! I just checked your website, and I see this page specifically for this wheel: http://www.adv1wheels.com/adv1wheels/deepconcave.php from that page I see we can have this wheel made in 21in diameter. My Question: If we choose 21inch diameter, can we go with even wider width ? for example maybe 21x10 in front, and 21x12.5in rear ? I search all your previous post and still can't find the offset for this wheel though... |
02-21-2011, 04:53 PM | #11 |
14
Rep 178
Yes I needed to make a correction, The wheels were wider than I thought they were. By going with smaller wheel does not make more clearance between the inner barrel and the suspension so we cannot use a larger inner barrel. It also doesnt create more clearance between the edge of the tire and the edge of the fender. This doesn't mean you can't run a wider wheel just the tires might stretch or stick out past the fender.
Yes we can make this wheel in 21's, as they are custom made to order wheels. |
