GetBMWParts
      09-25-2013, 12:38 PM   #1
BRAISKI
BRAISKI's Avatar
Drives: '11 335xi e92 M-Pak
2011 BMW 335xi  [7.00]
Question Bi Turbo vs Twin Turbo?
Ok now that the new M3/M4 will have a "bi turbo".
What exactly is the difference? Is there a difference, since technically bi=two so 2=twin.
Is one turbo for a first range of RPM and second is the the next range of RPM. This would be interesting comparison since BMW now has a car with a Twin Turbo (N54) and a car thats called Bi Turbo (S55).
Tried searching around Google but nothing no satisfactory answer everyone seems to have some different opinions.
      09-25-2013, 12:41 PM   #2
Savory
Kaskasero
Savory's Avatar
55
Drives: You Insane
Same thing. Bi=two. What you are thinking of is a sequential twin twin turbo system in which one turbocharger (smaller of the two) is specified for a lower set of RPMs to provide fast boost/response, then an actuator let's the second pre loaded turbo spool for the higher RPM range. At least that's how I remember it working. M4 appears to use a parallel twin turbo setup (two of the same turbos)
Rides:
BSM E53 X5 3.0i | Mods: 4.8is Style 168 wheels
1996 MB C280 Sport
2001 E39 M5
      09-25-2013, 12:42 PM   #3
bcl0328
Drives: 2012 328i
The term twin turbo has been often given to vehicles that use sequential turbos, a small one for low rpm torque, and a larger one for higher rpms and power. The biturbo system uses two equally sized turbos, one fed by cylinders 1-3, and the other by cylinders 4-6. They are not sequential or in series, but in parallel.
      09-25-2013, 12:44 PM   #4
Lorde
Ya ya ya, I am Lorde, ya ya!
Lorde's Avatar
Drives: E90 M3, 2015 SQ5
2008 BMW M3 E90  [0.00]
Really?? Already with these threads!?
      09-25-2013, 12:56 PM   #5
Boss330
Boss330's Avatar
Drives: BMW
BMW uses the phrase "Twin Power Turbo" for marketing speak. Either referring to a twin scroll single turbo or two turbos (a bit confusing).
This has Twin Turbo, which just is two turbos (as seen in the photos). BiTurbo or Twin Turbo is basically two turbos. Sometimes in paralell, sometimes serial, but still two separate turbos.
The exception being BMW's "Twin Power Turbo" which can be one or two turbos as explained above...
      09-25-2013, 01:06 PM   #6
NISFAN
NISFAN's Avatar
United Kingdom
3489
Drives: BMW M2
I suspect that 'Twin Power' just means forced induction. Even the single turbo - single scroll Diesel engines are branded 'Twin Power'
Regarding the twin turbo / BiTurbo, both terms can be swapped as they mean the same. For me I would expect Twin to mean two the same(same size in the case of Turbo's), but this is not always the case.
      09-28-2013, 12:38 PM   #7
gee-m-w
gee-m-w's Avatar
74
Drives: S4
This thread seems silly but I could see there being a difference. If there was two separate turbo systems that handle 3 cylinders each, you could call that a (identical) twin turbo. If there is two serial turbos of different size on the same circuit, you would call that a bi-turbo.
f80post
