BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > USA - Midwest / Rockies
EXXEL Distributions
      08-30-2011, 11:52 PM   #1
SlamMan
SlamMan's Avatar
Drives: ED 5/19/2010, Interlagos E90
Minimum Tread Depth for Perf. Driving School?
Does anyone know what the minimum tread depth is to pass tech inspection at the performance driving school? My tires certainly aren't bald but the tread is getting low. I'm hoping I can get through the fall driving school with these tires before having to purchase new tires.
I play real sports. Not tryin' to be the best at exercising. - Kenny Powers
      08-31-2011, 09:28 AM   #2
llis
octane chick
llis's Avatar
Drives: ex-M
2013 BMW M3 ZCP  [10.00]
2003 BMW M5  [0.00]
Which driving school? NASA? BMWCCA? PCA? Other? I don't know of any marked differences between the clubs re tech inspection, but someone else might. I do know that BMWCCA requires you to have changed your brake fluid within the past 90 days. Not sure how that particularity might translate over into tires.
I'm not sure what the actual depth number might be, but they will be looking for any chunking or exposed cord, especially on the outer corners of the tires, where you will see the most wear from HPDE. For example, my street tires, which I tracked previously but don't anymore due to a new setup, have visible wear on the corners, but would pass inspection because they have tons of tread on the flat and the corners show no chunking etc. However, a friend's front tires started chunking on the corners. They were very new tires but the track days had taken their toll on the corners, and those tires would never have passed inspection. In fact, she had to quit early the day the chunking happened. It was not safe to continue.
If you have a real question, I'd recommend playing it safe and get new tires. If you plan on doing more tracking on the next tires, you might do some shopping for the model of tire you might prefer. Recommend you take this question to the Tires forum here, and post some photos of the tires you have.
      08-31-2011, 11:58 PM   #3
SlamMan
SlamMan's Avatar
BMWCCA. The outer edges have worn a bit but inside that still has a fair amount of tread. I'm hoping the new camber plates I installed will result in more even tire wear.
      09-01-2011, 12:04 AM   #4
signes
signes's Avatar
Drives: 991 GT3 RS
You won't have a problem.
GT3 RS | Desperately seeking the next great M car...
m3post
