11-14-2012, 10:40 PM | #1 |
Rep 959
Major Speedo Error
Hello,
Today I thought that I was going a little slower than was indicated and decided to check with GPS. Mind you its only an iPhone app, but it can't be off that much. I checked and my jaw dropped. Going indicated 80km/h GPS showed 73km/h. Going 140km/h GPS showed 129km/h. Thats 9%!!! I just switched to 235/40/18 winter tires on OEM winter package rims - they have at least 60% thread left. My summers are 245/35/19F and 264/30/19R. The diameter for the tires are: 235/40/18 - 25.40" 245/35/19 - 25.75" 265/35/19 - 26.30" What could be wrong? Can it be fixed at the dealership through programing? Where do our cars pick up the speedometer reading front or rear tires? Thanks in advance. Last edited by Superfly_M3; 11-15-2012 at 12:05 AM.. |
11-14-2012, 10:57 PM | #2 |
Rep 2,189
you should be running 265/35R19 not 265/30R19 in the rear
i used gps to verify my speedometer. it's about 2% error for me on stock 18's (75 indicated is 73) speedometer is picked up off rear but the car gets wheel speed data from fronts and rears if you do a burnout they know you are going 0-5mph even though your rears are going 30mph... that is how they have tried to get out of warranty claims in the past |
11-15-2012, 12:36 PM | #4 |
M3Post Supporting Vendor
87
Rep 964
This is not completely shocking when you factor in that BMW speedo is usually reading a few percent high. Stack the ~3% error on the speedo with 3.5% error due to tire size variation and maybe a couple percent error in the GPS and you're right there.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
11-15-2012, 01:33 PM | #5 |
Rep 2,792
The M3 guys at the Airstrip attack this past weekend were noticing a significant difference between the speedo and their Vboxs. I have been driving past one of those police speed things that warns you to slow down and at 60 mph indicated, the display on the police thing shows 54. I am running 255/35/19 and 275/35/19.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
11-15-2012, 01:34 PM | #6 | |
Rep 1,590
+1; I don;t think thats unreasonable at all |
11-15-2012, 03:45 PM | #9 |
Rep 5,506
You have 235/40/18 all around!? That is way smaller in diameter than the front or rear stock size of the car. You get less ground clearance, higher rpms for the same speed, and just plain looks weird. The speed sensor is attached to the transmission which reads rear wheel speed. You should be running 245/40R18 or 235/45R18 all around if you want something closer to stock sizing.
11-15-2012, 04:40 PM | #10 | |
87
Rep 964
11-17-2012, 01:58 AM | #11 | |
Rep 959
What does speed and limiter has to do with this thread? ... not that you are trying to jack it or something like that. |
11-17-2012, 08:04 AM | #12 |
Rep 5,798
Every BMW I've owned has had an error between 5-8% and the error is worse at higher speeds (e.g., on the track; also, it appears the speedo "calibration" curve is non-linear). Below 70 mph my errors have all been < 5%.
11-19-2012, 07:57 AM | #13 |
Rep 713
11-19-2012, 02:15 PM | #15 |
Rep 869
Mine has a 5% speedo error with stock wheels and tires. so, 2 mph at 40, 4 at 80, etc. I documented this by one of those radar "Your speed is ___" signs near my house. Now, my track tires are 18s, so that introduces another 2% error for a total of 7%, so when my speedo says 153 at Road Atlanta my gps tells me its really only 143.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
12-08-2012, 11:10 AM | #16 |
Rep 713
