New 2009 2010 BMW Z4 - ZPOST
      01-26-2012, 02:38 AM   #1
GaryRudolph
Drives: 2012 Z4 sDrive35is
Camber Plates
Anyone found camber plates for the E89? I'm itching to take it to the track, but if it's like every other BMW one day at the track without camber plates and you burn through a set of tires... Of course it would give a reason to replace the run flats then
      01-26-2012, 04:13 PM   #2
timber511
Drives: BMW Z435IS
grould control has them
      01-26-2012, 05:13 PM   #3
GaryRudolph
Thanks, I emailed them to ask as it's not listed on their site.
      08-12-2017, 01:23 AM   #4
Furkan
Turkey
Drives: E89 Z4 35is / F10 M5
I'm using K-Mac Stage III with KW V3's. While turning the steering wheel at low speeds some different noises coming from them and steering wheel has untrustful feeling at +220kmh (140mph). I'm regret to order them.
I'm also looking for a good brand who produced a good camber plate's.
Waiting for advices...
      08-12-2017, 10:00 PM   #5
Vetracr
Drives: 2010 BMW Z4 3.0
Definitely go with Ground Control. They've been around a long time. I have them on my Z4. Good for camber adjustment but no caster adjustment.
      08-13-2017, 08:10 AM   #6
rif75
France
64
Drives: BMW M4 LCI ZCP and BMW M5 f10
Was wondering if the ref is the same as 335 xdrive e90. On the etk, it's the same
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
      08-17-2017, 10:33 AM   #7
Furkan
Turkey
thank you very much. in their website there are a E89 Z4 Camber/Caster Plate. Are you ordered that one? I need 7.20 caster I don't need more
      08-17-2017, 10:34 AM   #8
Furkan
Turkey
yes the struts are same I know at 2006+ E Coded BMW's.
      09-23-2017, 11:23 AM   #9
rif75
France
64
I m thinking about the ground control camber plates. Can some one tell me what spring inner diameter I should select with the KW V3 coilover kit? Since I have the oem camber with, it should be the oem size but not sure...
https://www.apexraceparts.com/suspen...mw-e89-z4.html
      09-23-2017, 03:21 PM   #10
fmorelli
fmorelli's Avatar
Drives: Atacama Yellow 35i
http://www.rogueengineering.com/Vors...ate_p_196.html
      09-23-2017, 04:48 PM   #11
rif75
France
64
Thanks Filippo but I prefer to stay with the ground control, it seems to be better for a street use (go to the track maybe 4-5 times/year)
      09-24-2017, 10:05 PM   #12
Vetracr
When I ordered a KW Variant 3 kit for my Miata it came with springs. I'm sure BMW kit does too. Check kit details on spring size.
      09-25-2017, 02:12 PM   #13
fmorelli
fmorelli's Avatar
Ground Control makes great stuff. But I'm curious why you say there setup is better for the street?
Filippo
      09-25-2017, 04:02 PM   #14
rif75
France
64
It seems that they are quieter in street version than the other ones
      09-25-2017, 09:22 PM   #15
fmorelli
fmorelli's Avatar
Interesting. Can I ask where you heard that? I am surprised there would be a difference. I was going to buy Vorschlag for my KW3 setup, but also looked at Ground Control. Do you have any more information to share on the noise factor?
Thanks,
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport.
      09-26-2017, 09:45 PM   #16
rif75
France
64
I ll check where I read that but from what I remember, it s because for teh street version it s not metal against metal.
I should receive it tomorrow. I ll let you know when it s one the car.
      04-10-2018, 02:17 PM   #17
fmorelli
fmorelli's Avatar
So I ordered Vorshlag camber/caster plates. They don't fit. It seems that the E89 Z4 shock tower mount holes are different than E90. They look like the E30 but spaced differently.
wmandra says he installed the Vorshlag kit in his suspension thread. Anyone have any specific info on this?
Filippo
zpost
